Cannot use the numbers session on the right side of the wireless keyboard. instead other functions indicated on the buttoms are activated. How to stiwch between the functions?
I'm not sure what keyboard you have but there should be an "Fn mode", "Mode" or similar button on your keyboard, it should be the same color as the function icons on your other keys. This is usually used to toggle between the different modes. If this doesn't work or only works while your holding it down then you'll need to find the setting software for your keyboard. It's most likely in with your other programs or in Control Panel, some will put an icon in your task tray that you can double click or right click to access them.
Maybe you don't have your wireless turned on. Look on
both sides and in front for the Wireless Switch and turn it on.
Also once the wireless switch is turned on there are keystrokes that can toggle
the wireless on or off. Normally you would Press and Hold the FN function
key located at the lower left of the keyboard, then hit the correct F1 thru F12
key that toggles the wireless. The correct F1 thru F12 key to hit will
have the wireless signal icon )))) on it. Or it might have the icon of a tower
with the wireless signal icon )))). Normally the screen will display
Wireless On or Wireless Off when you toggle the wireless.
Some laptops might have a wireless button instead of a wireless switch located above the keyboard or on the front or sides.
