Question about Sony HandyCam DCR-SR200E HDD Camcorder
Camcoder lcd signal distortion - Sony HandyCam DCR-SR200E HDD Camcorder
  • 172 Answers
Its due to LCD cable,it need to replace
Posted on May 02, 2010
Audio distortion
It is possible that the built in speakers are broken. Try hooking up your Bluray player/other devices to an external speaker. If you are using an HDMI a signal splitter can be purchased for relatively cheap.
Apr 09, 2014 | Proscan 47LB45H 47 in. LCD TV
Sigmac NE32AB1 Sound Distorted
Interference. Separate wiring in back, so there is no cross-talk of signals. If speakers are failing, go to walmart and buy a new set, <$20.00, hook up and sound is great.
Feb 13, 2014 | Sigmac NE32AB1 32" LCD HDTV
TV signal seems to "crack" with pixel distortion.
This is what digital signals do if there is not enough signal to paint the picture on your set. If you are using an antenna, then the signal coming from the station over the air is not strong enough or is being blocked by the trees and buildings. The TV needs a signal at least 60-70 % to get the data, and since the FCC mandated higher frequencies for over the air TV, the stations signal will not travel very far. You can try a better TV antenna, with a higher DB gain, but it seems to be a loosing battle for the present.
If you subscribe to cable TV and it is happening, then by all means complain to your Cable Provider as they should send yo a signal that will run your set.
Jan 17, 2011 | Sony KDL-46XBR4 46 in. LCD Television
My monitor screen has become greenish and with
Hello Devsi, hi, check your VGA cable connection for loose connections, try tighten it first to see if it solves the problem. the greenish thing is cause by a missing red signal, and the distortion is caused by a missing horizontal sync signal, also check out if there are bent pins on your monitor signal cable. just unplug the VGA cable and see if the pins are in order. if bent, carefully straighten it with a slim slotted screw driver.
Dec 17, 2009 | LG Flatron L1750S 17" LCD Monitor
Picture has shadowing or ghost like images
This unit is getting distortion form the video circuits, most likely capacitors or resistors causing distortion to the input or output circuits. This problem could be caused by a bad video amplifier also ,which is distorting the signal. This problem needs to be checked with an oscilloscope to follow the signal path and find the source of the distortion. Usually this is best handled by a service center. If the unit is still under warranty call this number for Insignia customer help : 1-877-467-4289. If the unit is not under warranty, you should take it to a service center and have an estimate of the problems and repair costs. You can find parts for this television at the Best Buy parts website. Just google it and put in the number of your television and it will list all available parts and prices. You can also call this number for Best Buy parts : 1-888-237-8289. Hope this helps you with your problem.
Apr 11, 2009 | Insignia 37" LCD Flat-Panel HDTV
Lines on camcoder lcd
the problem was solved automatically by connecting the camcoder to the pc which had the jvc software installed to it.
Aug 18, 2008 | JVC Everio GZ-MG21 Camcorder
Distorted picture when looking through view finder or lcd screen
the video playback is sampled off the video out and independently processed sorta like a TV signal to project on the lcd screen.
horizontal lines means you lost sync circuit and needs troubleshooting. Hopefully maybe a bad connection with a ribbon cable for the ICs and components are hard to change and jammed tight. I would order a video board.
May 14, 2008 | Sony Handycam DCR-TRV460 Digital Camcorder
The vivitar dvr 510 camcoder is not initializing
i use nickel-metal hydride so try that it should work ;) your welcome
Mar 27, 2008 | Vivitar DVR310 Digital Camera
Samsung Digital camcoder VP-D305i : LCD image blurred
OK IF YOUR PRERECORDER VIDEO'S PLAYBACK CORRECTLY THIS IS THE CCD AND CANON WILL FIX FOR FREE. THANKS TO SONY
Feb 19, 2008 | Canon ZR85 Mini DV Digital Camcorder
I have a Sam sung digital camcorder vp - d305i.
I have used the cam 3 times and decided to use it for once and now have found no image on the Lcd and view finder but it seems to record the sound only.
What could it be???
Dec 21, 2007 | Video Cameras
Sony HandyCam DCR-SR200E HDD Camcorder Logo
54 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
