Question about Vacuums
Hoover spin vac wont **** up the dirty water!
  • 126 Answers
Check the lid on the dirty water tank. This is a very common problem. If the lid is not engaged in the tabs of the tank, the lid will not sit down properly and all the suction will leak out between the lid and tank.
Posted on Mar 30, 2008
reddevil6
  • 1673 Answers
SOURCE: Hoover F5906-900 Steam Vac
Make sure that that the lid for the dirty water tank is locked on to the bucket, the other is make sure that the filter on the inside of the lid is not all the way up, needs to be a gap 1/4 inch or so.
Posted on Jan 06, 2008
SOURCE: hoover steam vac
I had the same problem just before the impeller broke. Lower the handle and check the hose connection at the bottom is not broken. Turn the unit on with the handle down, then check the suction on the accessory hose, leae it disconnected. Take off the bottom container, and check the suction on the round intake tube (lower one towards the front), with the handle up and with the handle down. If the suction increases dramatically when the handle is lowered, the impeller is probably in it's self-destruct stage. (same as mine). Soon the impeller will break off, and BINGO no suction at all.
Posted on Jun 28, 2008
  • 97 Answers
SOURCE: I can't get my Hoover Steam Vac to absorb the
if the dirty water lid isn't on correctly then you will not get any sucktion to **** up the dirty water. the best way to put the lid on would be to put it at a 45 degree angle. put the tabs thats on the front of the recovery tank inside the lid and push down untill you hear a click. if you can lift up on the recovery tank lid in the front, then you don't have it on correctly and it's not making a seal. hope this helps. if it doesn't write me back. try this first.
Posted on Aug 02, 2009
SOURCE: Hoover Agility Steam Vac has no suction for the dirty water
Broken suction hose.
Posted on Dec 05, 2009
  • 294 Answers
SOURCE: my hoover steamvac wont **** up dirty water float
Check your filter screen insde the upper tank. if your model has a wrap around filter try to pull it down about 1/2" to maximize air flow.
Posted on Apr 21, 2010
We have a Hoover Steam Vac spin scrub that is not vacuuming up the water during use.
Common issue. Have had it happen on mine as well.
Make sure the dirty water tank is seated properly.
Jun 17, 2011 | Hoover Vacuums
My hoover spin scrub steam vac stopped sucking up water
Only 2 possible probelms.
The vacuum adapter in missing from the dirty water tank.... OR the intake part of the machine is clogged and must be cleared of hair and dirt (with the supplied plastic wand)
Nov 21, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover steam vac spin scrub won't suction the water up.
I fixed my problem by repositioning the tunnel that is on the front of the pick-up tank. It had moved out of position and not allowing a tight seal. It is the white plastic piece that slides a little bit. Good luck.
Sep 20, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover steam vac not sucking water back up i have super wet floors and no water in recovery tank
I think it is the gasket on top and bottom of the plastic chanel that takes the water up to the dirty water holding tank , Part of the rubber gasket is missing on both the top and bottom. This will alow
air to come in and thus you loose the suction to empty the water into the dirty water bin. My unit is hoover steam vac model F60220-900. I need to know where to get the gaskets.
Aug 28, 2008 | Hoover F6020-900 SteamVac Upright Vacuum
Hoover steam vac
in most cases you will need to replace the dirty water tank assy. this is usually around $40 to $50.
Aug 14, 2008 | Hoover F7431-900 SteamVac Vacuum
Spin brushes spin freely on steam vac when not attached to cleaner indicator screen not dirty speed selector is in high position brushes are clean spin brush indicator when brushes attached to machine...
If this is a Hoover Steam vac, the turbine which drives the brushes is bad. If not a Hoover, then what is it, they are different, need brand and model number.
May 14, 2008 | Vacuums
Problems with the Hoover Steam vac Heated carpet cleaner
This happens when the filter on the inside of the lid for the dirty water tank is pushed all of the way up. You need to leave a 1/4 in. gap from the top to the top of the filter.
Nov 18, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Steam vac will not pick up dirty water
My Hoover Steamvac problem isn't with the bruches--it's with the suction. Dirty soapy water stays in the carpet instead of being returned to one of the holding tanks.
Oct 21, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Vacuums Logo
90 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
