Question about Vivitar ViviCam 8018 Digital Camera
Settings change everytime i power on/off
Why is it that everythime i turn the power off the settings change back to factory settings, i dont want it to be at 3 mega pixels everytime i turn it on, is there anyway i can save the settings so it stays the same when i turn it on/off
  • techno_panth May 19, 2010
    tried looking at the manual was the first thing i tried still nothing works
    it saves when i change the resolution but when i turn the power off it goes back to 3megapxels....stupid camera
    Guru:
  • 1,705 Answers
The user manual can be down loaded for free from here:-
http://www.vivitar.com/products#Digital%20Cameras/24/12/Support
Page 16 refers to picture resolution, apparently once you've chosen the resolution you require you have to
"3. Press the Up/Down button to select the desired image size.
4. Press the Menu button to confirm, save and exit to standby mode".
Posted on May 02, 2010
  • dgsturt May 19, 2010
    Then a stupid camera it is......................My only other thought is go back to Vivitar via the URL above, and use the "Contact" link to ask their techs why the camera doesn't do what its supposed to and what do they propose to resolve the problem.
    If there's been a whole bunch of your camera model with the same problem, they probably know all about it.
My sons friend changed his password and everytime I go to reset it it just turns off. How do I reset?
  • First, switch your tablet off.
•Then, power the tablet back up by holding down the volume (either + or - ) and power buttons simultaneously.
• Continue holding the volume button until the screen says "Booting tablet in recovery mode."
• This will give you a picture of an Android.
•Tap the android, and you will be given a screen with several options.
•Move between the options with the + and -, and select with the power button.
•Go to the option for Factory Data Reset and select it.
•Scroll down to `the Yes, and then the tablet will erase its memory back to factory settings.
•Once it has completed, select Reboot Tablet Normally.
Aug 29, 2015 | Craig CMP741d Tablet
Memory
u probably didnt connect the wires right or got them mixed up...the red wire should be connected to the switch wich means there should onle b power when the key is turned on and ur yellow to constant if u got both yellow and red to a switch power the memorry wnt store and thats why everytime u turn it off it goes back to factory settings ....
Jan 04, 2014 | Sony MEX-BT3100P - radio / CD / MP3 player
Emerson Microwave MW9325SL
Failed magnetron or power supply.
Aug 12, 2017 | Microwave Ovens
I have sony DSC-W190,i want correct menu setting ,bcos if i take a picture its not clear,i think may be menu setting changed,idnt any idea about menu setting pls help.....
If the Menu settings in the camera is changed, then I suggest you to reset the Camera back to factory default. Initializing the Camera back to factory default will set all the settings in the Camera back to factory default.
To initialize the Camera back to factory default, select the INITIALIZE Option from the Main Settings 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
You can also try a manual reset;
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
The blurry image capturing can also adjusted by changing the ISO Settings or the Scene Selection modes.
Thanks for using FixYa!
Apr 07, 2011 | Sony Cyber-shot DSC-W190 Digital Camera
The problem with my laptop is that I rebooted the computer and everything went back to factory settings, I cannot link up with internet using wi-fi capabilities, I press the wi-fi button on the right of...
What do you mean went back to factory settings? Are you referring to the bios settings? Or other else? If you are referring to the bios settings, and everytime you change the bios and rebooted, then back to factory settings then your problem maybe the cmos battery. You can change it and try if everything works fine. And maybe you can't connect using wifi because it is disabled in the bios settings or if not you got a defective wireless module. Hope this will help pal. Maybe you should elaborate your situation more detailed as what is really happening to your laptop,
Aug 29, 2010 | Acer Aspire 5735 Notebook
MOTOROLA W376G...turn off phone on ringtone
Hello!
Set phones ring style as "Vibrate then Ring" , "Vibrate" , or "Silent" to avoid the power on alert.
I set my ring style to "Vibrate then ring" so that I dont have to change the settings everytime I turn it on or forget to so when I receive phone calls or alerts it still rings & then I dont have to go back and change the settings again when I turn tha phone off so that is dosent have the power on alert.
This is the Only way I have found to turn the phone power on tone/alert off.
Change Ring Style:
-Go to Main Menu
-Settings
-Select Ring style
-Then choose change, & set it to the ring style you want.
Feb 21, 2010 | Motorola Mobility W376 Cell Phone
Philips HTS3555 custom settings reset to factory on its own
this happens when the electricity is fully discharged
May 17, 2009 | Philips HTS-3555 System
When you turn it on it freezes and doesn't take any commands
plug it to the computer
hold down the power button on the mp3 player for 10 seconds.
Go to the RCA web site and download the firmware.
Keep it plug into the computer and install the firmware.
Should work like new. (if you choose format it will erase everything and be back to factory settings)
Dec 10, 2008 | RCA M4204 MP3 Player
Video settings reset everytime I turn off TV
Hit the menu button on the remote. Click on Setup. Then click on Set The Quick Start Options. Make sure it is on. That should solve your problem.
Jan 15, 2008 | Hitachi P42H401 42 in. Plasma HDTV
Tear off
First, if you have your manual, look it at for possible solution. Does this printer have a "load" or "top of form" function? There may be a "programmable" setting which will back the paper back down to the correct spot. The college where I'm employed used to have several Panasonic dot matrix printers, but almost all are now long gone.
Sep 18, 2007 | Panasonic KX-P1150 Matrix Printer
Vivitar ViviCam 8018 Digital Camera Logo
136 people viewed this question
Top Vivitar Cameras Experts
Tony
SHARCNET-USA
SHARCNET-USA
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
