Question about Husqvarna Viking 1
How much oil do i put in my husqvarna huskey boy for it doesnt say on the caseing
    Genius:
  • 1,116 Answers
You have posted in the category for small electrical appliances, such as the Husqvarna Viking 1 sewing machine.
Since the Husky Boy is a motor bike, the category for motors may be of more help.
You may also be able to get this info from a bike dealer.
Posted on May 02, 2010
How do I fix my noisy Husqvarna Viking 64 40.
If it is mechanical (not computerized), a thorough oiling with good fresh sewing machine oil or Tri-Flow Synthetic Lube will likely make a vast improvement. Open the top, the left side cover, and the area under the sewing surface. Gently rock the handwheel and apply 1-2 drops of oil every place that metal rubs against metal. Do NOT oil rubber/fabric belts, leather, plastic, synthetic parts or computer components. Old oil turns to glue and then varnish and actually inhibits movement. Keeping the oil fresh will help your machine keep running for a long time. Oil at least every six months when not in use. More often if the machine is used frequently.
https://www.youtube.com/watch?v=bsn4qvDRbtg
Sep 05, 2016 | Husqvarna Sewing Machines
Why does 835 make a loud noise when sewing?
Is it a mechanical machine? Most mechanical machines make louder sounds when they have not been oiled for some time. Consult the owner's manual and use ONLY good quality sewing machine oil.
Feb 16, 2016 | Husqvarna Sewing Machines
Husqvarna Mega Quilter. After using the thread cutter the bobbin thread will not pick up to continue sewing.
sometimes the cutter doesnt leave a long enough tail to start sewing, and the needle wont pick it up, use a diferent thread in bobbin, sometimes thats the issue, or manually extend the thread from the bottom and then start sewing, it will pick it up then
Oct 21, 2013 | Husqvarna Viking 1
My manual is missing during our several moves. I think my machine needs oiling. I put oil in all the places there is a 'plug' and the holes. I think is still needs oil. I can not figure out where else to...
About the only place you can oil this machine relatively easy is the hook, (the piece the bobbin case locks on to), and the side cover. The side cover where the light is comes off by removing the screw under the small round plastic plug. That about you can do without tearing it all apart. The main thing is to keep it free from lint build up.
Apr 24, 2011 | Husqvarna Huskystar 207 Sewing Machine
Where do you put oil on a viking rose sewing machine
The only user accessible pert for oil is the rim of the sewing hook. Remove the slide plate, needle plate and the bobbin case and put 1 drop of oil on the hook rim where the bobbin case rests. Wipe off excess oil; only a tiny amount is good, and carefully reassemble. Opening up the machine for internal cleaning and oiling is not recommended except by an experienced tech.
Jan 04, 2010 | Husqvarna Sewing Machines
Husqvarna 2000 1974, uneven stitches
Take out the bobbin case, remove the bobbin. Using laquer thinner on a Q-tip or a thin rag, clean the center "hole" of the bobbin case. Then look at the post in the machine that the bobbin slides onto. Is there thread wrapped at the back of the post? Also clean the post with your cleaner. Once the post and the hole are clean, put a little sewing machine oil on your finger and wipe the post with it and the chattering noise of your bobbin will be gone.
Take the thread off the top of your machine, put in a new needle.
Turn your top tension to Zero and lift the presser foot, this will open the tension discs of your machine. Using a needle, scrape or clean the area between the discs. (Your needle also has a flat spot on the top of the needle, that faces the rear of your machine.) Also look for any rough edges in the hole of your presser foot or the hole in your needle plate. If there are any rough edges in the metal areas that your needle goes through, you would have poor stitching. Don't forget to put your tension dial back on the red dot before you sew.
Oct 21, 2009 | Husqvarna Sewing Machines
Can't put a bobbin on the winder Husqvana Viking 6020
Is this a Designer 1 or a #1? There is no moving lever on the pin of a Deigner 1,they are fixed. If it's a #1, use sewing machine oil or Triflow. NEVER use 3 in 1 oil. It will gum up and cause problems later on.
Aug 31, 2009 | Husqvarna Viking 1
Huskey 165 Sewing Machine
I'm looking for a owner's manual too. If I find out how to get one i will let you know. mommy9
Mar 03, 2007 | Husqvarna Husky 165
Sewing Machines Logo
152 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
