Question about Westinghouse 24 in. MDP531 RF Free-standing Dishwasher
Water not drainiNg after completion of cycle
DISHWASHER WILL NOT DRAIN ALL WATER FROM BASE OF MACHINE WHEN CYCLE IS COMPLETE
DISHES PLACED ON THE TOP DRAWER ARE NOT CLEANED CORRECTLY
RESIDUE LEFT ON SURFACE MODEL 921 FREESTYLE
  • 177 Answers
Check for any kinked hoses and check the drain spigot under the sink where the drain hose connects into the u bend. Usually this is where food gets trapped due to the spigot not being drilled out large enough. This then causes a blockage. Also check the non return valve under the filter and make sure the drain pump can turn freely. This should solve the draining issue.
As for the dishes not being cleaned on the top drawer check the holes on the top spray arm. If the holes are blocked up with food you will get poor wash results. Best way to clean the spray arm is to remove it by unscrewing it and giving it a good clean under the tap and poking the holes to clear any blockages.
Hope this helps
Posted on May 02, 2010
Dishwashwer not cleaning dishes at all, though it runs through a complete cycle.
try removing spray spinner and clean out holes the spray heads get blocked and stop water flow, or you may be able to remove spray nozzles and clean out , i had this several times in the past also make sure the base drain filter is clean some times the small holes in the filter get smaller and smaller reducing water flow
hope this is of some help good luck
Aug 02, 2016 | Bosch SHE5AL06UC 24 in Builtin Dishwasher
I have a Fisher Paykel DD24 dishwasher and when using top drawer after wash cycle is complete there is always water in drawer. Top drawer is unable to drain water after wash cycle is complete...what can I...
If the cycle is complete and dishes are clean, then you need to worry. Try to pull the drain hose up a bit under the sink. Also buy a Finish dishwasher cleaning kit and run dishwasher as per instructions on the kit. That should clean any obsrtuctions in the drain side.
Nov 20, 2013 | Fisher and Paykel DD24DCX6 Dishwasher
Our dishwasher is retaining water in the base and not cleaning our dishes fully what is the problem?
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound. If it seems as a low water pressure then check the fill valve.
Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete.
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump.
The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes.
Hope this helps...
Daniel
Aug 15, 2010 | Frigidaire Gallery FGBD2451KB Full Console...
Gritty/sandy feeling on dishes from dishwasher
You could only check the basics. Since the dishes are clean, it means they went through the wash cycle. It also means that that the holes on the washer arm are not blocked. If they were salty and dirty the wash arms would be something to check. And since they came out feeling like salt is on them its possible they didn't rinse and its also possible the dirty water didn't drain.Were your drain and fill hoses checked or did the techs just check the dish washing machine itself? Its also possible the water for rinse is not hot enough. Before the rinse cycle comes around try running the hot water at your kitchen faucet. Any other issues may be within the cycling of the machine.
Apr 29, 2010 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Food particles are on dishes after washing
Try adding bicarb of soda/baking soda and vinegar in the detergent dispenser. Bicarb fizzes off hardened particles and vinegar strips off grease and aids rinsing.
Jan 26, 2009 | Maytag 24 in. PDB1420 Built-in Dishwasher
Water seems to be hot enough, drains properly, arnms not blocked, dishes not being cleaned at end of cycle. Almost seems like it is skipping the wash cycle.
Hi smiller8565,
There is 3 basic problems that will cause a dishwasher to not clean the dishes. You can check these problems and see if any will solve your problems.
1: If there is water or suds left in the dishwasher after the cycle is complete. This will cause dirty water to be used in the final rinse and the dishes will not get clean.
2: The pump that supplies water to the spray arms is jammed or defective and unable to pump the water properly, thus causing the dishes to remain dirty.
3: Timer, the timer is not allowing the machine to work in the wash cycle.
The solutions for these 3 are as follows.
1: check the drain line for blockage, if you have a disposal make sure it is clear and water flows down the drain properly. If you have suds left in the dishwasher, clean them out and run a couple cycles with not detergent to rinse away the old suds.
2: Look down in the bottom for any obstructions in the pump. Popcorn seeds, broken glass, etc.
3: If the unit is skipping the wash cycle you will most likely need a new timer or control assembly.
Good luck and I really hope this will Fix Ya
Mike
Sep 24, 2008 | Dishwashers
Dishwashers Logo
533 people viewed this question
Top Westinghouse Dishwashers Experts
Denis FixYa...
Denis FixYa...
Are you a Westinghouse Dishwasher Expert? Answer questions, earn points and help others
