Question about Kitchen Ranges
Gasket for bottom oven on a Tappan double oven range
We need a new cloth/fiberglass gasket for the bottom oven on a Tappan double oven range. The original part number is 641T003P01. The latest version of the replacement part is #08010449. However, that was discontinued in 2004. Is there any way to find an old gasket, or a whole door? Or, is there an after-0market gasket that would fit a 24x16 inch seal?
The model of the range is 73-4456 0001019
SOURCE:
SOURCE: Replacement door seal/gasket
Replace a tub seal for a frigiduare front loader
Posted on Apr 08, 2007
SOURCE: How do I fit a new door gasket?
after putting the seal on with the aid of washing up liquid put the spring on first by the door catch hold it on with one hand and isnert a screwdriver in the hole for the door catch this will enable you to hold the spring on if you put your knee against the screwdriver giving you two hands free to push the spring on
Posted on Sep 15, 2007
SOURCE: Replacing LG Dishwasher door gasket/seal with Part # 3920DD3005A
Problem solved - it was not the gasket - it was the vent tube as defined in one of your on-line reported solutions. Thank you!!!
Posted on Oct 14, 2009
Testimonial: "Contacted numerous resources to try identify LG dishwasher leak problem, including LG. Found solution,vent tube right here on FixYa. Many thanks!!!!"
erpaalai
  • 999 Answers
SOURCE: I need to replace the over door seal (or gasket)
yes you have to separate the door panels to tuck the seal in properly.
Eric
Posted on Dec 24, 2009
EllaWatson25
  • 725 Answers
SOURCE: A long rubber gasket fell out of the bottom of door
We provide free diagnostic information when you tell us what brand and model number you are having issues with.
We are available from 7 AM – 7 PM CST. We also provide part removal/installation instructions for our customers when parts are purchased through us.
It is our goal to get you back up and running again ASAP, so please contact us when you need us to help you.
We look forward to hearing you and hope that you have a terrific day. Thank you, Ella
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
Posted on Mar 11, 2010
How do I replace the oven door gasket on my VGIC3686
Replacing a Door Gasket
If the oven won't heat to the desired temperature or heats unevenly, the problem could be a defective door gasket. The best way to test for this is to pass your hand around the door, being careful not to touch it, while the oven is turned on. If you can feel heat escaping, the gasket needs replacement. Replace it with a new gasket made for the range.
On most ovens, the gasket is located on the frame of the oven, and the door closes against it. This gasket is generally friction-fit in a channel and can be replaced. In other units, the oven door has two sections, and the gasket is not mounted on the door frame, but is installed between the front and back sections of the door. Don't try to replace this type of gasket; call a professional service person. Here's how to replace a frame-mounted gasket:
Step 1: Pull the old gasket out of the channel. On some oven door frames the gasket is held in place with screws. To get at the screws, bend back the exposed edge of the gasket.
Step 2: Clean the channel and the door frame with a solution of mild household detergent and water.
Step 3: To install the new gasket, start the replacement at the top of the door frame and work down the sides, easing the gasket around corners. Finish the installation along the bottom, butting the ends of the gasket firmly together.
Apr 16, 2012 | Viking Kitchen Ranges
Tappan oven door seal replacement
You will have to google the parts may be very hard to find but you never know what comes up .
Mar 16, 2017 | Tappan TEF242 Electric Kitchen Range
I have an older Tappan gas range. There is a
If you are referring to the top of the oven cavity itself (the ceiling in the oven) you may be describing the flue gasket and flue that is mounted on the top of the oven cavity. The part numbers are 316116600 and 316204401, respectively.
If you are referring to the top panel of the stove directly under the console, and in back of the surface burners, you may be describing the oven vent opening. It is normal for this vent to have oven heat escaping it. That's what it is for. That's also why you do not leave anything on the stove top while baking. There is a vent cover that is supposed to install over the opening. The part number is 316104500.
If the model number is correct, you can refer to pcappliancerepair.com for illustrated parts listings. The flue gasket and flue are listed under the "Body" section as items 35 and 36, respectively.
The top vent cover is listed under the Top/Drawer section as item 25.
Please review the parts listings for clarification. If I have identified the wrong parts, based on your description, or if the model number is not correct, please post back and let me know. I hope this helps you.
Dec 20, 2009 | Tappan TGF320 Gas Kitchen Range
I have an old (20 years +) Tappanr 4 burner range with a double oven. I am missing the knob for the cleaning cycle but it says it is self cleaning. I need a replacement. I'd also like to find replacement...
chances ar erte hlower oven door , is your broiler, the older models didnt have a seperate broiler inside oven, rather they used 1 burner bar ,and depending on wher oyu place the food you would either bake(above) or broil( under) made sense, just pain in the rear to bend down to use it. as far a knob and gasket , perhaps you can find a model number under the main top assy so we can look up for you
Mar 07, 2009 | Tappan MPF500PBW Gas Kitchen Range
Need directions to clean my tappan oven
1. Add baking soda to a cool oven. Sprinkle a thick layer of baking soda onto the bottom of the oven. Make sure the oven is completely cool before you attempt to do this. 2. Spray the baking soda with water. Using a spray bottle, spray the baking soda down until it is damp, not saturated. The water and baking soda together will help break down the food particles. 3. Continue spraying baking soda as it dries out. Every few hours spray the baking soda down again to keep it moist. Continue this process over several hours, spraying water as the baking soda begins to dry out. 4. Scrape out the baking soda. Scrape the baking soda out of the oven. Food residue will be scraped out with the baking soda. 5. Rinse the bottom of the oven out thoroughly. Yes, you'll still have to rinse out the oven, but next time you cook your food won't have an added taste of oven cleaner.
If I had the rest of your model number I may find what Tappan now Fridgedaire Electrolux reccomends, but this is the least toxic. Have a great day..
Feb 08, 2009 | Tappan TEF242 Electric Kitchen Range
Tappan gas range burner ignition
Hello paultoledoWelcome to fixya.
I'm Huuum and happy to assist you,
You said, You got a 5-year old Tappan gas range. Two of the burners don't ignite, the other two and the oven are fine.
What do you need to do to fix the problem?
Sounds like a yes from where I'm sitting, your right on target, buying a new spark module will fix it.
That sounds like the spark modules.
I think you are correct!
Let me know if you need me!
Please remember to leave a solved rating!
Huum
Sep 24, 2008 | Tappan TGF657 Gas Kitchen Range
Kitchen Ranges Logo
89 people viewed this question
Top Kitchen Ranges Experts
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
