Question about Nokia Cell Phones
New nokia 7230 won't connect to Jabra bluetooth headset
I just set up my new Nokia 7230, and it refuses to connect to - or even 'see' - either of the Jabra Bluetooth headsets I've been using with my Nokia 6288. And yes, i did RTFM :D I've set the various connectivity options to detect Bluetooth devices and I've connected Bluetooth headsets to Nokia phones before and never had any problem. FWIW the 7230 did 'see' my desktop Bluetooth dongle, but refused to pair and now doesn't even 'see' the 'puter. Help!
p.s. If this is a new Nokia thing, e.g. that the phone will only recognise a branded Nokia Bluetooth headset, I'll be furious. I've used Nokia phones for 15 years now with no problems before.
trillian_tx
  • 4 Answers
SOURCE: bh 101 bluetooth headset lost manual and forgot pairing code
Try this: 1. Ensure that your phone is switched on. 2. If the headset has not been previously paired with a device, switch on the headset. The headset enters the pairing mode, and the indicator light starts to flash blue quickly. If the headset has been previously paired with another device, switch off the headset, and press and hold the multifunction key until the indicator light starts to flash blue quickly. 3. Activate the Bluetooth feature on the phone, and set it to search for Bluetooth devices. See the user guide of your phone for instructions. 4. Select the headset from the list of found devices. 5. Enter the passcode 0000 to pair and connect the headset to your phone. In some phones, you may need to make the connection separately after pairing. You only need to pair the headset with your phone once. If pairing is successful, the headset appears in the menu of the mobile phone where you can view the currently paired Bluetooth devices. When the headset is connected with your mobile phone and ready for use, the indicator light of the headset slowly flashes blue.
Posted on Apr 14, 2009
MonsterG
  • 52 Answers
SOURCE: pairing Jabra BT135 with motorola L2
okay, try this, turn off the jabra headset, and then, hold the power button but hold it down until the lights flash in a different way, and make ur phone search for devices and if it finds it then its all good, just use the 0000 password to pair it.if this works give me a fix rate. thank U
Posted on Feb 11, 2008
SOURCE: no connection withe nokia HS-36W bluetooth headset
go into the bluetooth menu, with phone bluetooth on.
next, select paired devices, select new.
now the headset hold the volume + and - at the same time to re-set the headset, NOT the phone + and - / the headset only
this will re-set the headset and paired it to the new phone.
Posted on May 19, 2008
SOURCE: How to use Jabra BT5010 with 2 mobile phones
how to activate bluetooth jabra
Posted on Jul 05, 2008
SOURCE: Pairing my Motorola Razr with my Motorola H12 Bluetooth Headset
I have an old Motorola H12 Bluetooth I am trying to reactivate and cannot locate the manual. I need the passkey to reactivate.
Can you help me?
Posted on Nov 11, 2008
I paired my jabra bt 2015 with my mobile N91 NOKIA then i bought a new mobile nokia 5530 xpress music i can't pair it with the new mobile why ??? please help me
Go to Jabra site to confirm compatibility:
http://www.jabra.com/sites/mobile/ap-en/products/pages/jabrabt2015.aspx?submit=y
It says that they are compatible.
Dec 21, 2010 | Jabra Bluetooth Headset with Adjustable...
I have a plantonics voyager pro. It won't pair with Nokia 7230. How could I solve? this problem? Serra
Check First If it Compable with Your Nokia 7230... From the net type Bluetooth programmation with Nokia 7230... Then Read Instruction., Good Luck
Oct 09, 2010 | Plantronics Voyager PRO Bluetooth Headset
Got a new Nokia and need to connect it to my Jabra
Go to this site, and it will walk you through each step to connect your particular Jabra headset with your cellphone. Choose the headset, and then at the next page, choose your phone. Moving your mouse over each step will change the picture to what you should be seeing on your phone at each step.
http://jabra.pairx.co.uk/ Pls come back and let us know if this solved your problem.
Oct 22, 2009 | AT&T Nokia 6555 Cell Phone - Black
I cant pair my jabra bt125 with my nokia n97
This is one of the mistake commonly done by many people. First you need to pair. Let me walk you through. First, the headset has to be switched to pairing mode which is done by holding the on button for a while even after the headset is switched on. Then the bluetooth headset light will remain on. You switch on the phone bluetooth, search new device. Then select it and press the option for pairing. Read the instructions which come on the phone display and select accordingly. It will ask for passcode which is usually four zeros. Then it will get paired ask you whether to connect. You select connect and you are done.
Sep 02, 2009 | Jabra BT125 Headset
How To pair Jabra A125s with Nokia BH-604 bluetooth headset ?? Need Help !!!
Turn ON the bluetooth headset (keep the button pressed for few seconds) and bluetooth connection of your Nokia phone. Search for the device from your phone, when found enter the pass key "0000" (its default) when prompted, set this device as authorized to pair it.
Jul 02, 2009 | Jabra BT125 Headset
How to disconnect bluetooth headset from a lost phone
I bought a Jabra Bluetooth headset, It worked fine with my phone(nokia). I lost my phone now. Now i want to use the same headset with my new phone (huawi), but i am unable to connect it to my new phone as the phone is already paired with my previous phone. So please help me with the issue and tell me is there any way i can disconnect the bluetooth headset from my previous phone??
Jun 04, 2009 | Jabra BT125 Headset
Be careful of the earhook Jabra does not offer a replacement in the BT5010
Dec 07, 2007 | Jabra BT350 Bluetooth Headset Headset
Connection prob
Brand New Jabra -BT350 won't work on my Nokia 6102i, I did everything in term of setting my phone properly to paired with the Bluetooth, My Phone Bluetooth light is on, and the device blue light is flashing as well, but it still doesn't work. the phone would ring, I hit the JABRA button to answer it.....still can't answer my phone... Please send your help to me at jjkernaud@hotmail.com
thank you all.
Nov 08, 2007 | Jabra BT350 Bluetooth Headset Headset
My Jabra BT160 won't connect to my Nokia 6103 why?
hold the on/off button and the + button for 2 min. If you fail at the first time. Try again, until you see the blue solid light. Search again in your phone, you should see Jabra bt160. Enter 0000 at the passcode. Good luck
Nov 07, 2007 | Jabra BT160 Wireless Headset
Cell Phones Logo
297 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
