Question about Kyocera Mita KM-1815 All-In-One Laser Printer
Kyocera c3200 error Problem - Kyocera Mita KM-1815 All-In-One Laser Printer
  • 29 Answers
A C3200 is as follows:
Exposure Lamp Problem.
• In indicator check before starting copying, the average value in scanning of the shading plate with the CCD is 128 or more.
Solution:
Defective scanner board (KP-5063).
Replace the scanner board (KP-5063) and check for correct operation
Defective exposure lamp or inverter board.
Replace the exposure lamp or inverter board.
Incorrect shading position.
Adjust the position of the contact glass (shading plate). If the problem still occurs, replace the scanner home position sensor.
Poor contact of the connector terminals.
Check the connection of connector YC7 on the scanner board (KP-5063), and the continuity across the connector terminals. Repair or replace if necessary.
These are direct from the Tech man.
More than likely it is the Exposure Lamp.
Hope this helps.
Posted on Aug 24, 2010
3 Suggested Answers
flsts
  • 10 Answers
SOURCE: Scan error C3200
C3200 indicates a problem with the exposure lamp. You can try to clean the optics and check the lamp. It may need parts if cleaning does not fix it.
Posted on Feb 27, 2008
  • 241 Answers
SOURCE: Unable to copy with my Kyocera KM-1815. Error code is C3200.
Typicaly the scanner optics would need to be cleaned. Or it could be a scan lamp failure. A Kyocera dealer could help you with this.
Posted on Jun 09, 2010
I have kyocera km1500 and have error A3200 .what is the solution?
Hi
A3200 is not a known error in the service manuals, maybe it's C3200?
Code
C3200
Description
Exposure lamp problem
Causes
Defective scanner board (KP-5063). Defective exposure lamp or inverter board. Incorrect shading position. Poor contact of the connector terminals.
Jul 24, 2016 | Kyocera Office Equipment & Supplies
My Kyocera km-c 830 shows error code c3200
Exposure Lamp Problem. Exposure lamp does not reach the input value threshold within 5 sec of commencing reading.
Oct 25, 2013 | Kyocera Office Equipment & Supplies
Error c3200
C3200 is an exposure lamp problem. The simplest explanation would be a bad exposure lamp or inverter. More exotic, but still possible, is very cold environment, dirty AC power, a bad CCD, or a bad main PCB.
Jan 29, 2013 | Kyocera FS-1118MFP Laser Printer
Fs-1118 mfp printer error code c3200 for solustion
UNLOCK THE SCANNER LOCK SWITCH ON THE PRINTER WORKING.
Mar 17, 2012 | Kyocera FS-1118MFP Laser Printer
C3200 ERROR IN FS-1118MFP PRINTER WHAT I DO FOR THIS ERROR
I've cleaned the optics and the error stoped.
In addition, I've set U087 to no.
Mar 19, 2011 | Kyocera FS-1118MFP Laser Printer
How to resolve error code c3200 on km1650,fs1118 copiers
c3200 is related to the optics. in km1650 the scanner may be derailed. check and realign the wire. clean the lamp and the entire optics.
Aug 11, 2010 | Kyocera Mita KM-1650 All-In-One Printer
May 27, 2010 | Kyocera Mita KM-1815 All-In-One Laser...
Kyocera mita error codes of KM 1500
Hello sir; The error code you display A3200 is not available in our menual, we do have C3200 , if that's correct, it means exposure lamp burn out ( not on), replace it, or thermos fuse out.
May 13, 2009 | Kyocera KM-1505 Copier
Scan error C3200
remove the flat wire in the scanner, then remove the railings from the scanner, clean the railings with a soft cloth, if you encounter the c3200 error it only means that the railings of the scanner is dirty, the scanner cannot move. i hope this will fix your problem..... if you have anymore questions regarding kyocera copiers dont hesitate to txt me or call me to this number +639081953003 or +639079941995
Feb 27, 2008 | Kyocera Mita KM-1815 All-In-One Laser...
Kyocera Mita KM-1815 All-In-One Laser Printer Logo
2,359 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Adorjani Laszlo
AAAA262430
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
