Can not make the SBG900 to communicate with my laptop, and can not connect with internet
  • intacto750 May 02, 2010
    Thank you so much, I solved the mistery by myself.
    Bless your heart.
    Sandy ...
    Guru:
  • 731 Answers
Does the laptop sees the signal from the wireless modem? how are you trying to setup, please brief the problem.
Posted on May 02, 2010
Searching for password on bottom of motorola surfboard SBG900
try this link
https://www.cleancss.com/router-default/MOTOROLA/SBG900
Jan 15, 2018 | Arris Surfboard SBG900 Modem Cable Modem...
Having problems connecting my lap top to my wireless cable modem. Its a motorola SBG900 gateway. everything seems to be connected. Im able to use it with a ethernet cable just need help geting it to be...
Ok. As per your statement your laptop is working perfectly , when you are connected your laptop with with the cable wire.So the network cable is OK. So you have to configured the wireless cable in your laptop when it is connected to your laptop. After connecting the cable wire to your laptop you have to findout the gate way of your ISP ( Internet Service Provider). To find out the gate way , kindly follow the following instructions.
First findout the IP address , subnet mask,and Gateway addresses of your ISP ( InternetService Provider ).To find out the above mentionedaddresses first open the control panel -> network connections -> local area connction -> properties -> Internet Protocol Version 4(TCP/IPV4) OR Internet Protocol Version 6 (TCP/IPV6)according to your ISP -> Properties
By the systematic selection as mentioned above you will get the IP address, subnet mask and Gateway addresses. Kindly note the Gate way address of your ISP. Then enter the gateway address in the browser and open the window. Then a control panel / a window will appear. It will prompt you to enter 1). user name, and 2) password. If you are having the user name and passwords provided by your ISP , kindly enter them in the window and click to open. Then the particulars of Motorola SURFboard SBG900 Wireless Router will be displayed in the window. Then click the wireless icon and click to enable. Hurray ! your laptop will work perfectly through wireless. If you are not aware of about the 1). User name and 2). password , you must approached to your ISP and try obtain the same for working of your laptop wirelessly.
Oct 03, 2010 | Arris SURFboard SBG900 Wireless Router...
Motorola SBG900,constantly logs off and will not log back on
Common issue with Sync and Security issues with Hybernation and disconnects... It is something to do with your laptop settings with Hybernation.
Mar 24, 2010 | Arris SURFboard SBG900 Wireless Router...
Unable to wireless connect TP-Link TL-WR841ND to Motorola SBG900
DO any of these error conditions show up on the front panel display?
Front-Panel Lights and Error Conditions
Light Turns Off During Startup If:
RECEIVE The downstream receive channel cannot be acquired
SEND The upstream send channel cannot be acquired
ONLINE IP registration is unsuccessful
POWER The SBG900 is not properly plugged into the
power outlet
OR
Light Turns Off During Normal Operation If:
RECEIVE The downstream channel is lost
SEND The upstream channel is lost
ONLINE IP registration is lost
POWER The SBG900 is unplugged
If you rent or lease your SBG900 Contact your cable service provider.
If you own your SBG900 Call 1-877-466-8646 for technical and warranty support. Support is available
24 hours a day, seven days a week.
Feb 28, 2017 | Arris SURFboard SBG900 (49402201900) Modem
Motorola SBG900 Connected but not sending and recieving.
its your modem dude.... try to connect it to your main connection..
Jun 16, 2009 | Arris SURFboard SBG900 (49402201900) Modem
I can't connect the network games!!!
u have to change some settings on the wireless router.go with port forwarding.or u have to put a static ip address .Also u can try out DMZfirst turn off the firewall and try playingbest of luk
May 12, 2009 | Arris SURFboard SBG900 (49402201900) Modem
Motorola SBG900 looses internet connection
if its working proprly with xp computer then i am 100% sure that this modem does not support vist...
Try to contact manufacturer ......or look for user manual...
one more thing try to update your Ethernet driver......may solve it...
happy to help
Aug 18, 2017 | Arris SURFboard SBG900 (49402201900) Modem
Bridging a Motorola SBG900 to a Speedstream 4200
You can't use the Motorola SBG900 for that. The only way it might work is if the Motorola SBG900 had a 4-port Ethernet switch built into it.
Sep 16, 2017 | Arris SURFboard SBG900 Wireless Router...
Can't connect to the internet wirelessly
Well, to avoid confusion, I'd start by doing a factory reset. Insert the straightened end of a paperclip into the reset hole and power up the device to do this. From there, the device should begin broadcasting the default wireless network with the name (SSID) of "Motorola." The DHCP server should also be enabled and if your computer is configured to receive an automatically assigned IP address your wireless network interface should pick up an IP. The security for the "Motorola" network is disabled by default.
Basic troubleshooting from there would be to try to see if you can connect your wireless computer to another wireless network that is know to be working well. Either buy and return another wireless access point or router from a retailer or head to a Starbucks or other establishment that offers free wireless. If the wireless computer is hooking up nicely with the secondary wireless network, you can refocus on the SBG900 as the likely source of the problem.
If after attempting the aforementioned procedures you find that the wireless computer continues to fail to connect to the SBG900 you might have to consider that you have a faulty device. At that point I would consider consulting the manufacturer's documentation.
Apr 05, 2008 | Arris SURFboard SBG900 802.11g/b...
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
