Question about Sony CDX-S2200 CD Player
CDX-S2200 fitting to old golf
Hi how to i fit a sony CDX-S2200 to a 95 mk3 golf the block connectors do not match the ones on the new head unit. even though the old radio is also sony
thanks m
  • 2 more comments
  • superqaz May 02, 2010
    it says u want clarification???
    anyway, thanks for the info, i assume then,that there is no wiring harness adaptor availablen for this job
    thanks again mark
    thanks again mark
    yes i'll just get some connectors. the harness adaptors are qiute plentiful and adapt older terminal blocks to the new standard , so u can just swap radios quickly
    cheers mark
  • uno_1 May 11, 2010
    the older sonys used a different style connector... the wire colors should all be the same, (assuming the old one was wired properly) just match the colors of the new harness to the old one and splice them...
    Scholar:
  • 84 Answers
Haha, yea sorry about that must have clicked the wrong button... if they spliced that old sony harness to the factory harness and did not cut the factory plug off then you can go to you local bestbuy or car audio store and get an adapter for your factory harness... but, if you have the tools and the time, its faster and cheaper just to hardwire on the new one... as for an adapter to convert the old sony to the new sony plug... ive never seen an adapter for that...
Posted on May 02, 2010
Testimonial: "thanx"
Vw golf gti mk3,clutch pedal has broke plastic parts off but looks like would go back together if i knew how it looked before,help!
no its a new clutch cable for this vehicle as its auto adjust cable ,so when new one is fitted do not remove the clamping piece of wire in the middle of the cable till its all fitted
Apr 24, 2011 | 1997 Volkswagen GTI
Need a pic of wiring up to my van as some idio cut most the things off before i bought it,,,, iv got the sony cdx s2200 i want to put in.
The best advise I can give is to use the connection that you baught and cut of the end that connects to your VAN then you need to isolate the correct leads from your car. The chances are that they wont be the same colour so if you can get your hands on a voltmeter you should be able to find the correct leads. The manual for the stereo should tell you the correct colour wires for the head unit red=live black=neg.
Additionally, send us details about brand, year and model of your VAN, could be there some wiring diagram.
Keep in touch.
Apr 06, 2011 | Sony CDX-S2200 CD Player
Have just got sony CDX-S2200 can I connect my mp3 player to it and where can I get manual?
I dont think you can plug in mp3 but here is the manual download http://www.sony.co.uk/product/ica-cd-tuners/cdx-s2200#pageType=manual
Mar 24, 2010 | Sony CDX-S2200 CD Player
MEX-BT5700U, no sound in speakers in CD source, tuner source OK.
What many people do on this model is connect the remotes wires improperly. Use the solid blue wire for the amp and the blue with white stripe for the connection to the car.
Dec 06, 2009 | Car Audio & Video
Need to know how to change an alternator belt tensioner on golf mk3
There is long bolt under an alternator with 6 or 8 allan key head and on another side have nut - 13 spaner.The bolt going out thru a fan blades.
Dec 01, 2009 | 1996 Volkswagen Golf
RADIO STATIONS WONT STAY
This is simple the memory wire (yellow) is connect incorrectly. It needs 12 volt constant or continously. meaning 12 volts even when the car is off.
Dec 06, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
Sony CDX-S2200 CD Player Problem
Please press Reset switch in CDX-S2200. You can see it if you de-attache front panel.
If problem still exist, then you need to replace IC300 " 6-705-360-02 " IC TDA8588BJ/N2/R1
Oct 02, 2008 | Sony CDX-S2200 CD Player
Sony cd changer cdx-646...no card remote commander to release security code
Hi the CDX-646 is not coded. it must be your head unit thats coded.what model is the head unit?
you can get your code @ www.carradiocode.co.uk
for 33.50 if its one of the models listed you will nedd the remote comander tho.
Mark
www.blueice-electronics.co.uk
Feb 24, 2008 | Sony CDX-646 10-Disc CD Changer
No display on sony cdx-m8800
if the remote makes it work and it plays ....if all functions work other than display check for bad solder joints on the display pay  attention to the ones on the corners if the unit is or was a tight fit in the dash its possible that the unit got a little stress and broke loose from the board .... if there is a white powder look in the display it probably bad... the silvery black in the corners is normal
Oct 28, 2007 | Sony CDX-M8800 CD Player
Sony CDX-S2200 CD Player Logo
293 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
