Question about Grohe Integrated 1/2'' Shower Thermostatic Rough-In Valve With Stops - 3412
I have a grohe power shower wich only has cold water coming out. if i replace the thermo catridge will this solve the problem
    Scholar:
  • 102 Answers
It has been a while since I have worked on a Grohe, But if it has a built in scald gaurd or thermo cartridge, it may be sticking and need to be replaced.
Posted on May 05, 2010
Could my grohe thermostatic shower be letting cold water into my system? Some other taps run cool but the shower is running OK temperature
If you have single handle facute one bad cartridge in the system may be acting like a mixing valve and allowing cold water to mix with hot not allowing water to get hot enough .
Mar 10, 2015 | Grohe Water Heaters
Why is there no hot water, only cold water coming out the mixer valve?
Sounds like the screen is plugged or the check stop is not working correctly
May 28, 2014 | Grohe Grohtherm Thermostatic Rough-In...
Got a gocta w-26mixer shower bar fitted cold tap
from a plumber all hot and cold connections on all major showers are hot on the left and cold on the right just like the taps on your sink or washbowl
Dec 09, 2009 | Grohe Integrated 1/2'' Shower Thermostatic...
Grohe shower. I want to adjust the temp mixing valve. I can not get cold water. It is always a mix-never pure cold. I want cold water. How do I adjust it?
if you pull the handle off all the way back to the valve body there is a little black stopper around the cartridge body that you can adjust by pulling it out and sliding around the cartridge body this enables people to just turn the handle to one setting and jumpping in to their favorite temperature. in your case it doesn't allow you to have any cold water. so turn it one way see if you get what you want or try the other or some of them you can even just take the darn thing out and not even have to worry about it
Jul 29, 2009 | Grohe Integrated 1/2'' Shower Thermostatic...
I have exactly the same problem
you need to change the cartridge, it is a temp control and is going bad so it keeps you from burning yourself it is like a mixing valve and is givng more cold water, that way you don;t get burned,,
Jun 18, 2009 | Grohe Integrated 1/2'' Shower Thermostatic...
Grohe bath faucet adjustments
grohe is a faucet all by itself ,,, I would recomend to have you call there repair dept. and explain this to them, you said you put in the new cartridge and thats about all there is to it, when you put on the handle make sure it is not over tightened, sometimes it pulls on the cartridge and makes it come on by itself good luck
Feb 21, 2009 | Grohe Integrated 1/2'' Shower Thermostatic...
Grohe Thermostatic Valve
the temp, control valve is getting to hot!!! there for only let so much hot water go thru, did you take the inner parts out when soldering this in, if not you might have damaged it, and if so need to replace the cartdrige
Feb 10, 2009 | Grohe Integrated 1/2'' Shower Thermostatic...
Grohe Integrated 1/2'' Shower Thermostatic Rough-In Valve With Stops - 3412 Logo
609 people viewed this question
Top Grohe Water Heaters Experts
Paul Carew
ray gallant
Shimon David
Shimon David
Are you a Grohe Water Heater Expert? Answer questions, earn points and help others
