Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Steel-line garage door opener. I have a steel-line panel lift garage door opener, when I try to open or close the door the motor spins for a sec very slowly and then does nothing. Is there anything I need to so inside the motor. IE grease as there is black bust inside the the actual motor housing where the magnets are. Does anyone know if these motors/gear combination is available so I can replace rather then paying $500 for a new unit. Thanks ikhan42
    Scholar:
  • 143 Answers
It sounds like either the safety sensors are not aligned, or the rpm sensor needs replaced. Also whether you replace or repair get a surge protector 900 joules or higher on this unit. You can get a reasonable opener with one remote for 138.00 at most lowes. Thanks BB
Posted on Sep 03, 2010
The drive chain of my lift master doe not turn when I try opening my garage door even the garage door is disconnected
Sounds like the gear inside the garage door opener needs to be replaced.
If you take the cover off you should see a lot of white powder inside the bottom of the garage door opener case.
You will also see a large plastic white gear that it shredded.
Feb 15, 2015 | Building Materials
Door does not ope or close properly
might door handle was broken because of that its haperning,,
Feb 20, 2014 | LG WM2101HW Front Load Washer, White, 4.0...
Chamberlain Lift Master Pro Formula 1 only makes click sound
Is the door stuck in the open position? If so the trolley is probably jammed against the bolt just in front of the motor unit. Loosen the chain enough to free the trolley and then run the opener until the door is closed. While the door is closed locate the 'up limit' on the side of the motor unit and turn this control 2 complete turns in the opposite direction of the arrow printed on the cover. Tighten the chain.
Apr 03, 2010 | Sears Craftsman LiftMaster Chamberlain...
Door openly opens 5-6 in, then stops.
If the door isn't unusually heavy when you open it manually then maybe an adjustment will help. On the back of the motor unit you will find the 'up force' control. Increase it 1/4 turn and try.
Jun 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
Motor wont run on craftsman opener
You need to remove the cover and look at the drive gear. It is probably stripped. I really recommend a technician to repair your door.
May 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberplain Garage Door Opener
The screws that attach to the garage door from the arm pulled out of the garage door and left holes in the panel. I tried to anchor the screws but they keep pulling ou..what do I have to do to secure the screws in?
Jan 02, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears garage door remotes
Tilt antenna different direction. Call Liftmaster for advice
Oct 02, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
421 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
