Question about Sony PSP-3000 Silver Console
How to transfer umd to memory stick duo in psp
2 Suggested Answers
  • 8 Answers
SOURCE: UMD Icon Not Showing Up Under "Games" in menu
You've cleaned the disks but have you cleaned the laser? That'd be the next step before looking @ repair options.
Posted on Sep 05, 2007
How to download in psp games
1. CONNECT YOUR PSP TO PC
The PSP can function as a USB Memory Stick Duo reader. Using this functionality, you can copy pictures, audio, and other content to and from your Memory Stick Duo. To access the Memory Stick Duo in your PSP from your PC, you'll need a USB cable that has a "Mini-B" connector (common for digital cameras) and a "Standard-A" connector (common for printers, etc). Plug the Mini-B side into the top of your PSP and the Standard-A side into your PC. From the PSP software, navigate to the top of the settings list and select "USB Connection." Your PC (Windows/Mac/Linux) should detect a new "Removable Disk Drive" that you can then access.
2. TRANSFER SAVE GAME TO "SAVEDATA" FOLDER
Just copy the folder you have just extracted, and paste it into the PSP's "SAVEDATA" folder. But, BEWARE!, to any folder overwrite warnings! Because the PSP save game folders use the same names for the same games, copying folders into these locations could lead to lost data. For this reason, we recommend that you backup your old save games before overwriting them. For Example, I would simply rename a folder like "ULPS0004" to "ULPS0004_backup."
3. EXIT USB MODE
Because your PSP has been in USB Mode throughout this process, just push X to exit. Then you can safely disconnect your PSP from your PC.
download the games here as many as you can for free
http://www.pspmaniaonline.com/
Say "Thanks" by clicking the thumb icon in the post that helped you. Please click "YES" in solution that solves your problem as "was this helpful?"
Apr 18, 2011 | Sony PlayStation Portable (PSP) Slim...
My problem is with Harry Potter and the Goblet of Fire for PSP. I use a MicroSDHD to Pro Duo converter memory stick, and thus far it's worked PERFECTLY. All games launch off of it, load times are great,...
i bought my little boy harry potter and the goblet of fire but all it does is saysthe memory stick is currently been accessed removal may cause loss or corruption of data i went out n bought him a 8gb memory card because i thought it might of been that why won@t it load?????/
Apr 04, 2011 | Electronic Arts Harry Potter and the...
Psp 3000 or psp 3004 or psp go of sony which the best
PSP 3000 is a Japanese PSP.
PSP 3001 is the U.S. model
PSP 3004 is a european model
All of the above are the same PSP, different regions. The PSP3000 allows you to play UMD movies & games, allows the use of Memory Stick Duo which also work in Sony cameras and camcorders but none have internal memory.
The PSPGO has internal memory but it does *not* use UMD discs at all! It also does not use memory stick duos as the PSP 3000 does. It's not very comfortable to play games either -- I hear it was created to compete against the i-touch but it is NOT touch screen.
Stick to the PSP-3000. It's cheaper and does more.
Mar 17, 2010 | Sony PlayStation Portable (PSP) Console
Before i bought my psp there is nothing any problem with games loaded, then after i upgrade the memory from 4GB to 5GB do this will affect the memory stick and some games hung usually the vice city.
Try to remove your UMD (Universal Media Disc) when it gets hung and also try to remove your memory stick Duo from the memory slot. You can also try removing the battery and keeping it out for 10-15 minutes and the putting back your batteries and see does it work. If none of these work in the above sentences please try replacing your memory stick Duo.
Feb 15, 2010 | Sony PlayStation Portable (PSP) Console
PSP not detecting files on a 4gb memory stick PRO Duo
There are certain folders that the PSP puts on the stick when it formats it. Format the new stick on the PSP first. Then, you can transfer you files to it.
Jun 28, 2009 | Sony 4GB Memory Stick PRO Duo Memory Card
Storing games/music on the memory stick
press select button then when you see the CPU CLOCK XMB just turn it into 333/166 and also the CPU CLOCK GAME turn it into 333/166 and the UMD ISO MODE turn it into Sony NP9660 and then exit...
Mar 29, 2009 | Sony PlayStation Portable (PSP) Slim...
How do you copy games onto your memory stick on a sony psp piano black?
If you have custom firmware installed you can download umd dumper: http://www.psp-hacks.com/file/38.Just put the umddump and the umddump% in PSP,GAME and then put the umd you want to copy on your psp and on your psp go to game, memory stick and click x on umd dumper.Then when its done coping go to game, memory stick and there should be the game of the umd and you dont have to had the umd to play the game.
Mar 21, 2009 | Sony PSP (Piano Black)
Psp illiterate
Yes there is a way. What you will need is a PC, Some form of Memory stick Duo card Reader, And a PSP Compatible Memory stick Duo/Pro Duo.
If you havent already used the memory stick inside the PSP it will not have the correct Formatted file System for use in the PSP. but you can create the file system using your computer.
heres how to do it ! :
1) plug your Memory stick Duo/Pro Duo into the card reader on your computer.
2) open my computer, locate the Memory stick usually found under the "devices with removable storage" area.
3) once inside the memory stick, create 2 seperate folders. One called "PSP" and the other one called "MP_ROOT".
4) Navigate into the "PSP" Folder and create 3 Folders, "MUSIC", "PICTURE" & "VIDEO"
5) Copy & Paste the Necessary files into each Subsequent Sub-Folder within the "PSP" Folder.
Note : The PSP Can only handle Certain File types for Pictures, Music, And Video. i would suggest Navigating to http://psp.about.com/od/hardwarefirmware/p/compformat.htm before you transfer your files to ensure that you are adding files which are Viewable/Readable by The PSP's software.
Hope this helps !?
Oct 27, 2008 | Sony PlayStation Portable (PSP) Console
PSP:UMD'S and ISO'S
Do all UMDs / ISOs not work...
Clean laser lens with lint free cloth..
Can you transfer an ISO onto your memory stick - just to prove its the CD and not the decoder ??
Aug 14, 2008 | Video Game Consoles & Games
How can I download video files from my PC into my PSP?
First of all make sure that the movies you want to transfer are of the Mpeg4 format. For info on how to convert different files into the correct format follow this link : www.memorystick.com/psp Choose the movie icon from the main menu, insert a UMD or a Memory Stick Duo, a new icon will show up. Choose the icon and press the X button. The movie should now play. In order to download the movie into the Memory Stick Duo you have 3 options: 1. use a computer with a Memory Stick slot. 2. use a compatible USB cable. 3. use an external Memory Stick reader with a USB connection. Note that the PSP cannot read files converted in a rate higher then 768 KBPS. Good luck
Feb 21, 2006 | Sony PlayStation Portable (PSP) Console
Sony PSP-3000 Silver Console Logo
107 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
