Question about Gaggia Titanium Espresso Machine
Cannot solve "Ventilate" problem - weater circuit is broken
My Gaggia Titanium was performing the starting rinsing circle, when I accidentally removed the water tank. Rinsing continued, without water present, and in the end I had a notification "VENTILATE". In my Gaggia manual I found the instruction that it happens when the tank is empty (or removed) and that I need to press button 26 (with the water drop on it) and after the heating-up phase finishes I will be able to use the machine. But nothing happens when I press this button. I have filled up the water-tank. Can you advise me if I am doing something wrong or how to load the water circuit completely?
Please, help me with your adwice!
Thank you!
    President:
  • 1,618 Answers
Turn the knob on after you press the hot water button, run the cycle until the message is gone takes a few seconds or about 2 ounces of hot water.
Posted on May 04, 2010
Testimonial: "Thank you very much! It functions now!!!"
  • andrewbou360 Jul 27, 2011
    Can any body help me as my gaggia titanium has stopped working, I turned the machine on one morning the display went on for 2 seconds then went off and the whole machine doesnt work now.
    I replaced the fuse in the plug but still no joy,can any body help.
Why does my gaggia titanium say 'ventilate' 24 hours after decalcifying?
There is an air gap in system running the hot water clears it out.
Sep 04, 2014 | Gaggia Titanium Espresso Machine
How do I fiax a gaggia titanium stuck on ventilate?
rinse hot water.If remaining the ventilate ,you must change the flowmeter.
Aug 14, 2014 | Gaggia Coffee Makers & Espresso Machines
I have a Gaggia Titanium, I did descaling, had difficulty during the process. It shows ventilate. I have tried priming, but it doesn't pump water through the nozzle
Hi.
Disconnect and re-apply power (unplug power cord). After that try doing rinse and descale procedure as from manual. You may need to keep adding water while performing the procedure.
See also: the ventilate error.
Regards.
Ginko
Apr 20, 2011 | Gaggia Titanium Espresso Machine
What does it mean when the Gaggia Titanium machine tells you to ventilate the hot water as soon as you turn the machine on?
Ventilate by pressing the hot water button and opening the steam tap. Once water flows freely, close the tap.
If problem persists, its likely to be a broken "steam valve cam"
Apr 29, 2010 | Gaggia Titanium Espresso Machine
My Gaggia Titanium machine says ventilate
Run about an ounce of hot water from the wand.
Nov 10, 2009 | Gaggia Titanium Espresso Machine
Titanium ventilate issues
Remove the milk frother,checked to see if it is blocked.
This can cause the machine not to ventilate correctly.
They tend to block with old hard milk.
Aug 26, 2008 | Gaggia Titanium Espresso Machine
Titanium plus stuck on rinsing cyle
go in the menu remove rince cycle after it say ventilate put water in container start machine open valve it should ventilate if it doesnt remove water container take turkey blaster put water in it put the blaster in the hole were the water container goes force pressure with the blaster at the same time open valve you vented by now put cointainer back fill with water enjoy thanks for using fixya pierre
Feb 10, 2008 | Gaggia Titanium Espresso Machine
My machine was stuck on rinse cycle now on ventilate...
Try first to continue filling up the water resovoir (UP TO FOUR times) to see if the machine completes the rinse cycle on its own. If that doesn't work contact Gaggia Customer Service in the US at 888-389-4123. Sally there was VERY helpful and should be able to resolve your problem.
Dec 31, 2006 | Gaggia Titanium Espresso Machine
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
492 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
