Question about Nikon Coolpix 4200 Digital Camera
My Coolpix 4200 does not recognise SD cards
My Coolpix 4200 does not recognise any SD card anylonger - what can I do? Can I reinstall it and how?
  • gerda14 May 02, 2010
    Problem solved ;-)
    Apparently my computer formatted the cards in format FAT32 whereas the Coolpix wants FAT16.
    dgsturt you made my day! Many thanks
    Guru:
  • 1,705 Answers
Try re-formatting the card. It should be one of your camera menu options.
If that doesn't work, buy or borrow another card and try that. If a new card doesn't work you've a camera problem.
If its a camera problem, I'd try the Nikon web site, follow links to support and/or downloads to see if there's a firmware upgrade for the camera.
Posted on May 02, 2010
Sd card not recognised
What size card is it ? I had the same problem using a 64 gb card in my Pentax
Jan 19, 2016 | Nikon Coolpix 3200 Digital Camera
Why my 4GB SDcard can not work at my NIKON coolpix 5900
There are no 4GB SD cards. "SD" cards larger than about 1GB are actually SDHC cards. SD and SDHC cards fit the same slots, but they are slightly different electrically. Many cameras won't work with SDHC (high capacity) cards. SDHC is not backwards compatible.
Jan 16, 2011 | Nikon Coolpix 5900 Digital Camera
I Purchased a new SDHC card from Argos which was 4 GB as the one that came with my Nikon coolpix 3700 is a 16mb I put this new one into my camera and the camera showed that you couldn't use this card,...
Your camera will accept a maximum SD card capacity of 1GB. It simply isn't capable of handling anything of a larger capacity and in particular is incompatible with the more technically advanced SDHC cards.
Your fix is to either replace your camera with a later model or to stick to using SD cards with a maximum 1GB capacity.
Please take a moment to rate my free answer.
Oct 06, 2010 | Nikon Coolpix 3700 Coolpix 4200 Coolpix...
New nikon coolpix s570. sd card is not uploading
Use a good antivirus software to scan the SD card. Your SD card could be infected.
Hope this helped.
Jan 05, 2010 | Nikon Coolpix L11 Digital Camera
The camera will not recognise any sd card from 16meg upwards. Formatting the card makes no difference.... always comes up with ... this card cannot be used! Please help!!
I'm assuming you're formatting the card in the camera and not in the computer. Try this...remove the card and battery...press all the buttons....leave it alone for 20 minutes...insert the card and then the battery...turn it on.
Nov 14, 2009 | Nikon Coolpix 3700 Digital Camera
Regarding starting on the camera
This camera is now ten years old, and will only take an SD card, with a max limit of 2GB. It cannot recognise or use a more modern SDHC card, which is what I suspect you have been trying to use.
Sep 23, 2017 | Nikon COOLPIX L4 Digital Camera
Sd card
To reformat the card so the Nikon Coolpix can use it you can use the DOS command 'format' e.g. format g: HOWEVER the default DOS format is FAT32 which the Coolpix will not read. The SD card needs to be formatted in FAT.
Open a DOS command window and type:
Format 'volume' /fs:FAT
Where 'Volume' is the drive letter to be formatted. On my PC this was 'G'. This may be different on your PC. Make sure it isn't an internal drive e.g. C or D!
e.g. format g: /fs:FAT
The card then works OK on the CoolPix
Nov 27, 2007 | Cameras
Out of memory
Try Reformatting the card in the camera . Then come back
Jun 18, 2007 | Nikon Coolpix 4200 Digital Camera
Ipaq won't recognise sd cards help!!
did you install the following: "iPAQ H3970/H3975 SD Card Driver Updates version 1.1 (27 Oct 03)" SP25681 - Resolves performance issues with SD memory card. - Resolves undetected SD memory card. - Resolves lockups due to SD memory card.
Sep 14, 2005 | Compaq iPAQ H3970 Pocket PC
Nikon Coolpix 4200 Digital Camera Logo
186 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
