Question about Singer 2662
Machine will not stitch
When sewing there is no stitch at all too loose to form a stitch
  • 1 more comment
  • lisabanks Mar 27, 2008
    thank you robroy7 I will try that and let you know if that helps.
    Hi robroy 7 I changed the thread on the machine also changed the needle and wound new thread on a bobbin and now my machine is working right!!!! Thank you for you advise, I think changing the needle did it because when it was acting up and jamming the needle it might of bent it a little and it would not stitch properly. Thanks again! Lisa
  • Anonymous Mar 28, 2014
    when sewing there are loose stitche on the bottom
Hello i have this model 2662 I have no idea what is wrong with it. It will do absolutley nothing want catch the thread up in the bobin want do nothing no sound or anything could you please tell me any ideas what could be wrong. The proablems i were having was material get caught up in the thing and skipping and changed needles worked ok for a bit then all of a sudden want to anything any ideas what could be wrong or happened to the machine would be greatly appreciated. I had changed bobbins and moved tension but to no prevail
Posted on Aug 31, 2008
  • 106 Answers
It is either a top or bottom tension problem. Top tension speaks for itself. Most folks do not know that there is the facility on the bobbin case to alter the bottom tension. Your user manual will tell you how to do this. It is very difficult to describe how to do it you need diagrams or to be shown
Posted on Mar 26, 2008
  • Peter Bradshaw Mar 28, 2008
    Glad your sorted out.
3 Suggested Answers
bargainbox
  • 1388 Answers
SOURCE: singer 237 stitches loose on bottom of fabric
Please TRY the solution BEFORE giving your considered rating.
Specific detail on bobbin case adjustment (with picture) near halfway down reply, the remainder will help you achieve a balance of top and bottom tensions.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks
bargainbox.com.au
Posted on Sep 02, 2009
Tally Girl
  • 1133 Answers
SOURCE: trying to sew straight stitch but stitch loose and...
No top tension, follow manual to thread top again and make sure tension dial is set to 5 and thread is pulled between the tension discs fully.
Posted on May 01, 2011
Why straight stitch will not work but zigzag and herringbone stitches work on my machine.
it sounds like the machine needs to be checked at a sewing
machine shop to see what's wrong with the cam's or gear
that makes the stitches
Aug 01, 2012 | Sewing Machines
Kenmore 100 stitch machine will not form stitches
it's probably time for the machine to be serviced
May 29, 2012 | Sewing Machines
My top stich is tight,but bottom is loose of my singer sewing machine.
Think in opposites... the top stitch is formed by the bottom thread tension and the bottom of the stitch by the top. So either the bobbin thread is too tight or the top thread is too loose. Check the bobbin thread first as that is the one most overlook. It should come out of the bobbin without having to yank it hard but it should have a little resistance.
Mar 22, 2011 | SINGER 7470 Sewing Machine
Having rethread the spool it is now stitching but the underneath stitch is still loose
Did you thread with the presser foot up?
This opens the tension control so the thread can enter.
When the foot is then lowered to begin sewing, the thread will have the correct amount of resistance to form a proper stitch with the bobbin thread.
May 08, 2010 | Singer 5070 Mechanical Sewing Machine
Tension issues with the bobbn area
No, I have not had a consistent problem with this.
What looks like a bobbin issue could be a threading issue.
If a sewing machine is threaded with the presser foot down, the tension control does not capture the thread as it should. The top thread then cannot form a proper stitch with the bobbin thread.
If I forget to have the presser foot up when I thread, then I get loose stitching on top and loopy stitches on the bottom.
Mar 30, 2010 | Janome 659 Mechanical Sewing Machine
How can I use this machine as a MERROW machine ?
For best results, use Maxi-Lock cone thread.
Remove the left needle.
Slide the stitch forming finger towards you, away from where the stitch forms.
Set the stitch length to around 1.
Set the needle tension 4 or 5.
Set the upper looper tension at 4.
Set the lower looper tension at 7.
Adjust the stitch width, if needed.
Jan 24, 2010 | Juki MO-644D Mechanical Sewing Machine
Stitching too tight on top
I found a screw on the bobbin case (where you put the cotton for the underside stitching) which was very loose. I tightened it and that created more tension for the bottom thread which solved the problem.
Jan 02, 2009 | Bernina Activa 130
Singer 2662 Logo
184 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
