Question about Dell Precision M20 Notebook
I have a power problem with my dell precision M20. The green light shows through the adapter, but as soon as I plug it into the machine, it goes off. Suggestions..?
  • peter477 May 02, 2010
    Thanks for this suggestion. I have now tested with another adaptor, and the same thing happens. So the problem is in the machine..?
  • Dell Master
  • 6,993 Answers
there is a bridge somewhere, that's why it turns off when you plug it into your machine.
I would suggest that you find someone that uses the same adapter with your machine, then use the persons adapter to test your machine. If it still goes off, then you will know that the bridge is from the machine. But if it does not turn off, then you will know that the problem is from your adapter.
I hope you are able to understand my message.
Good luck.
Posted on May 02, 2010
  • Walesarumi
    Walesarumi May 02, 2010
    if you a have tested it with another adapter and it still does the same, then, YES, the problem is from the machine.
    Good luck.
My laptop lenovo 3000 N100 battery has a problem.. therefore i purchased a new battery but the problem with this battery is that when i use the battery it runs the laptop for 10 -15 mins and then with a...
My Dell laptop has a power problem.
d600a.jpg?w=300&h=258
The Dell Precision M20 Battery stops charging when I move the power cord on the DC adapter. When I start moving the cord left to right, the power LED light on the front goes on and off and the battery charge LED goes on and off too.
dell-precision-m20.jpg?w=300&h=225
I removed the precision m20 battery and tested the laptop again. The laptop starts fine from the DC adapter when the battery is removed, but as soon as I start moving the power cord the laptop shuts off. It looks like the laptop looses power immediately.
If you have a problem like that, most likely it’s related either to the power adapter or the DC-IN power jack.
First of all, I tested the laptop power ac adapter with a multimeter. The power didn’t cut off no matter how badly I moved the cord. The power adapter output voltage was 15.45VDC all the time. That means there is nothing wrong with the power adapter and most likely there is a problem with with the power socket inside the laptop.
Now I’m going to test the power socket inside the laptop.
In order to access the power socket I had to disassemble the laptop and remove the top cover assembly with the display.
You can find disassembly instructions for many HP, Dell, IBM, Lenovo, Sony and Toshiba laptops in these service manuals and guides.
In the laptop I was fixing (Tecra M2) the power jack is attached to a DC-IN harness and this harness can be unplugged from the motherboard.
As you see, I removed the DC-IN harness from the motherboard, plugged in the power adapter and tested continuity with my multimeter as it shown on the picture.
When the power cord is still, the voltage output is 15.45VDC, the same as on the plug.
But as soon as I start wiggling the plug inside the jack, the power cuts off and voltage goes to 0. It means, the power harness is bad.
The problem was fixed after I replaced the defective DC-IN harness with a new one.
In some laptops the power socket (DC jack) is soldered to the motherboard.
If the battery stops charging when you wiggle the power plug inside the jack, either you have a bad power adapter (test it with a voltmeter) or the power jack is broken or loose.
You cannot simply unplug the jack and replace it with another one. You’ll have to unsolder the old jack and solder a new one back on the motherboard as I described in this post.
If the power jack is not broken but loose (not making good contact with the motherboard) you can resolder the old jack without replacing it with a new one.
If you want to buy a new one,you can see more information from http://www.udtek.com
Feb 18, 2010 | Lenovo 3000 N100 Notebook
A power spike broke Dell Precision M20 motherboard
Hi there!
Yes it really does damage the motherboard when that kind of things happen.
You'd rather replace the motherboard than repairing it.
Hope this helps!
Feb 13, 2010 | Dell Precision M20 Notebook
I have a Dell M20 and it has stopped turning on. the green light on the adapter is illuminated when plugged into the wall ... then when plugged into the power port on the M20 the green light goes out. ...
I want to say that it sounds like a short in the wires for the adapter. I doubt that a motherboard would cause the light to go out on the adapter. Go to best buy, frys, or some computer store and ask them to let you plug your laptop in to test and see if it is the wire. They surely have a dell being displayed and usually they will let you plug it in with that wire to see if it works.
Dec 27, 2009 | Dell Precision M20 Notebook
My Acer Aspire 5920 is not booting up. When the power supply is plugged into the wall, its green LED is solid. As soon as I plug it into the laptop, the light starts to flash. When connected to the AC...
Your motherboard is probably shorting out your A/C adapter, you may need a new motherboard. With a Dell, the A/C adapter light will be green when plugged into the wall but as soon as you plug it into the PC the green light goes off. Which means that the Motherboard is shorting out the A/C adapter...
hope this helps
Sep 08, 2009 | Acer Aspire 5920-6727 Notebook
Dell Latitude 505 that will not run on AC
Sounds like a BAD adapter. When was the last time it worked in the laptop?? I would try another adapter if possible. When was the last time the adapter work on the laptop?
Jun 03, 2009 | Dell Latitude D505 Notebook
Bad motherboard for M1730
take out the battery of your machine and plug in the power. if it works well, suspected faulty battery. you need to replace it.
May 19, 2009 | Dell Inspiron 6000 Notebook
Laptop will not turn on
Unplug the ac adapter from the back of the computer. Make sure it's plugged to an electric outlet. check if the ac adapter light is solid green. if not. then you have to replace it.
If it is solid green, reconnect it to the computer, if the light on the adapter goes out as soon as you plug it in to the system, you need to replace the motherboard. call dell to seek your options for replacement.
Mar 02, 2009 | Dell Latitude D600 Notebook
Dell Precision M20 Notebook Logo
110 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
