Question about Tricity Bendix 24 in. DH102 Free-standing Dishwasher
Does not dry the dishes at the end of the wash
  • 96 Answers
Heating element is not working
Posted on May 02, 2010
The dishwasher runs through it's cycle but does not clean the dishes properly and leaves a cloudy film and smears on the inside of the machine and the dishes
    Common Problem
  1. Confirm the wash water is hot
    1. Try heated wash(sani wash) if available
    2. Run hot water in sink to warm up before starting
    3. At least 120 degree Fahrenheit water temperature
  2. Open door check wash arm position start washer for a minute
    1. Confirm wash arm has rotated
    2. Check for plugged spray tips at either end of wash arm.
    3. Use small tweezers to remove
    4. Check for rack and dishes interfering with arm rotation
  3. Place cup in upper rack with opening up cycle washer.
    1. Confirm that cup quickly fills with water
    2. Not washing check water level in tub mim 1 1/2 inch
  4. Discontinue use of rinse/dry liquid additive.
    1. Confirm rinse/dry additive not leaking from dispenser into tub
    2. Washer detergent contains sparkle additive and too much sparkle/rinses/dry additive will coat dishes
    3. Try alternative wash detergent that contains minimal rinse/dry additive and use without liquid rinse/dry additive.
  5. It will take several wash cycles after the elimination of rinse/dry to purge the oily film from dishes and machine..
  6. If success "joy" is achieved with no additives then cautiously add back wash detergent with additives. Additives are important to facilitate drying and protecting the glassware china from leaching. The leaching process permanently etches the surface of glassware leaving a cloudy appearance.
Jan 03, 2016 | Dishwashers
Runs through cycle, but dishes and glasses do not dry, they are soaking wet.
10 Tips to Help the Dishwasher Run Better - Cleaning Tips ...
www.thekitchn.com/10-tips-to-make-yo...
Apartment Therapy's The KitchnFeb 24, 2014 - Well, we're here to help, with 10 tips for making your dishwasher run its best. ... loading up to help reduce particles stuck on dishes once the cycle is over. ...water to flash dry and not roll off your dishes, taking the ends of the dirty bits with it..... but can lead to damage, particularly of any glasses you put in the ...
[PDF]Dishwashers - Frequently Asked Questions ... - Bosch
www.bosch-home.com/Files/Bosch/In/in/Document/Bosch.pdf
this cycle the dishwasher dries the dishes. 3. ... dishes. During this time, you do notneed to be around the dishwasher as it ... Does it also dry the dishes after the wash?... You can put utensils that are made out of steel, ceramic, glass, plastic which is ...No, the dishwasher runs the whole washing programme automatically.
Why is My Dishwasher Not Drying the Dishes? ' Dr ...
Dec 03, 2015 | Dishwashers
Dishwasher not drying dished with any heat source. Dishes washed in cold water.
Most dishwashers are plumbed to the hot side of the hot water side of the faucet. This should provide hot water for washing the dishes. Perhaps this dishwasher was plumbed to the cold water side by mistake.
Most dishwashers have a heating coil most of the way around under the bottom sliding/rolling dish rack. The heating coil may not be working, which would be consistent with the dishes not drying at the end of the cycle. Possible causes include incorrect setting selected on control console (push buttons) or timer, heating coil disconnected from electrical source at one end or both ends, faulty control circuit inside the timer, faulty wiring between the timer/control circuit and the heating coil, burned or pitted contacts in the control circuit.
May 23, 2011 | Dishwashers
Dishes not drying properly
You may have it set to an ECO wash (economy)witch may exclude drying cycle at the end to save power.
May 28, 2010 | Viking DFUD042 Built-in Dishwasher
Dish feels hot but not drying
sounds like your heating element is not working prtoperly or you are not washing in very hot water stop washer in middle of cycle and open it if steam come out hot steam be careful keep face away when you open itif not hot that could be the problem,A appliance serviceman once told me if water is hot enough and end of wash and rinse cycle not to run the dry cyvcle just open dryer a few inches and let the steam out Run hot water over a plate or a pot and set it in the drain tray in your sink notice how fast it dries itself while draining in the tray very hot water in a dish washer dopes the same good luck with this problem I hope my advice helps you oh yes one more thing always run the hot water till it get hot before you turn your dishwasher on
Dec 15, 2009 | Kenmore Dishwashers
Dishlex dx 403 does not dry dishes - fan dry on red led
Ther have been a lot of complaints about the drying performance of these machines. One solution suggested by Electrolux is to use the "anti bacterial" wash mode, as this is a higher temperature wash, therefore dishes dry better. If you are using Eco wash or Quick wash, drying performance is not very good- Electrolux recommend leaving door ajar at end of cycle to improve drying. Also, ensure your Rinse Aid compartment is topped up, as Rinse Aid greatly improves drying performance.
-Please note: these dishwashers will not dry plastics and other items that do not hold the heat very well!!
-Also, you should be able to hear the drying fan running at the end of cycle- if not, then you may have faulty fan (uncommon), or control board (more common).
Good luck!!
Aug 12, 2009 | Electrolux 24 in. EDW5505EPS Stainless...
Model LD1403W1
Are you using a rinse aid like Jet Dry??  All dishwasher manufacturers now require that you use rinse aid for drying dishes at the end of the cycle.
Dec 29, 2007 | LG 24 in. LD-12BW5 Free-standing...
Not drying
These dishwashers have no heater for drying dishes. It has a fan to circulate warm air. It is very important that your water temp is at least 120 degrees. It is the combination of hot water and air circulating that dries dishes.
Nov 19, 2007 | LG 24 in. LDS 5811ST Stainless Steel...
Same problem here. I read the manual very carefully. "OptiDry", "ExtraDry", "EcoDry", "condensation drying" -- lots of fancy words to cover the simple fact -- they DO NOT DRY the dishes. There is no heating element. I wish they would just state this up-front. Air drying the dishes for 24 hours after each wash is not workable for most users...
Nov 12, 2007 | Bosch 24 in. SHX99A15UC Stainless Steel...
Tricity Bendix 24 in. DH102 Free-standing Dishwasher Logo
125 people viewed this question
Top Tricity Bendix Dishwashers Experts
Are you a Tricity Bendix Dishwasher Expert? Answer questions, earn points and help others
