Question about HP Pavilion a420n PC Desktop
Hp Pavillion a420n blinking light
The pc clicks but the fan is not moving at all.i took the memory out and put it back in and it still didnt turn on and i checked all the wires again and they are good.
    Genius:
  • 1,226 Answers
Hello.
Is the computer still its power ? if the pc has its power then try to switch on without the memory. if the system beeps means that the mainboard and processor is good. However, if the pc has no power at all then first check the power supply.tell me what happen i give you more troubleshooting.
Posted on Mar 26, 2008
  • Anonymous Mar 31, 2008
    did you try my solution?
    anyway, in that case, the mainboard probably is busted. please consult the repairman in your area because it hard for me to troubleshoot when the unit is not at my hand. melnavz
SOURCE:
Red switch on hp pavillion
Is it booting up to windows?
What happens when you press the Power Button?
Whenyou plug in the power cord is there any lights whatsoever on the laptop, wherethe plug goes in or on the AC Adapter of the power cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the computer is trying to boot or may have booted,but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous. Most times the problemis with the memory or Video Card. Count the Blinking Lights or Beeps and takenote of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe you have a Static ChargeBuildup. Remove the Power Cord, then Press and Hold the power button for30 seconds. After 30 seconds plug the power cord back in and hit thepower button to see if it boots. Maybeyour memory is bad or the memory slot is bad.Removethe Power Cord, Open the Case and remove one of the memory chips. Set thechip aside then try rebooting the computer. If it boots, then you knowthe memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and tryrebooting. If it fails take the chip out and set it aside, then put theother chip in and try booting it in both slots. If it boots, just toverify that the chip set aside is bad, mark an x on it and put it into the openmemory chip slot and try booting.
Jun 07, 2012 | HP Computers & Internet
We moved the desktop to another location. We powered down and unplugged it. When we plougged it back in there was an alarm that went off then the power button started flashing and continues to do so. We...
hi t could be that your CPU fan is loose or that your RAM(memory) came loose try looking on youtube to see how to put RAM (memory) into pc and make sure your CPU fan is secure....bonnell
Sep 17, 2011 | HP Pavilion a705w PC Desktop
My hp pavillion a420n keeps shuting off and turning itself on every once and a while. Also othe flash keeps crashing and programs keep failing. Any clue what it may be telling me?????
Hardware failure - the voltage to the processor is unstable because either the PSU or the rectifiers on the motherboard have aged. Open the case and look at the motherboard - if some of the capacitors on it are bloated then you will have either to replace them or the entire board. If the capacitors are fine in there then the fault is in the PSU - you can get a new one for less than $20 at every pc shop.
Jun 03, 2011 | HP Pavilion a420n PC Desktop
My HP a420n won't start after replacing cd-rw drive
Please try to remove all the connections from your computer and also connections inside the motherboard, the power cord for your hard drives and also the power cord from the power supply to your motherboard.After that, remove the memory and clean the pin by using an eraser of the pencil. And then insert again the memory stick and connect all the connections from the power supply to motherboard and everything. Lastly reset your bios and put it back to normal again. Hope this would help. Thanks..
Oct 22, 2009 | Computers & Internet
I have a blinking green light on the back of the PC by the fan. What does that mean
That all depends.
Some computers have a small cluster of 4 leds that are used for diagnostics or if you have your computer on a network (cat 5 ethernet cable) plugged in then all it means is that there is activity on the network.
Aug 07, 2009 | HP Pavilion a420n PC Desktop
Light yellow under blue on light. power and fans on.
just unplug first the ac cable after 20 seconds pluin and test again. or it the same problem just open your cpu ang pull out the memory and clean the surface and insert again test your cpu again
Jun 26, 2009 | HP Pavilion a420n PC Desktop
Just installed 2 gb pc 3200 in hp pavilion a 420n
Remove the sticks and put them back again, make sure you hear the "click", the click means that the sticks are where they should be in possion,¨
Btw, you bought sticks that are suported by your Mobo i asume?
Dec 07, 2008 | HP Pavilion a420n PC Desktop
Hp wont turn on flashing green light in back an flashing blue light in front.
open your cpu remove the ram clean it put it back your problem will be sloves
Jul 16, 2008 | HP Pavilion a1250n (EG194AA) PC Desktop
Hello!
Is the pc has blinking power in it. or do your hear any beeping sounds? but anyway you can do check your PC. unplug the pc and open the system. remove and clean the memory and insert it again. and fix all connection inside the pc maybe some cable lessen. after that test the pc. and then tell me what happen i will give you more solution in it. melnavz
Mar 25, 2008 | HP Pavilion a420n PC Desktop
HP Pavilion a420n PC Desktop Logo
73 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
