Question about Apple iPod touch
I can't get connected to net on my itouch. I'm puuting in the correct password for my router i've checked on my laptop. I've checked it's not in caps.
  • Apple Master
  • 12,061 Answers
It's NOT the "Password" it's a WEP/WAP key generated IN the router at setup time, you need to access router, go securities, generate a KEY, copy that to notepad, save routers configuration, and then copy/pate the KEY into the "Authentication window" when trying to login to the WiFi Network, SSID. (Routers name)
Posted on May 02, 2010
My belkin works fine as do my items connecting to it which are a ps3,iPad,itouch,xbox360,and a few more but my laptop itself can't seem to connect to it even though it can be seen in the available...
What encryption is the router using? WEP, WPA, WPA2?
What version of Windows or MAC OS is the laptop?
For windows only WinXPsp3, Vista, 7 can connect using WPA/WPA2
Win95,98,ME, and XPsp1, sp2 are not able to use wpa wpa2
I believe you said that if you remove the security from your router that the laptop connects wirelessly, if this is the case you may need to update the wireless drivers to use it with encryption enabled.
Jan 26, 2013 | Computers & Internet
Itouch can't see my network
Not that I am aware of , but you signal strength will degrade if all the devices are on and using at once. Also your ISP MAY "throttle" your service/signal with high data usage. That said, Your iTouch and xBox, in the setting , wireless, the iTouch should see the signal, Is the wireless turned on? It's discoverable? If your wirell has a Password, has a setup box on the iTouch asked for the password? Use the Manuals for the devices to troubleshoot connections.
Dec 26, 2012 | Toshiba WRC 1000 Wireless...
I have had trouble connecting my laptop to the Internet at home. We gave another two laptops that are connected to our wireless router that work fine but my own laptop does not. It recognises the router...
  • Open Command Prompt, type 'ipconfig/all' and hit Enter. Check Default Gateway.
  • Ping your router's connection to the laptop. Open Command Prompt, type IP address, hit Enter. If your laptop is receiving connection from your router device, you will see a message like Reply from 192.168.1.1: bytes etc. If there is no connection, you may see the Request timed out message.
  • The Request timed out error can occur due to two things: (1). incorrect physical connection between your router device and the laptop or (2) incorrect wireless network setup & configuration. Recheck and correct the Ethernet connection between your system and the router device.
If you need any kind of technical assistance, you can contact support cell at http://www.vtechsquad.com
Sep 14, 2012 | Computers & Internet
Iphone doesn't work with router Dell 1184 broadband router in my house works with windows laptops but not Apple iPhone or iTouch. I have had the router/software installed for 5 years, is there new software...
you said the laptop is connected to the network.
when you try to connect to the wireless network on the i-touch or i-phone, do you see your network.
if your network is secured then you must enter the correct password for the wireless. If you are not sure about the wireless key or the password then you will need to open the router set up page and check the wireless settings.
you can also try to upgrade the firmware ( software) of the router.
Click Here to know more about router and network
Jan 10, 2010 | Dell TrueMobile 1184 Wireless Broadband...
Itouch connects to the internet everywhere except home
This is due to your router, not your iPod. I've had to reset the router several times in s row before I could connect to the internet. I'm not sure why the third time worked when the first two didn't. My suggestion is to keep trying repeatedly.
Oct 13, 2009 | Apple iPod touch
I'm not sure how to summarize this:
To reset the router to factory defaults there is a reset button on the back of the gateway usually between the power input and the RJ-45 jacks. This should get everybody back on the gateway. I would always recommend resetting the password and double checking the other settings you have changed to assist you with security since you have just cleared out all security settings as well.
Jul 08, 2009 | Belkin F5D7230-4 Kit (F5D7230V4SNPDQ)
Can't connect iTouch to Verizon GT704WG wireless router
Actiontech routers should use the username/password combination of admin // password. If those aren't working, you or someone else, may have changed the default username/password of the router. In that case, you either need to figure out what was set or use the little red button on the back of the router to reset the router to factory defaults. Once that's accomplished, you should be able to use the password combo above.
Mar 05, 2009 | Westell Wirespeed VersaLink...
Westell 327 modem is listed on itouch; itouch asks for password
lock on the botom of the router it might be locking for the WEP password on the label
Jan 04, 2009 | Westell Wirespeed VersaLink...
NetGear DG834GT
Are you sure you are entereing the correct passphrase, or is it a network key (usually entered in Hexadecimal). Is your Netgear router set up to use WEP or WPA or equivalient security?
Have a look at this thread. That may offer some insight.
http://discussions.apple.com/thread.jspa?messageID=6168599
Mike
Jan 05, 2008 | NetGear DG834G Router
Apple iPod touch Logo
121 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
