Question about Sagem PVR 6280 Freeview DTV Receiver / 40-Hours Video Recorder
I have a sagem DVR 62160 SL-UK set top box. The display shows 8888 and does nothing else. I have tried unplugging the unit, but when turned on the display still shows 8888, any ideas would be appreciated. I do not have the manual for the unit.
  • Anonymous Mar 18, 2014
    set top box displays 8888
There is no display on the digibox and it makes a whirring noise
Posted on Sep 22, 2010
My Sagem DVR 6200T box is not working. The motor
Same thing happened to mine, problem is insufficient power to machine - solution is to purchase a new Power supply unit (lead
Jul 06, 2010 | Televison & Video
Screwed up
Try first unplugging tv and box from power for ten minutes.
Give details on tv model and equipment used.
Oct 13, 2008 | Fortec Star Lifetime ULTRA
Er09 and Er07 black screened
Turn off the unit for 15 mins.
Turn back on with eveything connected except the antenna.
You will get an er 09 on the display.
Press OK on the remote.
With a bit of luck the box will reboot into standby.
Connect antenna and see how you get on.
Jan 07, 2010 | Sagem PVR 6280 Freeview DTV Receiver /...
My sagem dvr62160sl uk digital reciever wont work
A number of Sagem models have shown incompatibilities with the recent Freeview retune, there is a list of affected models (see http://news.bbc.co.uk/1/shared/bsp/hi/pdfs/01_10_09_freeview2.pdf ) but it's not a fully comprehensive list. Sagem error code 07 means there's an access problem in back-up memory (stored in the EEPROM) and code 09 means the machine has been unable to find any data necessary to do an upgrade. In essence, your box has tried to upgrade itself and failed and now cannot restore to it's previous state.
Your dvr62160sl is closely related to the dtr6240 and 6280 models which are known to have had issues and so the official advice is to contact Sagem directly on 0845 0900 316 to find out how whether they can supply a solution on a dvd or if they've scheduled an OAD (over air update).
I hope that you've found my posting to be of use and ask only that you return the favour by rating my answer.
Oct 23, 2009 | Televison & Video
Problem retuning Sagem PVR6240T set top box
Hey Agoodwin,
Looks like you have missed the final software updates for the PVR72xx and 62xx series last year. The bad news is that Sagem are not likely to send another update for their old models. If you check your box settings and you have software version 0.4.5. or less, your box will probably not work again. Sorry, mate...
Oct 05, 2009 | Televison & Video
My sagem DVR 6200T UK is now displaying when switched on P603 then it goes to ER07 this started last night.There seems to be no signal to the TV from the set top box and the remote wont work! i have...
Hi I had the same problem P603, er07 and er09, solved it by buying a 12v adaptor, you dont have to use sagem, in fact they are not very helpful, they will only take credit cards and it will cost you £15.00, any 12v adaptor will do. Mine is working perfectly now
Sep 26, 2009 | Televison & Video
Sagem dtr 6400t makes a whirring sound when you turn it on as if it is loading but nothing else happens. No screen is loaded so cant access any menus or anything
My Sagem DVR 6200T/6400T developed this problem. Initially, over a few days when I tried switching on the box via the normal button on the remote, the display would we black (no readout) but the box still made a whirring noise as if it was working and it would take about upto 15 mins for the display to come on and then I could use the remote as normal. After doing this for a couple of days the display evenutally stopped appearing, so the box would keep on making a whirring sound as if its was trying to initialise but nothing would be displayed on the readout and nothing happens if you press the handset. I tried turning it off and on at the mains plug, plugging the connections in and out of the box and television and at one point gave the box a 'smack' out of frustration. Amazingly I momentarily got a flashing error message:- either pb03 or p603 which upon looking online (for ages) apparently means an initialising error which seemed to make sense. NOTE- I do not recommend other people try 'beating up' their box. Anyway, this error never reappeared after turning the box off and on at the mains plug. After further research someone on this fixya site said try changing the Sagem adapor cable. I found an old external hard drive and the adaptor cable, which has the same input and output information as written on the Sagem AC/DC adaptor cable fitted and my sagem box now works fine again. And to think I was on the verge of paying out over £139 for a new box and amazingly all that was wrong with the old box was the cable! Points to note about using a different cable:- make sure the part that plugs into your box is the same size. Another adaptor I had rooted out from an external cd drive worked but it kept on switching the box off because the connection into the box (round plug) was slightly too small. The input should be 100-240V-50/60Hz and the output +12V=2.0A. Apologies for writing so much but because I no nothing about electrics I am trying to explain what I mean in laymens terms. I also suggest if you are in doubt, take your old cable into an electrical store like Maplins and get the advice you need about a new cable that is the same input and output as your sagem adaptor cable so that you do not plug in an AC/DC adaptor that could do further damage. AC/DC adaptors do not cost much and you may find that an universal adaptor set correctly may work.
I would like to thank the person who posted the solution because it worked for me and has saved me a lot of money.
Jul 12, 2009 | Televison & Video
My sagem DVR 6200T UK displays ER 07 on the box
I HAVE HAD SAME PROBLEM. I HAVE TWO OF THESE RECORDERS AND ONE IS OK. I SWAPPED THE POWER LEADS FROM THE GOOD ONE TO THE ONE THAT IS NOT WORKING AND IT WORKED SO ALL YOU NEED IS A NEW POWER LEAD FROM SAGEM IN FRANCE.COST £10 PLUS POSTAGE.
CHEERS
Dec 17, 2008 | Televison & Video
Sagem pvr 6200T UK freeview box, display frozen.
I left the box and went for a walk!!!
About four hours after having freezed an error 09 message came up on the set top display and then everything returned to normal, after an on TV screen message that update had been successful.!?!
No difference in in any operation of the freeview box.
Note to self and other users
DO NOT PRESS OK WHEN ASKED TO UPDATE SET TOP BOX.
Updating the channel tuning does seem to work ok, though I have to vary between where channel 4 can be found - or learn welsh!
Jul 19, 2008 | Televison & Video
Manual Needed.
Google It they are all there.
Dec 27, 2007 | Televison & Video
Sagem PVR 6280 Freeview DTV Receiver / 40-Hours Video Recorder Logo
954 people viewed this question
Top Sagem Televison & Video Experts
Andy Fraser
Andy Fraser
electracon
ka4iup
ka4iup
Are you a Sagem Televison and Video Expert? Answer questions, earn points and help others
