Question about Canon Selphy CP510 Thermal Photo Printer
Canon Selphy C510 connected and has driver but does not print from computer file. Prints fine direct from camera......
  • 304 Answers
Copy all the files to the computer then unplug your camera. It will print your files from the computer. Dont forget to check your printing settings.
Posted on May 02, 2010
Only half of the picture prints on my selphy cp 730 canon printer
Nov 01, 2014 | Canon SELPHY CP730 Thermal Photo Printer
Cp810 problem white line pictures
I am having the same issue with my cp910 and i believe it is caused by dust inside that for whatever reason is not coming out when running multiple prints to try and clear it. I have looked up a couple of videos to help me take apart mine but the cp910 seams to have a security screw in one of the corners but i think you'll find that yours does not and you should be able to take it apart fairly easily to give it a clean and that should hopefully sort your problem :)
Jan 09, 2014 | Canon SELPHY Office Equipment & Supplies
Problem in setting the printer spooling of my two cp800
1-800-243-0019 Call on our Toll Free Printer Support Number and we providing best service for resolve all printer spooling of my two cp800 issues.
Apr 14, 2017 | Canon SELPHY CP800 White Compact Photo...
When trying to print from my mac an event warning come up stating specified ink cassette and paper not found. However, printer works when printing photos directly from camera
check the driver to be sure it is good, your computer control panel to be sure it is the designated printer and then try a virus scan...
Best regards
Ck
Mar 06, 2011 | Canon SELPHY CP720 Thermal Photo Printer
Canon Selphy 710. The rollers don't grab the paper. Can this be fixed or do I have to buy a new printer? The drivers are up to date.
Had the same problem after not using the printer for many months. Removed the feed tray and blew into the printer. Then printed something but gently pushed the paper a few mm until the printer took it. Obviously top of the paper tray has to be removed for this. Expected to have to do this every time, but after four prints (which incidentally were perfect) it now works like a dream, taking the paper without attention.
Dec 15, 2010 | Canon SELPHY CP710 Thermal Photo Printer
Vista will not load drvers for my selphy 510
You could download the driver from Canon support: (select your operating system from the drop-down box)
Canon Selphy C510 Downloads
I hope this helps!
Mar 14, 2010 | Canon Selphy CP510 Thermal Photo Printer
Question Mark Appearing on Canon Selphy printer screen
I encountered this issue with a Selphy CP800 and I presume the reason is the same; it seems to be a common problem. Canon tech support says that Selphy printers need exif data "just so" in order to generate screen previews. If all you do is copy your image to a flash memory device from your camera card, you may well be OK. But if you edit the images (e.g. in Photoshop) you will very likely alter the exif data so that Selphy cannot generate previews from flash media plugged into Selphy. If you are copying images back to a **camera** SD card you may also have to make sure that you don't alter the file structure already present on the card. There are undoubtedly other ways to louse up the exif data of an image so that you can't get a screen preview. Workarounds: 1) official Canon advice is to print the image directly from your computer - that's what tech support told me; 2) if you own Canon's Digital Photo Professional Software you can rebuild the exif data by using File>Convert and save>kind of file = exif-jpeg - this worked for me; 3) Graphic Converter for Mac now has a way of rebuilding exif data according to a poster on the Apple discussion boards; I could not test this out b/c my (old) version of Graphic Converter, 5.4, does not have this capability; 4) if you get a screen question mark, the image will still print - you just can't see the preview. This is only a problem if there's more than one image that generates a question mark on your flash media device because you can't see what image you're printing. So if all else fails and you have to print from flash media, you can put a single image with screwy exif data on a flash drive and be confident that you know what you're printing.
Jul 30, 2009 | Canon SELPHY CP740 InkJet Photo Printer
Selphy ES1 printer switches on,
remove all the connection go to control pannel printer and default ur Selphy Es1 printer
Jun 18, 2009 | Canon SELPHY ES1 Thermal Printer
Selphy 510 won't print from computer, print ok from camera ...
Did you download and install the proper Vista driver from Canon's website? If not, I would suggest that. If you have, then try opening the device manager and look for the printer. Reinstall the driver and just direct it to look in the proper folder for it.
Apr 07, 2009 | Canon Selphy CP510 Thermal Photo Printer
Trying to find a printer to go with my new laptop
You may want o try this cannon.Less than a hundred bucks..Canon Selphy CP760 Reviewed on 05/28/2008 The bottom line: The Canon Selphy CP760 takes the pain out of printing photos with its plug-and-play design and straightforward usability, and the $100 price tag makes it an excellent companion printer for quick prints in the home. Read review
Specs: Compact photo printer - Dye sublimation - Color, 4 in x 8 in, Wired, PC, Mac, USB, Direct print USB RICHARDM69
Dec 01, 2008 | ASUS Computers & Internet
Canon Selphy CP510 Thermal Photo Printer Logo
313 people viewed this question
old marine
old marine
