Question about Microsoft Windows Vista Ultimate Edition
How to Fix Bad Sectors on a Hard Disk in windows? I have windows 7
  • 304 Answers
Defrag your pc. go to system tools and use disk defragementer and disk cleanup.
Posted on May 02, 2010
Lenovo S100 keeps on having disk errors
You could run the chkdsk disk utility Click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your Hard Drive. or an easier way to run the chkdsk utility Windows 7 chkdsk http://www.w7forums.com/use-chkdsk-check-disk-t448.html Click start control panel administrative tools computer management ,disk management right click on your drive select properties click tools click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now, start should schedule this task when restart have no input while the chkdsk utility is in progress any input may further damage your computers Operating System and Hard Drive
Feb 12, 2013 | Lenovo IdeaPad S100 Atom N455 1.66GHz 1GB...
Tip
How to use the disk error checking utility...
As you use your hard drive, it can develop bad sectors. Bad sectors slow down hard disk performance and sometimes make data writing (such as file saving) difficult, or even impossible. The Error Checking utility scans the hard drive for bad sectors, and scans for file system errors to see whether certain files or folders are misplaced.If you use your computer daily, you should run this utility once a week to help prevent data loss.
  1. Close all open files.
  2. Click Start, and then click My Computer.
  3. In the My Computer window, right-click the hard disk you want to search for bad sectors, and then click Properties.
  4. In the Properties dialog box, click the Tools tab.
  5. Click the Check Now button.
  6. In the Check Disk dialog box (called Error-checking in Windows 7), select the Scan for and attempt recovery of bad sectors check box, and then click Start.
  • If bad sectors are found, choose to fix them.
  • Tip: Only select the "Automatically fix file system errors" check box if you think that your disk contains bad sectors.
    on Jun 10, 2010 | Computers & Internet
    Tip
    By following a few simple guidelines, you can maintain your computerand keep it...
    By following a few simple guidelines, you can maintain your computerand keep it running smoothly. This article discusses how to use thetools available in Windows 7, Vista, and XP Service Pack 3 (SP3) tomore efficiently maintain your computer and safeguard your privacy whenyou're online.
    1. Free up disk spaceThe Disk Cleanup tool helps you freeup space on your hard disk to improve the performance of your computer.The tool identifies files that you can safely delete, and then enablesyou to choose whether you want to delete some or all of the identifiedfiles.
    Use Disk Cleanup to:
    • Remove temporary Internet files.
    • Remove downloaded program files (such as Microsoft ActiveX controls and Java applets).
    • Empty the Recycle Bin.
    • Remove Windows temporary files such as error reports.
    • Remove optional Windows components that you don't use.
    • Remove installed programs that you no longer use.
    • Remove unused restore points and shadow copies from System Restore.
    Tip:Typically, temporary Internet files take the most amount of spacebecause the browser caches each page you visit for faster access later.
    2. Speed up access to dataDisk fragmentation slows theoverall performance of your system. When files are fragmented, thecomputer must search the hard disk when the file is opened to piece itback together. The response time can be significantly longer.
    DiskDefragmenter is a Windows utility that consolidates fragmented filesand folders on your computer's hard disk so that each occupies a singlespace on the disk. With your files stored neatly end-to-end, withoutfragmentation, reading and writing to the disk speeds up.
    When to run Disk Defragmenter
    In addition to running Disk Defragmenter at regular intervals—monthlyis optimal—there are other times you should run it too, such as when:
    • You add a large number of files.
    • Your free disk space totals 15 percent or less.
    • You install new programs or a new version of Windows.
    3. Detect and repair disk errorsIn addition to running DiskCleanup and Disk Defragmenter to optimize the performance of yourcomputer, you can check the integrity of the files stored on your harddisk by running the Error Checking utility.
    As you use your harddrive, it can develop bad sectors. Bad sectors slow down hard diskperformance and sometimes make data writing (such as file saving)difficult, or even impossible. The Error Checking utility scans thehard drive for bad sectors, and scans for file system errors to seewhether certain files or folders are misplaced.
    Run the Error Checking utility:
    7. If bad sectors are found, choose to fix them.
    4. Protect your computer against spywareSpywarecollects personal information without letting you know and withoutasking for permission. From the Web sites you visit to usernames andpasswords, spyware can put you and your confidential information atrisk. In addition to privacy concerns, spyware can hamper yourcomputer's performance. To combat spyware, you might want to considerusing Microsoft Windows Defender, which is included in Windows 7 and Windows Vista, and is available as a free download for Microsoft XP SP2. Alternatively, there are other free anti-spyware software programs available.
    5. Learn all about ReadyBoostIf you're using Windows 7 orWindows Vista, you can use ReadyBoost to speed up your system. A newconcept in adding memory to a system, it allows you to use non-volatileflash memory—like a USB flash drive or a memory card—to improveperformance without having to add additional memory.
    on Jan 07, 2010 | Computers & Internet
    Hd502hj problem
    Windows 7 can be a pain it always seems to think the large drives are damaged whether external or usb drives.
    You could run the chkdsk disk utility Click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive or an easier way to run the chkdsk utility Click start control panel administrative tools computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart have no input while the chkdsk utility is in progress any input may further damage your computers operating system and Hard Drive. Hope this helps.
    Dec 18, 2012 | Samsung Computers & Internet
    My transcend storejet has bad sectors.. what should i do to prevent it from getting worst?.
    These sectors can be fixed.
    1. For Windows
      • 1 Double-click on My Computer to open the My Computer window.
      • 2 Select the disk that you want to diagnose and repair.
      • 3 Choose Properties from the File menu. You should see the Properties window for the drive that you selected.
      • 4 Choose the Tools tab.
      • 5 Click the Check Now button under Error Checking Status.
      • 6 Depending on your version of Windows, choose either "Thorough" or "Scan for and Attempt Recovery of Bad Sectors."
      • 7 Click on Start.
    Read more: How to Fix Bad Sectors on a Hard Disk ' eHow.com http://www.ehow.com/how_113636_fix-sectors-hardfix-sectors-hard.html#ixzz1PeS42ET5
    Jun 18, 2011 | Transcend StoreJet 25 Mobile 500GB USB 20...
    Tip
    on Jan 02, 2010 | Computers & Internet
    Tip
    5 ways to speed up your computer
    By following a few simple guidelines, you can maintain your computer and keep it running smoothly. This article discusses how to use the tools available in Windows 7, Vista, and XP Service Pack 3 (SP3) to more efficiently maintain your computer and safeguard your privacy when you're online.
    1. Free up disk spaceThe Disk Cleanup tool helps you free up space on your hard disk to improve the performance of your computer. The tool identifies files that you can safely delete, and then enables you to choose whether you want to delete some or all of the identified files.
    Tip: Typically, temporary Internet files take the most amount of space because the browser caches each page you visit for faster access later.
    2. Speed up access to dataDisk fragmentation slows the overall performance of your system. When files are fragmented, the computer must search the hard disk when the file is opened to piece it back together. The response time can be significantly longer.
    Disk Defragmenter is a Windows utility that consolidates fragmented files and folders on your computer's hard disk so that each occupies a single space on the disk. With your files stored neatly end-to-end, without fragmentation, reading and writing to the disk speeds up.
    In addition to running Disk Defragmenter at regular intervals—monthly is optimal—there are other times you should run it too, such as when:
    3. Detect and repair disk errorsIn addition to running Disk Cleanup and Disk Defragmenter to optimize the performance of your computer, you can check the integrity of the files stored on your hard disk by running the Error Checking utility.
    4. Protect your computer against spywareSpyware collects personal information without letting you know and without asking for permission. From the Web sites you visit to usernames and passwords, spyware can put you and your confidential information at risk. In addition to privacy concerns, spyware can hamper your computer's performance. To combat spyware, you might want to consider using Microsoft Windows Defender, which is included in Windows 7 and Windows Vista, and is available as a free download for Microsoft XP SP2. Alternatively, there are other free anti-spyware software programs available.
    5. Learn all about ReadyBoostIf you're using Windows 7 or Windows Vista, you can use ReadyBoost to speed up your system. A new concept in adding memory to a system, it allows you to use non-volatile flash memory—like a USB flash drive or a memory card—to improve performance without having to add additional memory.
    on Jan 01, 2010 | Computers & Internet
    WON'T LOAD ON WINDOWS 7
    Many things can cause that... I'll tell you which things you may have done wrong --->
    1.You turned it off while installing an update. Solution: Format it
    2.A part of your hard-disk's boot has a bad sector. Solution: Download HDD Regenerator and check your disc for bad sectors (if there are bad sectors, you should back up your files and then buy a new hard disk)
    3.There's a problem with your Windows 7 booting files. Solution: Recover Windows 7 from their CD
    4.Your PC is affected by a rootkit (a type of malware that loads before Windows). Solution: Format it
    Hope this helps :)
    Dec 28, 2010 | Ellis Enterprises Maxima Bible Library 6.0...
    My computer HDD have bad sactors please help to remove this on
    When a hard disk has bad sectors, these sectors can be fixed by running check disk. This is a temporary fix as the hard disk is nearly worn out and it will get more bad sectors and evenually the hard disk will fail completely.
    Bad sectors occur when the magnetic oxide on the disk platters is worn out and data cannot be written or read from these sectors.
    To run check disk click Start - My Computer - right click on C Drive and click on Properties - click on Tools tab - then Check Now in Error Checking
    I suggest once this has been done, you back up your data and purchase a new hard disk ready to install Windows etc. when the hard disk fails completely. You may want to install a new hard drive before the old hard drive fails completely.
    Aug 21, 2010 | Western Digital Caviar SE WD1600AAJS 160...
    How can i speed up my aircel internet on pc
    5 ways to speed up your PCBy following a few simple guidelines, you can maintain your computer and keep it running smoothly. This article discusses how to use the tools available in Windows 7, Vista, and XP Service Pack 3 (SP3) to more efficiently maintain your computer and safeguard your privacy when you're online.
      checkdisk.jpgExample of Check Disk Local Disk dialog box
    4. Protect your computer against spywareSpyware collects personal information without letting you know and without asking for permission. From the Web sites you visit to usernames and passwords, spyware can put you and your confidential information at risk. In addition to privacy concerns, spyware can hamper your computer's performance. To combat spyware, you might want to consider using the PC safety scan from Windows Live OneCare. This scan is a free service and will help check for and remove viruses.
    Jun 13, 2010 | Microsoft Windows XP Professional for PC
    Microsoft Windows Vista Ultimate Edition Logo
    32 people viewed this question
    Top Microsoft Computers & Internet Experts
    micky dee
    Piyal Perera
    Piyal Perera
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
