Question about Smeg 18 in. STX45-1 Stainless Steel Built-in Dishwasher
My dishes are still wet after the cycle has finished why?
  • Smeg Master
  • 19,396 Answers
Hi.
Ensure that there is no water at the bottom of the tub. If there is water, check drain well and drain hose, then test pressure switch in the drain system.
If there is no water, the the thermostat (or the dryness) sensor must be replaced.
In that case, cintact Smeg at the number listed on the owners manual.
Regards.
Posted on May 02, 2010
Dishwasher washes dishes but does not dry even though that display shows dry icon
First ,Check for a water puddle on the bottom of the dishwasher .If you have water there, you more than likely have a plugged drain or drain hose, or bad drain pump (less likely) If no water is there see if the dishes are hot after a cycle. If they are not you could have a bad heater (that circular thing on the bottom of the dishwasher) other problems could be the timer or computer Depending on the model brand and age of the dishwasher .One last thing there is a vent to let moisture escape that could be bad but then you would have hot wet dishes
Aug 07, 2014 | Blomberg Dishwashers
Ld 14aw3
Most dishes in any dishwasher are still wet when cycle is finished. The heat built up in the dishes during the washing cycle is what causes the water to evaporate when the machine stops.
If you want to accelerate the evaporation, simply open the door very slightly so that as the hot air escapes it causes the dishes to dry quicker.
Aug 04, 2014 | LG Dishwashers
Dishes still wet upon end of cycle
Check if the heater is working. This can be done by checking if the dishwasher has steam and dishes are warm when cycle is complete. Also check if the Rinse aid has not finished. Make sure the Rinse aid dosage is not at too low.
Jul 31, 2014 | Electrolux Dishwashers
Whirlpool dishwasher is not drying the dishes
sounds like your heating element is not working. It may be faulty.
May 01, 2012 | Whirlpool Dishwashers
The dishwasher dose not get hot at all and when it has finished washing every thing is still wet
  • Well, the dishes inside the dishwasher will still be wet unless you use a dry cycle at the end of the washing cycle. Not all dishwashers have this option. Even though mine does I rarely use it as the dishes will dry on their own in two hours.Saves a little money. Even when washing on a normal cycle the dishwasher itself should not get hot. It may blow a little steam out the front vent. Hope this helps.
Regards, Tony
Jun 08, 2011 | Dishwashers
Dish feels hot but not drying
sounds like your heating element is not working prtoperly or you are not washing in very hot water stop washer in middle of cycle and open it if steam come out hot steam be careful keep face away when you open itif not hot that could be the problem,A appliance serviceman once told me if water is hot enough and end of wash and rinse cycle not to run the dry cyvcle just open dryer a few inches and let the steam out Run hot water over a plate or a pot and set it in the drain tray in your sink notice how fast it dries itself while draining in the tray very hot water in a dish washer dopes the same good luck with this problem I hope my advice helps you oh yes one more thing always run the hot water till it get hot before you turn your dishwasher on
Dec 15, 2009 | Kenmore Dishwashers
Frigidaire dishwasher - no heat coming on to dry the dishes
Did you ever learn why the heat was not drying dishes? We have the same problem.
May 18, 2009 | Electrolux Frigidaire Professional Series...
The dishes don't get dry enough
I was able to fix this by using rinse during the cycle.
Nov 11, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Smeg 18 in. STX45-1 Stainless Steel Built-in Dishwasher Logo
242 people viewed this question
Top Smeg Dishwashers Experts
Cleverer2
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
