Question about Compaq Presario Laptop
Hello, my laptop have a prob when i switch on my laptop wire less ,it shows laptop wire less is working but buletooth (r) is diable , so tell me i do ?
  • 1,555 Answers
Just right click on my computer select properties go to device manager check whether bluetooth is disabled or not if disabled right click on it and select enable.
Posted on May 02, 2010
Where is the switch to turn wifi on and off on a dell laptop
Less and less laptops now have a hardware switch to turn wireless on or off. You have to do it from the operating system. As the method to do so varies from Windows to Windows (or other operating system) iterations, I find the easiest recommendation is to "disable" (not "uninstall") the device from "Device Manager" temporarily. You will not lose your settings when you re-enable a diabled Wifi adaptor.
Nov 27, 2017 | Dell Computers & Internet
My ACER laptop will not switch on the workshop told me i require a new motherboard they installed a new mother board but the problem still persists
It is very possible that your battery pack may be bad. Even if it is holding a charge, the connector can go bad thus diabling your unit to power on. The workshop should have connected a voltage meter to the board to make sure it is working.
I would return it back to the shop and demand they correct the issue. (Assuming you paid them for the service.)
Good Luck.
C2Solutions
Jan 24, 2011 | Computers & Internet
My scroll of touch pad is not active... how can i activate it...??? of sony vaio (VPCEB14EN)
Hello, if your touch pad is diabled you need to enble it from VAIO Control Center. You need connect a external mouse in order to follow the steps easily: Click Start, All Programs, and VAIO Control Center. From there you need look for Touch Pad > enable it.
(we need your rating to improve our quality)
Aug 29, 2010 | Computers & Internet
My hp pavilion entertainment pc is showing orange for the wireless connection.. when I click on it, it doesn't turn blue it just says WLAN: on or WLAN: disabled but even when it says its on it stays orange...
1. Go to device manager ad check your wireless card is not diabled,
2. Try to search your network and see if your laptop could detect it
3. you can try Fn + f2 kesy as well to turn off/on your wireless switch,
Jul 27, 2009 | HP Pavilion dv7-1132nr Notebook PC
Wont recognize or connect to wireless network
Make sure that Wifi is turned on. It may be a keyboard combo sequence or a dedicated switch. Check your manual. There also should be an indicator light to tell you when Wifi is turned on.
Jul 17, 2009 | ASUS Eee 4G Notebook
My buletooth is not working
You may have installed the correct driver but does the laptop have a bluetooth component device installed? Check in control panel, system specs.
Jul 07, 2009 | Dell Vostro 1510 Laptop
Hello, sir LT is Compaq prasario V6307 TU,have sound & WiFi prob.
Hi! For Wi-Fi you have to check weather the Wi-Fi switch is off or not ,there is small switch at side off laptop.
For sound you have to check the drivers
Mar 21, 2009 | HP Compaq Presario V6000T Notebook
I am unable to access the wire less lan in compaq presario c700
hello,
have you been able to access the wire less before? Or is this a new computer? Are you home where you have control of the router, or at work or someplace else?
Are you sure it's the driver? Are you sure you input your wire less SSID and password (if WEP or WPA encrypted)?
For a driver, you want to make sure it's not working now as far as the windows device manager. Can you check in control panel--system--->hardware tab--device manager? Under 'N" - network adapters-- is your wire less card listed? Or is it listen down by "O" - other devices (which would indicate that the computer can't tell if it's a wireless card since the driver is missing)
lastly, if the latter, to get a driver, we need to know the exact name and model of your computer, plus the operating system youre using.
And also, if youre using windows, the "windows update" function not only updates windows, but can also check for troubled devices and update some drivers. You might want to try that.
that said, most connection problems are not driver related, but more the person turned off wireless via a hardware switch or F key on the laptop, or didnt type in their encryption password correctly.
Feb 05, 2009 | Compaq Presario 700 470024-192 Notebook
Mitsubishi WS55807 Converge prob.
hello yes i can tell you where to look . take front of the set off and there's a cover with screw's holdng it on . take it off . and your convergence board in the front of the set.'GOOD LUCK"
Nov 07, 2008 | Mitsubishi WS-55807 TV
Pcmcia cards show up as mtd-0002
if you go into sound and multimedia you can change the preferred output/input items to your PCMCIA card rather than the onboard systems. you could also try disabling onboard systems in device manager too.
Oct 07, 2007 | Gateway 7210GX Notebook
Compaq Presario Laptop Logo
42 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
