Question about Acer Extensa 4620 Notebook
Battery I have a problem in the battery ... where they can not be more than a quarter an hour, then stop .. I hope you help me and thank you
  • nassufyu87 May 02, 2010
    8 month
  • Amruth Louis May 11, 2010
    How old is your battery?
    Sergeant:
  • 280 Answers
Since it is still under warranty, it is better that you take it to an authorized service center for replacement. Any poking on our side can void your warranty. Your battery seems to have a manufacturing defect.
Posted on May 02, 2010
Should my tablet battery go dead in two hours?
This is a loaded question... really. It has factors involved.
Are you watching videos, is the brightness all the way on 100? Or is it set on auto. Are you using bluetooth, and other power consuming actions on the tablet?
All of these things weigh in on whether a battery lasts 2 hours or 4....6....8.
If your battery is wearing down in 2 hours. Age of the tablet my constitute a battery replacement. Always wait until a battery is empty before charging it up.
Get an app stopping program. Installed so as to not having apps running in the background, draining your battery without you even knowing it.
I hope this helps a little.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/daniel_6d8155c5b1755ec1
Mar 17, 2016 | Tablets & eReaders
Im looking for an Extended Battery For a Dell Inspiron mini 10,as For Hours it lasts,?Cells? Thanks..
Sorry, I accidentally hit the button. The battery is supposed to be double the life of the regular battery, which was 9.5 hours. It can be found here (ignore link above):
http://www.amazon.com/Replacement-Rechargeable-Inspiron-312-0867-312-0931/dp/B004T87HW8/ref=sr_1_2?s=pc&ie=UTF8&qid=1333342127&sr=1-2
Hope this helps.
Apr 02, 2012 | Dell Inspiron Computers & Internet
My blackberry curve 8520 smartphone-this morning i turnt my phone on it was working normally then i re-booted my phone the loading screen came after 3 quarters of the bar it stops loading what should i do?
Switch the phone off and remove the battery for thirty minutes.
PUT THE BATTERY AND CHARGE THE PHONE FOR SIX HOURS AND SWITCH IT ON.
REGARDS
Sep 21, 2011 | Cell Phones
Fuel warning and battery warning (in the dashboard) stays on even when im already driving. I had my alternator and battery line checked already. I tried using new battery as well. The fuel gauge still...
I suggest checking your fuel filter,and cleaning rthe battery terminals THOROUGHLY.Also make sure if you have a battery that has the type caps that allow you to check the battery water level,make sire the water level is at least one quarter inch from the top.Also make sure belt on alternator is tight or the belt tensioner is working properly.
May 25, 2011 | 1992 Nissan Pickup
Battery runs down after about 5 hours and has to be removed and recharged. This leads me to believe that the battery is not being recharged in use. My supplier says nothinhg is wrong and I am stopping and...
Hi, has your supplier actually tested that the mower is charging? If you have a multimeter check the battery voltage with the mower running at about quarter throttle. It should be higher than 12.7 volts, usually somewhere around 14 volts. If it is not the charging system requires checking. Hope this helps, regards Phil.
May 19, 2011 | Garden
My 2005 z4's battery indicator color is black. Which means it is insufficiently charged. We tried to series it to another car's battery and drove it for an hour or so, hoping it will charge. When we got...
If the battery have, as you have said charged it more than an hour, it must be already dead and would not accept charging. It means the cell plates inside are all exhausted.
Try to go to your battery dealer and have a free check up. They have a meter load tester that assesses your battery if it is still good or need be replace. Ask them to check your charging system too!
The charging system should have a 13 volts to 14 volts output!
Hope that helps you out!
Thanks for using Fixya!
Dec 07, 2010 | 2005 BMW Z4
Acer keyboard and touch pad doesn't work
I had the same problem. Do not put the battery back. It is damaged. You need a replacement. It is a battery surge that causes this behavior.
Sep 07, 2008 | Acer NSK8458AN Keyboard
Battery pack for Canon ZR100 digital videocassette camcorder
For good spare canon nb-2lh battery,or cheap replacement canon nb-2lh digital camera battery,you can search and searh to find a famed relible camera camcorder batteries store with chargers on sale,shopping online convenient and cheap !
Jun 25, 2008 | Canon ZR100 Mini DV Digital Camcorder
Battery life under 5 hours
have you let the battery go totally flat as this is recomended to do every couple of months because if you dont let the battery go totally flat this stops the battery from full recharging and will cause bad cells in the batt so i would let hte battery totally flat till it wont even light phone up then fully charge for 16 hours see if this improves the battery if not then the charger is probably over heating and cutting off so you could replace the charge hope this is some help to you
Nov 19, 2007 | Samsung SGH-D900 Cellular Phone
Acer Extensa 4620 Notebook Logo
46 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
