Question about Rosetta Stone V3 Spanish (Latin America) Level 1 Personal Edition (Win/Mac) for PC, Mac (1580228542)
Error 2213, rosetta stone will start to load then gives me an error, Have the latest Java, Shockwave, and Active x installed. This is off the webbased version from Skillsoft.
bunnydawg
  • 5158 Answers
SOURCE: Cannot recognize working microphone
go to control panel.... sounds.... make sure the microphone is not muted in the settings
Robert
Please take a moment to rate this solution thanks
Posted on Apr 21, 2009
laikexpert
  • 281 Answers
SOURCE: Rosetta Stone error 2123
1.)Open BitDefender Antivirus in Expert Mode,
2.)click on the Antivirus module
3.)under the Shield tab click on the Advanced Settings button.
(BitDefender Active Virus Control Settings window should be displayed)
4.)adding an exclusion for Rosetta Stone solved the problem
or
If you have any other antivirus software
adding an exclusion for Rosetta Stone solved the problem.
Posted on Jan 04, 2010
  • 10 Answers
SOURCE: rosetta stone won't recognize my logitech headset
Make sure that your device is set as your default device by making sure that there is a green check mark next to the device. If not, right click and select "set as default device" (or something like that... I have vista and not win7)
If that does not work, right click on the headphones and go to "Properties" then go and under the "General" tab, change the name of the device to "Microphone HS" For some reason, Rosetta Stone does not recognize the headset unless it has the word "Microphone" in its name... Kinda stupid if you ask me. Hope that helps...
Posted on Mar 03, 2010
SOURCE: I fave a microphone in my web camera. And Rosetta
I solved by going to Control Panel, Sound, Recording, then click on your mic and click on Configure, and then Set up microphone... Thats probably going to fix your problem... That easy... xD
Posted on Apr 27, 2010
SOURCE: Rosetta Stone Microphone Not Found
This worked for me:
1) Right click on the Rosetta Stone icon in the Start menu
2) Click the "Compatibility" tab
3) Set it to run in compatibility mode with Windows Vista SP2 (mine was defaulted to run in XP compatibility mode, which seemed to be the problem)
4) Start the program again, if you are lucky all mics will now show up
Posted on Jul 20, 2010
Error 9119, 9114 rosetta stone
When you install Rosetta Stone it puts its language files in a different folder. When you uninstall the program the language files are left intact and are never touched. If a problem occurs and one of the language files becomes corrupt and unreadable you're going to get that error 9119 every time when you try to re-install your language pack. Each language level has THOUSANDS of files in hundreds of sub-folders. Each file in those sub-folders has an hexadecimal name of 40 or more characters in length. So good luck trying to find the corrupt file(s). Also, because the file or files are corrupt, they can't be read or deleted. You're going to have to perform chkdsk on your hard drive to recover the bad sectors...eventually. The quickest and simplest way to fix your Rosetta Stone problem is to rename the folder where it puts its language files to something else. On an xp system the default name is "C:\Documents and Settings\All Users\Application Data\Rosetta Stone". I changed mine to "C:\Documents and Settings\All Users\Application Data\Garbage Files". That way when Rosetta Stone goes to install its language files it will recreate the folder cleanly instead of trying to overwrite the old folder and its corrupt files. That will solve your problem. You can then run chkdsk at your leisure and delete the Garbage Files. Good luck and spread the word.
Dec 29, 2012 | Rosetta Stone Computers & Internet
Rosetta Stone fatal error 1141
Reinstall. Check your language - corrupt files usually give this error.
You might want to install CCleaner and clear registry. Here's the link for CC: http://www.filehippo.com/download_ccleaner/
Sep 25, 2012 | Rosetta Stone Spanish (Spain) v4 TOTALe...
Rosetta stone error code 3217
You should contact Rosetta Stone's customer support directly. They are excellent in helping with your computer issues. Phone number is 800-280-8172.
Sep 25, 2012 | Rosetta Stone Spanish (Latin American) -...
Loaded Start disc. When installing my language disc 1, I get an 9123 error code and a message " there was an error in the application". I cannot uninstall, because I get messages "...
Version 3/4: Error 9123 during Language CD installation
This error message relates to Version 3 and Version4. If you receive a 9123 error message during language installation, try one of the following resolutions:
  • Clean the disc with alcohol/windex/water and a soft cloth and try installing again.
  • Disable your internet security program, especially Norton or Symantec Security and try installing again.
If you are still experiencing this error, please contact Rosetta Stone Support
Dec 23, 2010 | Rosetta Stone Chinese Mandarin Level I &...
Error 2123 appears when loading rosetta stone
I started getting "Error 2123" recently, and spent A LOT of time searching for the fix. Here is what finally worked:
Find the hidden file "tracking.db3". It's in the hidden folder "ProgramData/Rosetta Stone" under the "C:" directory. Copy and paste it to the Rosetta Stone install directory (Program Files/Rosetta Stone).
Error 2123 should be gone, but now there will be Error 2125. So, in the Rosetta Stone install directory, run the "service_installer" .exe file by double-clicking it.
Feb 20, 2010 | Rosetta Stone Japanese Level 1 & 2 for...
I installed Rosetta Stone and got the error 2123, is this a driver problem?
Hello my friend.Usually this error is cause because antivirus is blocking that program and usually bitdefender.So
1.Open BitDefender Antivirus in Expert Mode,
2.Click on the Antivirus tab
3.Under the Shield tab click on the Advanced Settings button.
4.Now add an exclusion for Rosetta Stone(click on + and find your program and click ok)
If you don't have bitdefender add an exclusion like we did with bitdefender for your rosetta stone
Feb 08, 2010 | HP Computers & Internet
After uploading the application software for Rosetta Stone, I try and start the application and I receive: there was an error in the application. error 2123. How do I fix this problem for my iBook G4...
Feb 02, 2010 | Rosetta Stone Spanish Spain Level I & II...
There is an error with this application
Nov 23, 2009 | Rosetta Stone V3 Spanish (Latin America)...
or
Jun 16, 2009 | Rosetta Stone V3 Spanish (Latin America)...
Facebook picture won't load
Create another User for your windows with administrative rights and delete the user you are currently using.
May 20, 2009 | Facebook Social Network
Rosetta Stone V3 Spanish (Latin America) Level 1 Personal Edition (Win/Mac) for PC, Mac (1580228542) Logo
965 people viewed this question
Top Rosetta Stone Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
IT GURUS OF ATLANTA
IT GURUS OF ATLANTA
k24674
Are you a Rosetta Stone Computer and Internet Expert? Answer questions, earn points and help others
