Question about Tunturi T30 Programmable Treadmill
Treadmill stops when i incline it
Power just turns off when i put on the incline
    President:
  • Tunturi Master
  • 832 Answers
Start your unit without any body on it, then increase incline and see if the unit shuts down if it does not then the first thing I would do is lubricate the deck if no maintenance has ever been done on the unit refer to your owners for the procedure. After lubricating the deck proceed with normal operation of the unit. If this do not take care of the problem you may have a worn belt and deck thus causing too much power to be draw thus shutting it down.
Posted on May 15, 2010
Error 100 won't connect to network anymore to use ifit live
Check the power cord to ensure it is connected to the power supply and the treadmill if the power does not stay on or does not turn on. Look at the circuit breaker, located near the base of the unit, to see if the circuit was tripped. Push the switch back in to reset the circuit.
  • 2 Take the key out of the console, wait a minute and place it back in the console to resolve issues with the power turning on and off during use or if the console displays are not functioning properly.
  • 3 Remove the console key and press the "Stop" button to turn off the "Demo" mode, which is often the default setting when the treadmill is first purchased.
  • 4 Reset the incline by holding down the "Stop" and "Speed increase" buttons and putting in the console key. Release the buttons and then press the "Stop" button, followed by the down or up arrows for the incline. This step can be taken if errors are occurring with the incline function.
  • 5 Turn the treadmill "Off" and unplug the unit if errors continue. Wait five minutes and then plug the unit back on, insert the console key, and turn the treadmill "On." This will reset the treadmill and should return to normal funcTION
  • Oct 04, 2011 | Nordic Track NordicTrack Elite 9500 PRO...
    The incline on my proform treadmill is not working and now I can't get the treadmill to start, it just keeps inclining up and down
    ICON CALIBRATION INSTRUCTIONS- INCLINE
    1) Press the Stop and the Speed Up keys down while inserting the safety key.
    2) Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test.
    3) Press either incline key and the incline will calibrate automatically.
    4) THIS IS A VERY IMPORTANT STEP BECAUSE YOU WILL GET AN ERROR MESSAGE IF THIS STEP IS SKIPPED.After completing calibration of incline, press the Stop key and then remove the safety key.
    If the incline moves but you it will not operate normally nor calibrate, check the wiring from the incline sensor to the power board. If all looks normal, put it back in calibration and see if you see a blinking “- -” symbol in the incline window when you are calibrating. If not, the incline sensor is bad.
    If the incline moves but only just a bit, it could be a problem as simple as the gearbox on the motor being jammed. We remove the motor from the treadmill, reconnect the wiring, and then try to run the incline motor outside the treadmill. Many times, this will unjam it if that is the problem and then reinstalling it in the treadmill will get it to work. If you have the same problem or it doesn’t run outside the machine and you can hear it try to work, you need to replace the incline motor.
    If the incline motor does not move, we need to figure out if the motor is getting voltage. Use a simple multi-meter and set it to AC volts. When you put it into calibration, it tries to calibrate the directions one at a time. Measure across the white and black wires first, then measure across the white and red wires second. If the motor is getting voltage you will read 120VAC (or
    thereabouts) one one of the measurements. If you have voltage but the motor won't move, you need to replace the motor.
    4.
    If the incline motor does not move and you have done the voltage test and you do not have any voltage present, there is a problem in the electronics board that supplies the power. If the console is powering the drive motor as normal, you can bet it is getting an incline signal and the power board needs to be replaced (some models have an integrated power board/controller) so if there is only a single board the whole board has to be replaced. It is possible the console is not giving the proper signal but we've never seen it happen in thousands of treadmills.
    Jul 09, 2010 | Proform 650 Crosstrainer Treadmill
    I have a proform xp 580. when I turn it on,
    Jun 12, 2010 | Proform XP 580 Trainer Treadmill
    When you turn on treadmill the incline goes all the way up and all the way down. Does nothing else.
    First we need to do a calibration follow this procedure
    THIS IS A VERY IMPORTANT STEP BECAUSE YOU WILL GET AN ERROR MESSAGE IF THIS STEP IS SKIPPED. After completing calibration of incline, press the Stop key and then remove the safety key.
    If the incline moves but you it will not operate normally nor calibrate, check the wiring from the incline sensor to the power board. If all looks normal, put it back in calibration and see if you see a blinking “- -” symbol in the incline window when you are calibrating. If not, the incline sensor is bad Call icon Fitness @ 800-999-3756, they may have the sensor or they tell you, you need to replace the incline motor
    May 29, 2010 | Proform 675 E Treadmill
    I have a Image 15.5 Treadmill, it turn on, Incline...
    If the incline moves but you it will not operate normally nor calibrate, check the wiring from the incline sensor to the power board. If all looks normal, put it back in calibration and see if you see a blinking “- -” symbol in the incline window when you are calibrating. If not, the incline sensor is bad call icon Fitness @ 800-999-3756, they may have the sensor or they tell you, you need to replace the incline motor
    May 21, 2010 | Icon Image 17.5 S Treadmill
    When I turn on the treadmill, the incline is stuck @ 12degree and the console beeps and I can not control the treadmill at all. What do I need to do?
    1) Press the Stop and the Speed Up keys down while inserting the safety key. If this doesn’t work, click on the help topic entitled “Alternate Calibration Codes” for key sequence instructions to enter calibration.
    4) THIS IS A VERY IMPORTANT STEP BECAUSE YOU WILL GET AN ERROR MESSAGE IF THIS STEP IS SKIPPED. After completing calibration of incline, press the Stop key and then remove the safety key.
    1. If the incline moves but you it will not operate normally nor calibrate, check the wiring from the incline sensor to the power board. If all looks normal, put it back in calibration and see if you see a blinking “- -” symbol in the incline window when you are calibrating. If not, the incline sensor is bad.
    2. If the incline moves but only just a bit, it could be a problem as simple as the gearbox on the motor being jammed. We remove the motor from the treadmill, reconnect the wiring, and then try to run the incline motor outside the treadmill. Many times, this will unjam it if that is the problem and then reinstalling it in the treadmill will get it to work. If you have the same problem or it doesn’t run outside the machine and you can hear it try to work, you need to replace the incline motor.
    3. If the incline motor does not move, we need to figure out if the motor is getting voltage. Use a simple multi-meter and set it to AC volts. When you put it into calibration, it tries to calibrate the directions one at a time. Measure across the white and black wires first, then measure across the white and red wires second. If the motor is getting voltage you will read 120VAC (or thereabouts) one one of the measurements. If you have voltage but the motor won't move, you need to replace the motor.
    May 15, 2010 | Epic View 550 Treadmill
    How do I fix my Endurance Treadmill TF3i Err7 problem? I stopped during operation.
    Unplug unit remove motor shroud check connections on lower board (incline board). I believe their is a 3 amp fuse in circuit check with multi meter to see if open replace fuse power up unit and if it blows the fuse then replace incline motor and if not, then use engine mode press stop then Incline + or - to force incline up to max incline then bring it down to 0 then turn off power then wait 10 seconds then hit power on then if error does not appear then hit start and resume using unit. If the procedure above does not activate unit then replace board.
    Apr 15, 2010 | Endurance T3 Treadmill
    Proform 550xp Treadmill in continuous incline/decline mode!!!
    i just called the manufacturer on this and found out i have a faulty control panel, but these are the steps they told me to go through to reset. If it works, then you are good, if not, you may also have a control panel issue.
    1. plug in and turn on treadmill, keep red key out
    2. press and hold the stop button and speed up button at the same time and hold them while you insert the red key
    3. after red key is inserted, let go of both buttons
    **CAUTION - be sure to stand on side bars of treadmill, clear of the belt for this next part bc it will go VERY FAST***
    4. press stop button once
    5. press speed up button until it reads 85 (see what i mean?!)
    6. press stop button once
    7. press incline down or up one time and it should get back into normal mode. mine just started a series of flashing lights and "8"s in all the "windows" so my panel needs to be replaced. here is the number i called - 1-877-993-7999. Good Luck!
    Dec 30, 2009 | Exercise & Fitness
    Ifit treadmill will not incline but everything else works, how do I fix the incline
    You may need to calibrate the incline. Do this with the following procedure.
    Safety key out
    press the stop and speed up buttons at the same time while inserting the safety key. (you are now in diagnostics)
    press the stop button one time only.
    now press the incline up button (incline motor should start moving up)
    incline will go up to the top and then all the way to the bottom. when it gets done you can remove the key. Reinsert the key and you should be operating normally.
    Good luck Tim
    Nov 23, 2009 | Proform Quick Burn Pro Treadmill with 12...
    Pro-Form Sport 1000 treadmill does not stop inclining
    Do a Calibration on the treadmill. Take out the safety key. With 2 fingers, hold down the stop button and the speed up or spped plus button. keep holding them down as you insert the safety key, then let go of both.
    Press the stop button 1 time, you should see all 0's in the windows, or EP 2P or something weird like that.
    Press the Incline up button and then wait. If the incline go up until it stalls then down until it stalls the stops at the bottom, the you are recalibrated, take out the safery key and put it back in to see if all is well. If the incline takes off up again without touching a button, the you have wiring problems or control problems. Call service company to get it repaired.
    Apr 27, 2009 | Proform Sport 1000 Folding Treadmill...
    Tunturi T30 Programmable Treadmill Logo
    162 people viewed this question
    Top Tunturi Exercise & Fitness Experts
    Electro Med Services...
    Shehu Pro
    Shehu Pro
    Are you a Tunturi Exercise and Fitnes Expert? Answer questions, earn points and help others
