Question about Microwave Ovens
Roper microwave has broken glass in the door - Microwave Ovens
    Problem Solver:
  • 6 Answers
Whatever you do don't use the microwave until you replace the door. You run the risk of possibly shattering the glass or being exposed to dangerous microwaves from the oven. Get on the Roper web site and find a replacement for the door. You never know there could be a recall for safety issues on your particular model.
Posted on May 02, 2010
How do I clean between the glass and mesh on my roper microwave oven
That I would leave up to the professionals. If you are geting moisture or debris inside the glass then it is malfunctioning and needs professional repair. Call the service phone number locatedin the manual or in back of unit. These emit dangerouse uv rays that can harm you if leaking at the door. Never operate if you suspect it is not sealing properly.
Sep 02, 2014 | Roper Microwave Ovens
Need to know correct size of microwave door glass for LG model MG-604w mine is broken after a fall, can I still use without glass?
NO, do not use the microwave with a broken door glass, this glass is specially protected to stop any dangerous microwave leakage, it is also something you cannot replace yourself, take it to a reputable service centre so that once the glass has been repaire the oven can be tested for safety purposes.
Sep 09, 2013 | LG Over-the-Range Microwave
Can you use a microwave if the glass on the door is broken?
It is not advisable. The door is a critical safety part of the microwave oven. The glass being gone will allow heat in areas of the door not designed for heat. The glass also is a support for the safety mesh that contains the microwave energy to the cavity.
May 12, 2010 | Westpoint TV-201 Microwave Oven
The glass on the microwave door on the outside has slipped down and there is no screws to take apart the door and fix the glass. Does this fall under the warranty? My 5 years is up on 12/01/09.
I would contact customer service (for Amana, Frigidaire, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here about the warranty and to find your nearest authorized servicer.
If not, it's pretty easy to fix this yourself.
There are probably broken tabs on the inner or outer door panel.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can find handy exploded views and order parts by model number here.
Sep 26, 2009 | Maytag MMV1153A Microwave Oven
Broken microwave door glass
Be very careful with microwaves. I would not work on it myself. Technicians actually have a meter to measure for leaks after they put it back together. I would be surprised if you could get parts for it anyway. You risk life and limb if you get it wrong.
Aug 15, 2009 | Neff H7871N2GB Convection / Microwave Oven
Door handle broken away from microwave unit.
The door handle can easily be replaced. This is a common problem with microwave oven doors. You would think the manufacturer's would make them a bit more durable.
This is a very simple repair. To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
If you have questions about this repair, please let me know. I hope this helps you.
Jul 16, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Can i replace a broken door handle?
Yes. This is a very simple repair. To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
Jul 15, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Broken glass on full sized microwave door
Unfortunately, you would have to replace the complete door assembly, you can find a replacement door assembly for this model at this link:
LG LRM1230W Replacement Part Complete Door Assembly
Jan 07, 2009 | LG LRM1230W Microwave Oven
Burnt stain on door
In most cases you must replace the glass in the door. Sorry i couldnt be of more assistance. Good Luck
Jul 03, 2006 | Roper MHE14XKB Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
