Question about Matrix Mr600 Metronome
Broken metronome I have wound an old metronome too tight and it doesn't work. It is a triangular shape. Where in dublin could i get it repaired?
  • Matrix Master
  • 5,603 Answers
Take it to a place that repairs clocks. They should be able to help you.
Posted on May 02, 2010
The metronome on my P90 won't switch off. Is there a way I can fix this easily?
The P90 uses a rubber membrane switch to turn the metronome on/off it maybe that this has failed. Inside the rubber is a carbon contact that bridges over the PCB. If this gets dusty or worn out then it will not operate. This could be the cause, dismantle and clean and try again.
If not then it is with the electrical circuitry which would be harder to diagnose.
Jan 27, 2015 | Music
Over winded
... what is it? A tuner on a guitar?
Sep 13, 2012 | Wittner 6401 Taktell Super Mini Metronome
Dr. beat will not turn on
Most of the problems with these type units are due to dead batteries or incorrect power adapters and broken power jacks, Check for those things use ONLY the original type power adapter.
Aug 02, 2012 | Roland Boss DB60 Dr Beat Metronome
SEtting tempo on metronome Zoom R24
The metronome speed is controlled by the Tempo setting. The metronome controls only adjust the volume of the metronome and if the metronome is heard on the input or output recording. The R24 manual is available here: http://www.zoom.co.jp/downloads/r24/manual/ . See page 20 for setting the Tempo. The Tempo button is below the Tempo label to the left of the LCD display on the right side of the Zoom R24.
I hope this helps.
Jun 01, 2012 | Samson Technology Zoom R24 Multitrack SD...
How open the metronom for internal repair
Almost all these plastic "wonders" have a set of screws... sometimes they are hidden under rubber feet OR under labels. When these are out, often there are little plastic protrusions that mate to depressions in the opposite site that have to be popped open. The key is to go slow and NOT to exert too much force. Sometimes they "hide" screws in the battery compartments as well. Often when you open these devices they go sproing and the little plastic buttons fall out of the front cover, so NOTE where they go. Rotating knobs often must be pulled off the shaft
Sep 10, 2011 | Korg digital metronome KDM-2
My son has started learning piano using the CTK 651. The music teacher needs a metronome function in this keyboard. Is there a option for this here? How do i get to that.
Most of these keyboards have such a function... the manual doesn't show any... however one could select drum set 5 and use the claves setting for a rhythm and control the rate with the tempo. This might be too complicated and it might be simpler to get a small metronome... some are very inexpensive.
Jul 19, 2011 | Casio Keyboard Ctk-481 Ctk-631 Ctk-651
Hi I have a Digitech RP 300 Modeling Guitar Processor that lights up and will play the metronome tik but will not output the guitar, the guitar input is dead or semes to be. can any one help. thanks...
The metronome is built in software, but it proves that your output is working fine. That's good.
Try changing your patch cable from guitar>pedal. if that doesn't fix it, grab a screwdriver.
Open the pedal and check the input port - is there any bent pieces or blockages preventing the cable from contacting what it needs to? Is the solder broken, cracked, or missing? Are both contact points firm and in place?
May 11, 2011 | Music
I can't figure out how to change my metronome (A Korg Metronome MA-30) to 2/4 instead of 4/4
Turn on metronome. Make sure that metronome is not operating. If it is operating then press metronome switch to stop it. Now press up (^) or down switch. This will change the time signature. When u get appropriate time signature, press Metronome switch once. It will start operating with selected time signature...
Mar 17, 2009 | Korg Ma30
Matrix Mr600 Metronome Logo
307 people viewed this question
Top Matrix Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Matrix Music Expert? Answer questions, earn points and help others
