Question about Uniden Cordless Phone exai398i
Set ringer back on
I have no guide to find out how to fix the ringer from off to on - how do i get it?
  • ceagles Mar 30, 2008
    thank you so much for the manual - it really helped
  • 667 Answers
Here is the link for your manual. Hope this helps. Please rate if it does.Thx. http://www.uniden.com/pdf/EXAI398iom.pdf
Posted on Mar 25, 2008
Lg phone won't ring # 800Ghl
look at the phone receiver on one of the buttoms on the phone will say settings, open the setting scroll down the list until you find the ringer and turn the ringer off or on.
if you need to find a manual or information try looking in the following sites:
www.ask.com
www.about.com
www.howto.com
www.info.com
www.wiki.org
www.wikipedia.org
www.infolink.org
www.alltheinternet.com
ask info: manufactures name, model # operational manual
setup guide phone, installation guide
thank you rod
Mar 15, 2015 | LG Cell Phones
How do I adjust the ringer volume of a GE 29369? The incoming ringer is too loud. Can't find the answer in the manual user guide. Thanks N.T
Set the RINGER volume switch located at the back of the base to the desired loudness.
OFF - Telephone will not ring.
LO - Sound will be lowest.
HI - Sound will be loudest.
The above is from the third column of the first page of the manual at
http://www.home-electronics.net/USER-GUIDES/29369_DOM_ES_CD_IB.pdf
May 24, 2011 | GE 29369GE1 Corded Phone
Ringer is off/cannnot hear incoming calls - instructions does not include how to turn the ringer back on
hello,you have to go to your phone settings,then you go to the phone ringer settings,you then set the ringer settings to the step you wish.
that will make your phone ringer work as expected and supposed.
wish you good luck,
take care.
Aug 13, 2010 | Cell Phones
The ringer icon keeps appearing on the screen
Sorry but your Ringer switch needs replacement. Take it to the apple store and see if they'll give you a replacement. If they don't there are third party iPhone Repair Services that can fix it for you. There are also free iPhone Repair guide that show you how to fix it yourself.
Apr 13, 2010 | Apple iPhone 3G
KX TGA244B How do I get the ringer back on
Handset ringer volume
4 levels (high/medium/low/off) are
available. The default setting is HIGH.
1 Press {MENU}.
2 Scroll to “Ringer setting” by
pressing {V} or {^}, then press {>}.
3 Scroll to “Ringer volume” by pressing
4 Press {V} or {^} repeatedly to select
the desired volume.
LTo turn the ringer off, press {V}
repeatedly until “Off ?” is displayed.
5 Press {Save}.
Note:
LWhen the ringer volume is set to off, the
handset will display “Ringer off”, and
will not ring for outside calls. The
handset will ring at the low level when
paged by the base unit.
Jan 05, 2010 | Lands Phones
How can I turn the ringer back on? Thank you
1 Press (MUTE/FUNCTION).
pressing öor ñ, and press á.
3 Press áat “Ringer volume”.
4 Select the desired volume by
pressing öor ñ.
•Each time you press öor ñ, the
volume will change and ring.
To turn the ringer OFF:
press örepeatedly until “Off ?” is
displayed.
5 Press á(Save key).
•A beep sounds.
To turn the ringer ON:
Press ñin step 4.
•The ringer will sound at the LOW level.
•You can exit the programming mode any time by pressing (OFF).
•If set to OFF, “Ringer off” will be displayed while the handset is not in use.
•If you have received new calls, “Ringer off” will not be displayed but
“Received calls” will be displayed while the handset is not in use.
“Ringer off” will be displayed for about 5 seconds after completing operations
or lifting the handset from the base unit or the charger.
•You can also select the ringer volume while an external call is being received.
Press öor ñwhile the handset is just ringing.
•You can change the ringer tone for external calls. See page 49.
HIGH
MEDIUM
OFF
Ringer volume
Low High
Ringer volume
Off ?
LOW
ñ
ñ
ñ
ö
ö
ö
V.M. access
HRinger setting
Initial set
HRinger volume
Ringer tone
18
LCD
Oct 26, 2009 | Panasonic KX-TG2352 Cordless Phone
How to inactivate melody ringer
Base unit ringer tone
(use either the handset or the base unit)
Make sure the base unit is not being used.
Setting the base unit ringer tone by using the
4 Select the desired ringer tone by pressing [d]
or [B].
• The handset will ring and the ringer tone will
change. If the ringer volume has been turned off,
the handset will not ring
• You can also select the ringer tone by pressing [1]
to [7].
5 Press Save, then press [OFF].
Press VOLUME [<] or [>], then select the desired ringer tone by pressing
[1] to [7].
[1] to [3] : Bell ringer patterns [4] to [7] : Melody patterns
• After pressing VOLUME [<] or [>], the base unit will ring using the current ringer
tone.
• The base unit will ring and the ringer tone will change.
• To stop ringing, press [STOP].
1 Press [MENU].
2 Scroll to “Initial setting” by pressing [d] or [B], then press
Select.
3 Scroll to “Set base unit” by pressing [d] or [B], then press Select.
4 Press Select at “Ringer tone”.
5 Select the desired ringer tone by pressing [d] or [B].
• The base unit will ring and the ringer tone will change. If the base unit ringer
volume has been turned off, the base unit will not ring
• You can also select the ringer tone by pressing [1] to [7].
6 Press Save, then press [OFF].
This Can Be Found On Page 17 And 18 Of The User Guide.
If You Do Not Have The User Guide It Can Be Downloaded Here
http://support.radioshack.com/support_phones/doc73/73355.pdf
Thank You For Choosing Fixya.com
Dec 21, 2008 | Panasonic KX-TG2357 Cordless Phone
Cannot Hear the Ringer
could be set to "no ring" on the system, if so it will never ring, sounds like you need to talk to your helpfull sys admin!! ;-)
Dec 09, 2008 | Mitel 5220 IP Phone
Turn off ringer
here's what my instructions say about turning off the ringer:
Ringer high/low/off Shortcut
Apart from the setting in the main menu, there is a shortcut to set the ringer. Make sure the phone is OFF (not in talk mode).
1. Press the #RINGER/PAUSE button to go to the RINGER VOLUME menu. RINGER 1HIGH shows in the display. 1HIGH is the default.
2. Use the cid/vol (- or +) button or the touch-tone pad on the handset to scroll to 1HIGH, 2LOW, or 3OFF.
3. Press the #RINGER/PAUSE button to save your selection. You will hear a confirmation tone.
Jan 21, 2008 | GE 25951EE2 Phone
Ringer off, need to re-install ringer. volume control does not put ringer back on
To turn your ringer back on, you do the following. For your handset, you push Menu, scroll to ringer settings, then push select, Press select again for ringer volume, then scroll up to turn on and increase the ringer volume. Then press Save once its at the desired volume. To change your base ringer, while it is not in use, push the ringer up button until you hear the desired setting. That should fix your problems.
Dec 31, 2007 | Panasonic KX-TG2357 Cordless Phone
Uniden Cordless Phone exai398i Logo
111 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
