Question about Zanussi WJS1265W Front Load Washer/Dryer
Grinding sound - drum turns then nothing - just grinding sound until E20 warning.
  • 269 Answers
Can you turn the drum by hand.E20 relates to a fault with either the pump or the filter or drain may be blocked,check the filter is clean and the pump can be turned by hand,its up at the end of filter housing and can be seen depending on the model.If the drum cant be turned freely then you have something stuck inside the drum.
Hope this was helpful.
Posted on May 05, 2010
My dryer makes a loud grinding sound and won't turn?
The grinding Sound is the motor attempting to start and not being able. If you find nothing binding the drum and you can turn it by hand fairly easily you will likely need a new motor. Otherwise, find and remove what is causing the drum from not turning
Nov 14, 2015 | Dryers
GE Profile DPVH880EJWW dryer makes a grinding sound and vibrates intermittently. Any idea what causes that. I was thinking the drum glides.
look an see if the front seal on dryerdrum is rubber again front dryer cabian look for melt shaving in dryer drum are drum support an dryer pulley is warn out
Sep 25, 2015 | GE Dryers
Braking results in grinding sound
I suggest you pull rear drums or have someone qualified look at rear brakes. it could of broke a spring or other brake hardware. I suggest stop driveing the car until you can inspect or have the brakes inspected..
Aug 02, 2014 | 1999 Ford Taurus
Drum will not turn
there is a belt that drives the drum in your dryer it is broken
the grinding sound is caused by the the wheels that the drum rides on broke or the bearing went out
Apr 14, 2014 | GE Dryers
Grinding Noise
Check for warn drum rollers
Jun 05, 2017 | Frigidaire Dryers
Dryer making a grinding noise when turned on. How do you get the top off to check the barrel motor?
Clanging Sound
1. If the noise coming from your dryer can be described as a clanging sound, the solution is probably well within your grasp. This common sound is typically the result of loose debris accidentally put in with the load of laundry. Change may be left in pockets of pants or other objects may be dropped in the laundry basket by children --- perhaps a toy car. The objects may not be noticed when put into the wash, and the water in the washer may have dampened the sound. Simply remove these items, and restart the dryer to resolve the issue.
Sometimes the clanging is from snaps or buttons that are actually part of the clothing. If you are drying a jacket with metal snaps or another garment with metal attached, you should expect this clanging sound as they tumble and strike the inside of the dryer tub.
Humming or Whistling
2. Many Roper dryer models are equipped with a safety feature known as a lint signal, which is usually a light that often accompanies a warning signal, telling the machine owner that the lint trap has become clogged. When the dryer cannot pull adequate air through the lint filter, it can overheat and become a fire hazard. The warning alarm may sound like a hum or whistle to get your attention. Look at the lint signal light, clean out the trap and the noise should stop.
Thumping or Grinding
3. If the noise you are hearing can be described as a thumping sound or a metal grinding sound, the device that turns the dryer drum, known as the drum rollers or glides, can be worn out. As the drum turns, there may be a constant and rhythmic thump each time the drum rotates. A severely worn or broken roller could cause the metal of the drum to rub against the metal housing of the machine, causing a louder grinding noise. The rollers will need to be replaced to remedy the problem.
Squeaking or Squealing
4. Most dryers work by using belts to turn the rollers, which in turn make the drum rotate and tumble the clothes dry. When these belts get loose, a worn belt or a malfunctioning tensioner spring may keep the belt tight. In either case, belt slippage may occur and will produce a squeaking or squealing sound that is easily recognized. The problem is likely to be the tension on the belt since most belts will break before wearing out to this degree.
Feb 24, 2011 | Whirlpool Dryers
Grinding sound on offside rear wheel when breaking. Parts as standard. Tried brushing dirt from brake drums. Still persists.
Your brake shoes are warn down to the metal. get them off of there fast or you will be turning the drums too. Hopefully you are in the squealer stage still, they put a piece of metal in there that hits the drum first as a warning. to you. get them changed.
Sep 28, 2010 | 2000 Ford Focus
Rear brake grinding noise when pressing on brakes
The grinding noise in the rear brake drum means that brake shoes are warn out and the metal part of the shoe is touching the drum. You need to replace it asap as it will damage the inner part of the drum and than replacing shoes will not help without skimming or replacing the drum.
Jun 28, 2009 | 1999 Mazda Protege
Loud noise when it spins
Sounds like main drum bearing noise, try turning the drum by hand, if it feels rough or you can hear it grinding or rumbling, then it is the the main bearings that have failed..
You will probably need to call an engineer.
Dec 03, 2008 | Washing Machines
Drum won't spin freely
Are you sure that there is nothing sticking through the holes in the drum like a nail etc or a screw from trouser pockets, it could be that the heating element has come loose and is scraping against the drum or that the bearings have gone.
Feb 04, 2008 | LG WM-2077C Front Load Washer
Zanussi WJS1265W Front Load Washer/Dryer Logo
177 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
