Question about Tecnik 24 in. TKD795/3 Built-in Dishwasher
Hi, I have a Tecnik TKD/795 dishwasher (not sure which version - its the one with the three black rubber buttons on top). The problem is that the 'ready' button's led light is continuously on green 'on' so I can't change the program select. Also when I close the door to automatically start the cycle - nothing happens ! Please can you help ? Thanks Mr. Arwel Jones
  • arwelfon May 02, 2010
    Thanks for the reply......how do I trip the circuit beaker ? Im not very technical minded !
    Thank you
    Arwel
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. This issue can be either due to a faulty door latch or door lock switch which is not engaging itself. And, if the door latch will not engage, the dishwasher will sense it as open door and will not start the cycle. The light also blinks when the dishwasher detects a no-fill condition. You’ll need to get access to the fill valve by removing left panel, look at back to see where valve is when you get to it remove one of the wires and set meter to ohms setting and put a lead on each tag on valve. The reading should be about 3.6k ohm. If you don’t get a reading then the valve is at fault. I'll also suggest you to check the detergent dispenser solenoid for this issue. Remove the door panel and see if there is a round item at the dispenser assembly with two wires attached to it. Put the dishwasher into a cycle and when the noise appears, gently press on the solenoid to see if that is where the noise is coming from. Please check the following --
1. Fuse (blown or tripped).
2. 120 VAC supply – wiring connection faulty. Repair or replace wire fasteners at dishwasher junction box.
3. Electronic control board faulty.
4. Motor (inoperative, check resistances).
5. Door switch (open contacts).
6. Door latch not making contact with door switch.
7. Touch pad circuit defective.
You may also put a large quantity of tap water inside bottom of the dishwasher and close the door and turn it on. It will clear any dry objects from the dishwasher water pump and it will function normally. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on May 02, 2010
  • Tecnik Master
  • 19,396 Answers
Hi.
Try tripping the circuit breaker, and removing water from inside (if any). While power is off, check the drain well at the bottom of the appliance.
Connect power back and see if the appliance works.
If the problem comes back after re-start, then there is a fault condition. In that case the machine must be tested.
Testing will start from inlet hose, ensuring that it is not kinked or blocked, and that there is sufficient pressure. After that , test float and pressure switch and pump. The timer board is the last part to be tested.
If you need repair or parts, call Tecnik at the number listed on the owners manual.
Regards.
Dimensions for tecnik 795/2
This dishwasher was made for tecnik (moben/kitchens direct) by bosch. Any Bosch, Siemens or Neff fully integrated 600mm dishwasher will replace this machine.
Apr 08, 2013 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
TECNIK TDK 795 FAULT
is there the power supply still to the washer??
Mar 01, 2008 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Tecnik Integrated 795/2
Unfortunately you may have lost the controller or if you are lucky just a loose wire. You can get to all of this by taking the door cover off. If it is not a loose wire the control would be my next best guess. Sometimes they just go.
Sep 06, 2012 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Trying to remove the decor door from my Tecnik 795/3. Removed the top two screws along the top of the door, and also the two long side screws half way down the door. It won't budge though so wondered...
I am not sure about which way the door comes off but I know of a company called Appliance Art that makes covers for existing appliances.
www.applianceart.com
These guys have all kinds of colors, textures, designs and stainless options for refacing your dishwasher--- then maybe you can save the hassle of removing the door at all.
Sep 24, 2011 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Hi, We have Tecnik Dishwasher TKD 795/3 it wont seem to drain the water, we have tried to clear the pipes but they seem to be clear, Can you give us any tips on how to sort this problem out? Thank you
Hi, if the water doesn't drain from your dishwasher, check the drain line and pump..
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Jun 25, 2011 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Water not draining
were is the drain plug located and how do we remove? help
Jan 25, 2008 | Frigidaire 25 in. FDP750RC Free-standing...
Tecnik integrated dishwasher 795/2
make sure all filters are clean.make sure the wash arms are not cracked at the seam.if all that checks good you could have an obstruction to the pump.also check to see if you lose any water when running a cycle because the drain valve may be stuck open.the other possibility is that the impeller on the pump is worn or broke.
Aug 27, 2007 | Frigidaire 25 in. FDP750RC Free-standing...
Tecnik 24 in. TKD795/3 Built-in Dishwasher Logo
141 people viewed this question
Top Tecnik Dishwashers Experts
Renee Knafel-Bullock
 Mikey
Mikey
Tom Chichester
Are you a Tecnik Dishwasher Expert? Answer questions, earn points and help others
