Question about Canon PowerShot A620 Digital Camera
How do you replace the lens cover for the Canon A620.
My nephew broke the lens cover. So parts of it are missing and now I get a shadow on the left bottom corner of pcitures. I am going ot order a new lens cover, but not sure how to install it. Suggestions.
  • Canon Master
  • 4,738 Answers
This blog post outlines repair procedures for stuck lens covers. An A400 is used as an example. But for the A620, you might want to extend your zoom all the way out before removing the camera's batteries. Also you'll be applying the ring loosening rubbing alcohol around the barrel's perimeter instead of the front as shown in the procedures.:
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Posted on Jun 04, 2008
2 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 46 Answers
SOURCE: How do you replace the lens cover for the Canon A620.
Dear OzWiz,
As I have seen several times in these forums, digital camera owners often elect to order camera parts in order to save money on repairs but then they do not know how to procede properly from there.
Though it may seem a simple matter (and indeeed may be) digital cameras can be complex mechanisms and they are very small, often requiring specialized tools. To make matters worse, Canon does not offer ANY instructions or technical support with these parts. Thus you are on your own in installing them.
If you know you are capable then by all means make the repair and save yourself some $$ in the process. If you are at all unsure how to procede however I would leave the repair to a trained technician - either at the Canon Factory Service Center or at another camera shop.
Based on my experience, however, local shops typically charge from 50% to 100% more for repairs than the Factory Service Center (FSC) does. And lastly, if you cannot repair the item on your own and have to ultimately send it in to the center for a repair, you will end up wasting money on the part as it is FSC policy not to use customer purchased parts.
So think about it carefully before you make your final decision. If your camera is out of warranty you might be better off taking advantage of Canon's Loyalty Program which offers upgraded refurbished cameras at discounted prices as an alternative to fixing your camera. For certain models the upgrade price is lower than the repair cost. If you haven't done so already, call Canon's Tech Support at 1-800-828-4040 and see what your full range of options may be.
Hope this helps.
Sincerely,
HeavyDLB
Posted on Jun 01, 2008
Accidentally pushed lens closed - now stuck, nearly closed with 'on/off' light flashing.
know try to pull the lens slowly may be it work if not then you have to DI-assemble and fix it on wright place the gear or lanes was miss place
Sep 27, 2011 | Canon PowerShot A620 Digital Camera
Lens Shutter Don't Close
This blog post outlines repair procedures for stuck lens covers. An A400 is used as an example. The A620 is more complex, but still similar enough. As recommended in the post, try the simpler fixes first before attempting:
Dec 26, 2008 | Canon PowerShot A620 Digital Camera
Lens cover will not close
YES, BUT THAT IS A JOB THAT NEEDS TO BE DONE PROFESSIONALLY, DUE TO THE ALIGNMENT OF THE LENSES AND THE POWER DRIVE FEATURES. IF YOU GOOGLE CANON POWERSHOT A620 REPAIR SERVICE, YOU SHOULD BE ABLE TO GET A PRICE QUOTE BEFORE YOU SEND THE CAMERA IN FOR REPAIR. IS IT JUST THE COVER THAT NEEDS REPLACED OR THE LENS? THE COVER MIGHT JUST NEED TO BE CLEANED GOOD WITH AIR TO START WORKING AGAIN? WORTH A TRY. IF I CAN HELP MORE, REPLY TO:
ARCLIGHT1217
Sep 15, 2008 | Canon PowerShot A620 Digital Camera
Canon PowerShot A620 Photos have shadows
I was having this problem and found I was placing finger to close to the flash when I was steading the camera.
Aug 23, 2008 | Canon PowerShot A620 Digital Camera
Dear OzWiz,
Hope this helps.
Sincerely,
HeavyDLB
Jun 01, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
My PowerShot A620 lens isn't working
Don't even try unless you know what you are doing - you can get a nasty belt off a charged flash capacitor (around 300volts) - the lens is more than likely clogged up with sand, this will wear the sliding tracks in the zoom very quickly and will render it useless.
You can buy new lens assemblies (Colchester Camera Repairs) but the cost will be high, around £80.00 just for the part.
Jan 01, 2008 | Canon PowerShot A620 Digital Camera
SHUTTERS AREN'T FUNCTIONING PROPERLY
Repair costing close to half the price of new camera is uneconomical. And unfortunately if it is the shutter ( which seems questionable and sounds like the lens unit has sand inside and canon want to replace it ) you will not be able to do this yourself. Buy a new camera.
May 09, 2007 | Canon PowerShot A620 Digital Camera
My lens cover can't open and close completely.
Have you tried Canon customer support? If the camera is new[ish] you may get it fixed under warranty. A repair price will be high. You could just gently push it back. Or compose your picture to miss that side of the image
Jan 04, 2007 | Canon PowerShot A610 Digital Camera
Canon PowerShot A620 Digital Camera Logo
693 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
