Question about Maytag EPIC MFW9700S Front Load Washer
Maytag epic II washer error codes, especially error code F 21
  • 6,784 Answers
HI. Click here to download the complete service manual for this unit. All the repair procedures and error code definitions can be found in this repair manual. I would advise to save this PDF to your HD for safe keeping.
Posted on Aug 24, 2010
What does F- and 21 mean
Error code F 21 means the drain is clogged...follow this advise for the Whirlpool washer as Maytag was bought by them
there is also this site for the washers http://fixedappliance.blogspot.ca/2011/11/whirlpoolkenmoremaytag-more-f02f21-sd.html
Jun 04, 2015 | Maytag EPIC MFW9700S Front Load Washer
Maytag epic Z Washer shuts down at spin cycle
F21 usually indicates a pump problem however when that is not the problem then the place to look is the board itself as there is a mis communication between it and pump cycle? If the pump cannot operate it will not allow it to go into the spin.
Jan 13, 2015 | Maytag Epic Z and Performance Series 2000...
F11 error code
The F11 code means there is an electrical with the Maytag Epic washer. This could involve wiring, fuses or a number of other issues.
Press the "Pause" button twice to stop the current cycle. Press the "Drain" button to remove any excess water. Try to run the washer again. If the F11 code repeats, shut the washer off and contact a service agent
The FH error code may be mistaken for the F11 code. The FH code signals a water supply issue and has nothing to do with electrical problems. Check the LCD screen to ensure you read the proper code
Dec 28, 2010 | Maytag EPIC MFW9700S Front Load Washer
Washer display flashing error code f-21
The F21 code on the Maytag EPIC is telling you there is a pump problem.
The pump impellers should be checked. There should be four of them.
Sometimes the impeller blades can be broken by coins, etc.
Make sure that the pump is clear of debris, to do this:
Remove the discharge hose, and blow through it.
If after clearing of water, the hose doesn't blow free and clear, you have something stuck in there.
You will need to clear the pump of the item that is stuck inside.
Good Luck,
I hope this helps,
Please rate me,
Thank you
Dec 02, 2009 | Maytag EPIC MFW9700S Front Load Washer
F 21 error code? Maytag epic z washer
The F21 code on the Maytag EPIC is indicative of a pump problem. The pump impellers should be checked, there should be four of them. Sometimes the impeller blades can be broken by coins, or other items. Make sure that the pump is clear of debris, then remove the discharge hose, and blow through it.
If after clearing the initial slug of water, the hose doesn't blow free and clear, you have something stuck in there.
Nov 28, 2009 | Maytag EPICz Electric Dryer
Maytag Epic Z with error codes F20 and F24
my epic will start & wash & then gets F 20 & won't drain until I hit start again
Oct 16, 2009 | Maytag EPIC MFW9700S Front Load Washer
Maytag Epic giving F11 error code!
ths.gardenweb.com/forums/load/.../msg1012004912002.html
Jun 22, 2009 | Maytag EPIC MFW9700S Front Load Washer
Maytag Epic Z frontloader Error Code F20 Help Please!!!
i also have a magtag epic z &f 24 error code is on my washer. i don't know what to do.
Jul 01, 2008 | Maytag Washing Machines
Maytag Epic Z error code
I need a clear code for maytag epic z front load washer
code f-o1 is coming up
says intall new ccu, I did but still the same
do I need to clear the code if so how.
please tell me.
Jun 16, 2008 | Maytag EPIC MFW9700S Front Load Washer
Maytag EPIC MFW9700S Front Load Washer Logo
776 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
