Question about Motorola Mobility RAZR V3
Everytime my phone is open it randomly types digits and switches the volume up and down without me pressing anything. It also stops me from accessing anything on my phone- however when i flip my phone shut it is fine. I have tried to turn it off multiple times and also take out my sim card and battery but nothing has worked!
  • Motorola Mob... Master
  • 641 Answers
It sounds to me like one of the smart keys on the screen side of the phone is sticking or stuck,there are 4 screws (very tiny) that hold the back cover on the screen,you can remove them and carefully snap the cover open,make shure the battery is removed ,then use a good electronic cleaner or better yet a can of air that is used for cleaning a computer,try and clean the buttons and the switches inside.. i hope that works for you
Posted on May 02, 2010
  • 4,737 Answers
Yes Tickets1 is right about the problem and how to make it work, but in rare case, the cabinet (Mobile Body) also makes this problem when it isn't fit with. If several keys are just typing themselves automatically, you can try changing the cabinet, if in case Ticket1's isn't solve this problem.. Good luck...
Posted on May 03, 2010
Unlock screen on lgl34c
when ever you forget the
pattern lock and can't access the
phone, below is a step by step guide
on how to reset it.
1. Switch off the phone by pressing and holding the power button.
2. Now, press and hold the power button and the volume down button
(Power-on + Volume down button)
together until the phone has power on.
3. On the next screen that shows up, you should see about four ( 4 ) options, scroll down to "Factory Reset" or "Clear Flash" and select it. (Use the " Home button" or Switch button to select).
4. On confirmation, the factory reset process begins immediately. And,
when the process completes, the
phone boots up without the pattern security lock.
TIPS: For navigation purpose to explore
other options on the screen, you can
use the (Volume Down key) to
navigate down, the (Volume Up Key)
to navigate up and the (Home Key)
to select the option you want, you can use (Switch button) to select in some android phones
Nov 01, 2014 | Cell Phones
How to reset a windows phone
Try these fixes if, for example, your phone randomly reboots, freezes or does not switch on, if an app crashes, if you have sound problems, or if the screen is blank:
1. Restart your phone.
Press and hold the Power and Volume Down keys simultaneously for 10-15 seconds. Release and the phone will restart. After this operation, you may need to set the date and time on the phone.
If the problem persists, reset and restore your phone as instructed below.
2. Reset and restore your phone.
Important:
  • This erases all personal content on your phone and restores the factory settings.
  • Before continue with the reset, make sure your phone's battery level is above 50%. To check the remaining battery life, go to Settings > battery saver. If you are not able to check it, or the level is too low, charge your phone for at least 20 minutes.
Reset your phone by using the built-in option in the phone settings. Select Settings > About > Reset your phone.
However, if you cannot access the phone settings, follow the steps below:
a. Disconnect the charger. Press and hold the Power and Volume Down keys simultaneously. Release the pressed keys when phone vibrates and then immediately press and hold the volume down button until the phone displays an exclamation mark (!) on the screen. Release the volume down key.
b. Then press the volume and power keys in the following order: volume up, volume down, power, and volume down.
c. Wait for your phone to reset, during the reset you will see gears rotating on the screen for up to 5 minutes, after which the screen goes blank for ~30 seconds and then your phone will restart.
d. Go through the initial phone setup. Make sure that you have the date and time set correctly on your phone (Settings > date+time).
Sep 02, 2014 | Nokia Cell Phones
Tracfone customer service
  1. Check a ringer volume and profile. Press a volume key to see the volume status bar at the top of the screen. Use the volume up and volume down keys to adjust the loudness of the ringer (scale 0 to 30). Tap on the text next to the ringer icon to change the profile (vibrate only, ring+vibrate).
  2. Check if the issue is with a specific ringtone: Go to Settings > ringtones+sounds > Ringtone, and tap on a playbutton to preview the ringtone.
  3. Switch off the ringer vibration (Settings > ringtones+sound > vibrate) temporary, to determine if your phone is affected by any motion settings i.e. Flip-to-Silence.
  4. Make sure that call forwarding is not switched on: Tap the phone icon > ... > Settings.
If the problem persists, restart your phone by pressing and holding the power and volume down keys simultaneously until the phone vibrates. Release and the phone will restart. After this operation, you may need to re-adjust the volume and set date+time on the phone. Note that this does not remove your personal content.
Mar 13, 2014 | Computers & Internet
Power button wont turn
Soft reset by removing the battery, wait 20 seconds and reinsert.
If this does not solve the problem...
1. Remove the battery, wait for a few seconds, then reinsert the battery to turn off your Merge.
2. Press and hold the VOLUME DOWN button, and then briefly press the POWER button.
3. Wait for the screen with the three Android images to appear, and then release the VOLUME DOWN button.
4. Press VOLUME DOWN to select FACTORY RESET, and then press the POWER button.
If none of this works, get a new phone, hopefully you have the insurance.
Dec 17, 2013 | HTC Cell Phones
Akai service centre thane
  1. Remove battery.
  2. Place in again.
  3. Press volume-up and switch on buttons.
  4. Make your choice from recovery menu by pressing volume button up or down.
  5. Press "menu" (second from the left) icon.
Oct 26, 2013 | Computers & Internet
Why does my htc wildfire randomly shuts off and on ?
Try to reset it and see if it fixes this problem but backup your data before doing this.This process will erase everything.
Performing a factory reset via settings
  1. Press HOME > MENU, then tap Settings.
  2. Scroll down the screen, and then tap Privacy > Factory data reset.
  3. On the Factory data reset screen, tap Reset phone, and then tap Erase everything.
Performing a factory reset using phone buttons
If you cannot turn on your phone or access the phone settings, you can still perform a factory reset by using the buttons on the phone.
  1. With the phone turned off, press and hold the VOLUME DOWN button, and then briefly press the POWER button.
  2. Wait for the screen with the 3 Android images to appear, and then release the VOLUME DOWN button.
  3. Press VOLUME DOWN to select CLEAR STORAGE, and then press POWER.
  4. When asked to confirm, press VOLUME UP.
Mar 14, 2011 | HTC Desire Cell Phone
My HTC G1 phone has been acting up for some time now. It just randomly shuts off. Last night I decided to try it again and it lasted through the whole night but then when i woke up in the morning I looked...
FOR HTC wildfire
Do a hard reset:
Please note that all data will be deleted from the HTC Wildfire as a result of this procedure. This process does NOT delete data stored on the microSD card. We recommend backing up all of your personal data before proceeding.
1. Turn the power off. If your HTC Wildfire is frozen, pull the battery out and reinsert it
2. Hold the Volume Down button
3. Press and release the Power button
4. You are now presented with a menu that allows for Fastbook, Recovery, Clear Storage, and Simlock
5. Select Clear Storage by pressing the Volume Down button
6. Press and release the Power button
7. Now simply confirm your decision: Volume Up for YES and Volume Down for NO
If you selected YES, all data including third-party applications will be deleted from the HTC Wildfire.
Once the wipe is complete, the phone will reboot to its factory fresh state.
Jan 04, 2011 | HTC G1 Smartphone
My blitz's speaker phone wont work. and the open/close, on/off, and ringtones, wont work... help! ive gone thru all sound settings and everything is "on" i can hear my calls thru the regular handset...
Try these couple of things:
The speakerphone feature lets you hear audio through the speaker and
talk without holding the phone.
  1. To activate the speakerphone while in answering or calling modes,
    press the Navigation Key to the right.
  2. The phone returns to normal (Speakerphone Off) after ending a call
    or when the phone is turned off and back on.
To adjust the ringer, key tone, voice call and speaker phone volume levels:
1. Press left soft key [MENU] (7) (1) (2).
2. Select the type of volume you wish to adjust.
3. Select the desired volume level.
4. To confirm, press OK.
Let me know if this works for you or if I can help you with anything else.
JimmyC
Jun 13, 2009 | UTStarcom Blitz Cell Phone
Computer just shuts down
Run an Error check on your computer. Process takes anywhere from 1 to several hours, depending on hard drive size, files on computer and number of errors needing to be fixed. Manual steps to run Chkdsk at the command prompt loadTOCNode(3, 'moreinformation');
  1. Click Start, and then Run.
  2. In Open, type cmd, and then press ENTER.
  3. Use one of the following procedures:
    • To run Chkdsk in read-only mode, at the command prompt, type chkdsk, and then press ENTER.
    • To repair errors without scanning the volume for bad sectors, at the command prompt, type chkdsk volume:/f, and then press ENTER.
      Note If one or more of the files on the hard disk are open, you will receive the following message: Chkdsk cannot run because the volume is in use by another process. Would you like to schedule this volume to be checked the next time the system restarts? (Y/N)Type Y, and then press ENTER to schedule the disk check, and then restart your computer to start the disk check.
    • To repair errors, locate bad sectors, and recover readable information, at the command prompt, type chkdsk volume:/r, and then press ENTER.
Jun 04, 2009 | Acer Aspire RC500 PC Desktop
I'm locked out of my phone, I forgot my password and there is no way for me to get my numbers or anything out. What should I do?
u can try factory reset the device like this but all data will be wiped off pls active sync ur device and backup ur data then try this
To perform a hard reset
1. Pull out the stylus.
2. With the device turned on, press and hold the VOLUME DOWN and
ENTER buttons, then press the RESET button with the stylus tip.
3. Release the RESET button, but continue pressing the VOLUME DOWN and ENTER buttons until you see a message on the screen for the confirmation
4. Release the VOLUME DOWN and ENTER buttons, then press the
VOLUME UP button to perform the hard reset, or press any other
button to cancel the reset.
if it doesnt help then u can upgrade ur ROM from www.HTC.com and it will also solve ur problem
pls rate me FIXYA
Mar 08, 2009 | HTC Touch Diamond Smartphone
Motorola Mobility RAZR V3 Logo
133 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
