Question about Asko 24 in. D3350 Dishwasher
F7 code hi i have asko d3351 dishwasher ,which gets halfway through cycle and brings up f7 blocked drainhose,i have checked both hose and pump all seems good is there something eles i can check
    Sergeant:
  • 351 Answers
Yes remove filter and water from under filter theres a small chamber at the back of the sump,it may be full of fat clean it with your finger then try running some heavy wash cycles to clean it.
Posted on Jun 17, 2010
My asko D5155 stops washing and flashes F7
LED L1+ L2/Fault code F7, Pumping out fault (machines with
pressure sensor)
Water not evacuated after 120 seconds pumping out. Program
interrupted.
Check: Drain pump, hoses, installation of drain hose, control unit and wiring.
Dado
Oct 06, 2015 | Asko Dishwashers
Asko D3350 code F7
you seem rushed
ok
the problem might not be in your senser or timer but in the pump its self
Sep 14, 2008 | Asko 24 in. D3350 Dishwasher
Will not pump out water at end of cycle
Unplugthe power cord to your dishwasher. You can do this by manually removing thedishwasher from the wall and unplugging it, or you can flip the power switch toyour kitchen at the circuit breaker (although you will need light to drain thedishwasher hose). 2 Put on your gloves,and, using your screwdriver, unscrew the screws from the kick plate of yourdishwasher. The kick plate is the panel just below the door of your dishwasher.3 Place your bucket on the floor in front of the dishwasher. 4 Unhook the drainhose by pinching the ends of the clamp and sliding it down the hose. Remove theother end from the pump. There will be two hoses in your dishwasher. The drainhose is the one that leads from the pump to the underneath of your kitchensink. 5 Point the hose into your bucket to drain any debris. Twist and scrunchthe hose to help remove the waste. 6 Test the hose by running water through it,and then reattach your hose in the same manner in which you detached it fromyour dishwasher.
May 13, 2011 | Kenmore Dishwashers
Hi I have an Asko D3350, and have an 'F7' problem, can anyone help. Starts all wash programs then stops half way through with f7 showing. but the pump and discharge hose is clear. If it means anything it...
At the bottom of the dish washer where the water drains from there is a rectangular hole at the back (you will need to remove all the baskets and the screen). Grease can accumulate here and block the tube that feeds a pressure switch, causing this malfunction. This grease will not be visible as it sits under a lip on the other side of the rectangular hole and above it. This would need to be removed carefully as one doesn't want to push the grease into this tube
Feb 02, 2011 | Asko 24 in. D3350 Dishwasher
My Asko dishwasher is not draining. Code F2
drain plugged, hose kinked or discharge pump bad
Jan 19, 2010 | Asko D1976 Built-in Dishwasher
4 flashes and beeping
4 flashes indicates a drain failure. Could be obstruction in drain system-first check drainhose for kinks, check where drain hose attaches to wastepipe spigot for blockage. If OK blockage may be in pump- disconnect from power, remove bottom panels to access under machine. Drain pump located front left- remove plug from pump, then there is a plastic tag on top of pump you must push down, then drain pump will turn and come off (it comes off easily if tag pressed correctly, so don't force it!!)
If pump OK, fault will be with water indicator switch-sometimes get full of muck. Open dishwasher door, remove filters and clean out any water from base. Right in the bottom right hand side of sump you will see a round black grill- this is water level indicator switch. If it looks blocked up, advise replacing (you can try cleaning, but replacing is best). To replace, access from under machine-again, this switch turns and pulls out, but can be quite difficult due to it being located behind the heating tube.
So, check hoses and pump, then press and hold start button for 3 seconds- this clears fault and resets machine. Try another cycle-if OK, problem solved. Recommend expert assistence to replace water indicator switch.
Aug 04, 2009 | Whirlpool 24 in. ADG7540 Built-in...
Asko D3350 code F7
Service manual says:
LED L1+L2/Fault code F7, Pumping out fault
(machines with pressure sensor)
Water not evacuated after 120 seconds’ pumping
out. Programme interrupted.
Jan 19, 2008 | Asko 24 in. D3350 Dishwasher
D3350 - Code F9
Asko D3350
Steve, according to the codes listed on http://www.repairclinic.com/0078.asp apparently F7 is a bad door latch. It could be just not shutting fully or maybe one of the springs/rods needs looking at.
Is there anything recently that may have happened to the door? Slamming, jarring, etc.
Dec 21, 2007 | Asko 24 in. D3350 Dishwasher
D3250 drain blocked error
usually these are blocked at the discharge end under the sink, especially if the hose is hooked to a copper pipe then shoved down the plumbing standpipe. It could also be in the hose behind the dishwasher if someone has fitted an extension onto the hose and used a small diameter coupler. Run the dishwasher on any cycle...if there is standing water you should hear the drain pump run first...if there is no standing water run it on a rinse and hold cycle. at the end of the cycle the pump will run. if you hear the pump, but no water is ejected out the drain hose under the sink, then you most likely have a clog in the hose near the end or in the middle if it has an extensio. if you dont hear the pump run, then its a bad pump and you need a new one (parts like that are covered for 5 years if you use an ASKO servicer) Good luck!
Nov 03, 2007 | Asko 24 in. D3250 Built-in Dishwasher
Asko 24 in. D3350 Dishwasher Logo
1,063 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Owen Barnes
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
