How can i correct DNs server code80710102 because we cant connect to the ps3 or the computer
  • 304 Answers
Check your internet connection if it is working properly.
Posted on May 02, 2010
I have been tring to connect to wireless internet all day with my ps3 and it ethier says my WPA key may be incorrect or errorhas occurred (8013013D)
that is not a problem and i will be glad to assist you. If this doesnt work please follow up with a comment and i can give you instructions on what to do next.
This error code is caused by a connection time out when attempting to connect to the Domain Name Server (DNS). If you are seeing this code you should check the following: • Do you have a working internet connection (can you connect successfully using a PC)? • Reconfigure your network settings (delete existing settings and create new ones) • Does your Internet Service Provider (ISP) prohibit access to secure pages as a default setting? (this may lead to failures when accessing system software updates) • Within network settings, is the Primary DNS being detected? If the ‘Primary DNS’ is displayed as 0.0.0.0 or is blank, the DNS is not being detected automatically. If this is the case you should contact your ISP and ask for the ISP’s DNS address. This DNS address should then be manually input into your network settings. Following all of these steps your PS3 should now be able to get online.
to find your dns in windows > Start
> Run
> command
> ipconfig /all
Then the DNS Server(s) being at the bottom
If it still doesnt work let me know your router model number. Also ensure your WPA key is correct and that its not wpa2 as depending on the model most playstation 3's cant use wpa2. that way if you provide me with your router i can ensure that everything will work with each other and determine the best security settings to get your computer online
If you need further assistance or help with anything please let me know and i will be glad to guide you through any assistance you may need.
Aug 28, 2010 | Sony Playstation 3 (PS3) Console
PS3 says DNS error (80710102) when i try to connect to the internet with a wired connection
Goto the command prompt bar in the start menu type ' cmd ' then click o.k . A black dos screen will appear type in ' ipconfig/all ' and it will the the two servers you need under dns servers but if your doing a wired connection to your ps3 then you need to manually configure your dns on the custom method of setting up your internet connection on your ps3 as if this is auto config that will give you a dns error. Hope that helps ,I can go into more detail and guide you through it if need to .
Jun 02, 2009 | Sony Playstation 3 (PS3) Console
DNS Problem On PS3
try setting up your network in auto.
go to internet connection setting an select easy, it should setup itself.
May 02, 2009 | Sony Playstation 3 (PS3) Console
.trouble with playstation 3 getting on line through router...
It looks like there are a lot of DNS servers that do not work correctly with the PS3. Below I will list a few DNS servers that do seem to work and you will need to manually configure the DNS settings for your PS3 to any of these addresses.
208.67.222.222
208.67.220.220
129.250.35.250
129.250.35.251
4.2.2.1
4.2.2.5
Nov 01, 2008 | D-Link DI-604 4-Port Cable/DSL Router...
Cant get internet connection on my ps
first check wether you received a valid ip address for your local network. usually, this should be something like 192.168.x.y. if so, then you might indeed face a dns issue. dns is used to resolve web site names to ip address. usually, your ip service provider will broadcast the external dns servers for your router to recognize.
try to connect with a computer first. if it works, check the ip settings. if your computer also cannot connect without explicit dns server settings you can do one of the following:
- explicit dns server address in ps3. go to "advanced internet connection settings", and then to "dns settings" and set the dns server address
- purchase a 30$ network router and hook it between your internet and the ps3. in the router settings, set the dns server address to be broadcasted to the clients. you can use 168.126.63.1 and 2 which are dns servers in korea (i live in korea), but you might want to find the server near to your location or promoted by your isp
Jul 28, 2008 | Sony Playstation 3 (PS3) Console
Cant get internet on ps3
make sure that the ip address that you are getting is a valid one and you are connected to the correct wireless network. for example, if your router's ip address id 192.168.1.1, your computer should have an ip address of 192.168.1.x. if you are getting a valid ip address and you're still getting the dns error, the thing that you can do is set a static ip address and dns to your ps3.
if you don't know the dns to use, go to the command prompt and type ipconfig/all and it'll give you a list that'll contain the dns servers. copy the dns and enter it on the ip settings of your ps3 together with the default gateway (ip address of the router), subnet mask (it's usually 255.255.255.0) and your ip address (make sure that the ip address that you'll set on the ps3 is not being used by any of your computers)
hope this'll help you and just ask me if your still having any problem
ciao!
Jul 05, 2008 | Blitzz Technology BWA711 (B3WL000900)...
PS3 Networking HELP
The way this was resolved for me (and I know someone else mentioned it in an other post here), was to enter the DNS server addresses manually in the PS3 network settings AND use tetertiary DNS server from my ISP as either the primary or the secondary DNS server. Voila... I am upgrading my PS3 software as I write this.... ..btw, this also fixed the similar problem I had with my PSP..
Jan 13, 2008 | Sony Playstation 3 (PS3) Console
for mine i tried other fixes and they didn't work. Turns our my router had enabled security but the PS3 had forgotten the password (WEP key).
I turned off the WEP on my router and the PS3 suddenly found its connection.
To say I was getting stressed is an understatement, Sony should put something on their website, it seems like a really commonm problem to which people have no clear route to solution.
Dec 21, 2007 | Sony Playstation 3 (PS3) Console
Internet Connection Problem
hi you could try here http://uk.playstation.com/help-support/psp/
see if any clues as to why you cant connect
riz.
Oct 27, 2007 | Sony Playstation 3 (PS3) Console
Computers & Internet Logo
51 people viewed this question
David Payne
David Payne
