Question about Linksys Wireless-G WRT54G Router
Wireless Range seems to have been reduced - Linksys Wireless-G WRT54G Router
  • 550 Answers
Try to change the wireless channel on the router. For this you will need to access the router set up.
If your router is very old then it's better to upgrade the firmware of the router.
Firmware is the software of the router.
Download the latest firmware of the router. Go to the manufacturer's web site and download the firmware of the router.
Open the set up page of the router and upgrade the firmware of the router. Once you upgrade the firmware of the router, reset the router.
On the router you will find a small reset button, hold it down for 30 seconds. release it. wait for 1 minute. Now unplug the power to the router and plug it back in.
Now you will need to reconfigure the router according to the Internet service provider.
Posted on May 02, 2010
Inconsistant wireless signal in house
Have you checked that the signal on your new cable modem/router is strong enough to reach your wireless devices? You may need to re-site the cable modem to get better coverage in your home. Your old one probably worked fine in the same position but that doesn't mean a new one will. There are a few things you can try to get the best of the range it has. Internal walls and furnishings all play a part in reducing the effective range of the router. Most routers will give you at least 50 metres indoors. Keep the router as high and as far away from walls as you can, this will greatly improve the range. Try to ensure the router is not screened by large near by metal objects such as steel PC cases, these will absorb wireless signals and reduce the range.
Jan 18, 2014 | Arris SURFboard Gateway SBG6580 DOCSIS 3.0...
How to extend range
Difficult one to answer. You cannot adjust anything internal to the router to extend the wireless broadcast range. however, there are a few things you can try to make the most of the range it has. Internal walls and furnishings all play a part in reducing the effective range of the router. The model you specify has the 3x3 MIMO antenna array so should give you a decent range, at least 50 metres indoors. Keep the router as high and as far away from walls as you can, this will greatly improve the range. try to ensure the router is not screened by large near by metal objects such as steel PC cases, these will absorb wireless signals and reduce the range.
Oct 18, 2013 | Cisco Linksys Wireless Router EA4500...
Expand range extender
You can install a wireless range extender. Try a Netgear Dual Band WiFi Range Extender, this device extends the wireless range of your existing wireless router, it connects to your wireless router using a wireless connection without the need of a LAN cable.
May 19, 2013 | TP-LINK TL-WR1043ND Router
Is there a way to reduce the range of my Dlink wireless G router?
Hi Good day!! Im sorry but you cannot set the range of your router because it is already set in the system of your router which mean it cannot be re-set.
Nov 24, 2010 | D-Link Computers & Internet
I have multiple workstations with the same wireless dynex mouse. The ones that are closer together connect to the wrong room and conflict. Any way to change frequency or reduce range?
Unfortunately, there aren't very many settings to adjust for the Dynex wireless mouse. It is only set up to use one frequency, and other than putting up thicker walls or jamming the frequency somehow, there really is no way to reduce the mouse's range.
You can get wireless mice for $10 or $20 at most computer stores, discount stores, and online retailers -- your best bet is to use mice with different frequencies for computers that close together.
Sep 23, 2010 | Dynex Wireless Optical Mouse
My Craftsman remote won't close my garage door
If the remote opens and closes while inside the garage but not outside , there are a few things it could be. Assuming it was working fine before..
1. weak battery in remote.
2. remote itself could be bad. (unless you have more than 1 remote acting the same)
3. Logic board in opener is going bad causing limited range.Is the wire that hangs down from the opener straightened out? That is your remote antenna.Some people have coiled or even cut it off..reducing range.
4. Less likely but this can happen- interference from another electronic device, wireless routers, cell phone, new appliances etc.. can reduce remote range. Any new electronics recently purchased?
Jan 28, 2010 | Sears Craftsman LiftMaster Chamberlain...
I want to know if an ' N ' range wireless router s
All of the "N" routers I have seen are backward compatible to the 54 Mb "G" standard. An "N" router on your network will mot likely not work any better than the old "G" router did (unless there was something wrong with it) if you continue to use the old "G" card in the PC.
To take advantage of the greater range and other technical advances that the "N" router offers, an "N" card should used in the PC, too.
To maximize speed and reliability of any wireless "G" network, decrease as much a s possible, the distance between the "G" router and wireless PC.
An open air, "line of sight" path is best. A path through gypsum board, wood, foil backed insulation, brick, concrete, steel goes from "OK" to "very difficult". Basically, the thickness and type of material can affect the signal. The harder it is for you to drill through the material - so is the difficulty of passing a wireless signal through (more or less).
Minimize interference by reducing or removing any cordless 2.4 Ghz telephones, intercoms, etc. These devices *can* significantly reduce the range of wireless G networks. Try it yourself by unplugging the base and removing the battery from a handset to see if this is a source of interference for your location.
Sep 30, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Security
If you do not have wireless security enabled then anyone within the range of the radio transmitter will be able to use your internet access.
A G band router has about a maximum range of 300 feet which is greatly reduced by walls, wiring and other items in your home.
If your using a wireless laptop you can do a site survey by walking around outside your home to get an idea of the range your router has.
Dec 28, 2007 | Linksys Wireless-G WRT54G Router
Very short range of wireless network
Your Belkin Wireless router being an RX/TX device follows the basic rules of radio communication:
1. LOS - line of sight range; anything in between the router and the laptops such as doors, walls, drapes, foliage is an obstacle that reduces the signal strength to a certain degree;
2. Height is might, the higher the router the better;
3. Antenna, the more exposed the further the range. Internal antennas such as in most laptops reduce both receive and transmit. Likewise, placing the router in a shelf or cabinet reduces antenna exposure. How you position (orient the antenna also plays a role in coverage. Some materials will reflect radio signals and change antenna radiation pattern.
A few things you can try to improve coverage:
a. Mount the router to the highest practical position;
b. ensure that there are no obstruction between router and laptop;
c. position router to approximate practical center between two furthest laptops;
d. install an external antenna if the Belkin would allow;
e. Replace the F5D7230-4 with another with more punch such as a LinkSys WRT300N; and/or
f. In really extreme range, install repeaters.
Hope this be of some help/idea. pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Nov 05, 2007 | Belkin (F5D7230-4) Router (587009)
Range
All wireless products are subject to radio interference. The performance is a direct result of the operating environment. Other products that use the same frequency can drastically reduce the performance of the wireless product. Try changing the operating channel or moving the wireless Access Point.
Feb 16, 2006 | Belkin (F5D72304F5D7000) Router
Linksys Wireless-G WRT54G Router Logo
82 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
