Question about Drills
8391D left out in the rain!
I stupidly left my brand new Makita 8391D out in the rain all night. It was in its case BUT OPEN which was worse because once the moulding filled with water it gave it a pretty good soaking. I have dried it all extrenaly and have it sitting on our Rayburn. I am considering whether to risk taking it apart to try and dry it further, or take it into some sort of Makita drill hospital! Any advice would be most welcome.
Tim
  • tim_blake May 03, 2010
    Thanks Meola, I also decided not to take it apart, but kept it in a very warm dry atmosphere. Amazingly it all seems to work. I did take the charger apart and dried that with kitchen towel, that too seems OK now. So I think I got off lightly. Phew!
    Tim
    President:
  • 512 Answers
If the battery was connected you probably shorted out the battery. Shake all water out of drill and let dry. get a battery that was not in water, try this. If still won't work you will have to bring to repair shop. If you try and take it apart it may be hard to put back together.
Posted on May 03, 2010
My makita 8391d and the battery will not come out, what can i do?
you could dismantle the driver itself.. this will also give you clues as to why it was stuck in the first place
Apr 06, 2014 | Makita Drills
I have a makita 8391d cordless drill The problem is that the drill runs incredibly slow even when both batteries are fully charged I have checked the voltage and both batteries are showing the correct...
You have to check the batteries with a new machine. If the new machine works ok then the rotor of the motor of the old machine is broken.
Jan 18, 2014 | Drills
My makita 8391d runs incredibly slow
The motor is burned... I think the motor of the BHP453 and of 8391 is the same.
A piece of metal fell out of the speed selector (8391D) and now will only work on slow, not sure where it goes back in any ideas?
it was probably the contact for the high control. see if you can open it up and place it back in by the speed controls
Dec 07, 2011 | Makita Drills
Hi. I bought a Makita cordless drill, model 8391D. Whilst drilling a pilot masonry hole it suddenly stopped. The battery had only just started to slow so I changed it anyway to a fully charged one and the...
I would try changing the brushes and use compressed air I would blow out all the dust and lint I could from around motor.
If this does not help I would return for guarntee replacement. Thank you.
Mar 19, 2011 | Makita Garden
Where can I get a rebuild kit for my makita AN451 new O rings and driver pin
eReplacementParts.com is the site I prefer.
You can right click and select open or double left click on the link. If that does not get you to the site you can select and copy the site address pasting it into your browser address bar and clicking on refresh or go.
http://www.ereplacementparts.com/makita-an451-roofing-coil-nailer-parts-c-97_575_579.html
I did not see a rebuild kit. However, you can email them and ask about one. Worst case you can individually order the O Ring and other parts.
Mar 04, 2011 | Makita Roofing Coil Nailer AN451
I left my Makita 9514b out in the rain one night and I let it dry out the next day in the hot sun. I was using it and everything was fine and all at once it quit working. I figured it was still wet but I...
what does the end of the brushes look like, are they dark or shiny. what I would do if they are dark is unplug tool find a wooded emery board and turning the spindle by hand rub the board on the commutator to reseat the brushes. If this doesn't work let me know and I will try and come up with something else.
Aug 09, 2010 | Makita Angle Grinder
How do i remove the chuck from a Makita 8391D
I think you will find that if you open the chuck fully you will see a cross head screw inside the chuck which you need to undo before removing the chuck. this secure the chuck from unscrewing while being used in reverse to undo screws. Once this screw is out a spanner is used at the base of the chuck to unscrew it from the shaft. this may need a short sharpe shock to get it to move.
Jul 31, 2010 | Makita Drills
How do i remove the drill bit from a Makita 8391d cordless drill
Put the clutch on a high number, put the reverse on, hold the chuck tightly, lightly press the triger. If it does not come undone, make the clutch tighter (loer number).
Jul 17, 2010 | Hand Tools
Drills Logo
920 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
