Question about Intertherm P3RA-048K Air Conditioner
Heat want shut off
Its summer heat want shut off
  • 674 Answers
I am assuming you mean it will not shift from heat to A/C. This could be because of a stuck reversing valve. You can tap it lightly!!! on either end but not on the side because if you dent it, it will for sure be stuck then. This could also be due to a low refrigerant charge and it just isn't cooling.
Posted on May 04, 2010
Heat will not shut down, continues to get hotter
there might be a broken hot water pipe somewhere and so that might be causing the heater to stay on as its not getting to temperature.
Sep 26, 2016 | Water Water Heaters
I have a Summer Escapes 18 x 42 metal fram pool. This is my second season using it and the pump was stored over the winter. It's been working fine for the past 3.5 months. I only use it during the day and...
Wall Mounted motor? that's a new one for me.
All the same check the vents on the motor and make sure they are not clogged or blocked.
Is the motor loud? if so it's your bearings
Are you getting proper voltage?
Aug 12, 2013 | POLYGROUP LIMITED Summer Escapes - 24x52"...
I can't find the summer switch on my furnace model FG6RA 072C-12A
there isn't a summer switch - the thermostat will switch the operation from heat/winter operation to cool/summer operation. I.E. "Cool" for Summer and "Heat" for Winter.
Aug 05, 2011 | Heating & Cooling
We just purchased a home with a beckett heater. we cant stop it from heating the house, it is 80 degrees in here and the heater is off! its burning up oil like crazy but we are only in need of the hot...
Terry, most units like yours had a Winter and Summer setting. It should be located on the furnace itself. In the Summer mode, only the water is heated for domestic use and the furnace side of the system is shut down.
Apr 05, 2011 | Heating & Cooling
Heater still lets out heat
Hi, if you can't find the pilot shut off, all wall heaters have a gas line that supplies gas to it, the main line at the unit. There should also be a gas flex line going to it. It will have a valve on it to shut gas down to the unit for the summer. This will solve your problem. You will have to look for it, as it may be hidden from site for looks and decoration. You will find it.
Sincerely,
Shastalaker7
Heating Contractor.
Please be kind when rating. Thank you, I know you will.
Jul 15, 2010 | Williams 3003622 Ceramic Wall Mounted...
Hitachi 51F500 Shuts down during summer months
I am finding out that these sets have almost the same problems mostly going back to middle power supply broad ck all connections,then try looking for leaky caps.
Nov 08, 2007 | Hitachi 51F500 51" Rear Projection...
Intertherm P3RA-048K Air Conditioner Logo
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Dan Webster
Dan Webster
Bill Long
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
