Question about Freecom 80 GB USB 2.0 Hard Drive
USB not recognized
I am receiving USB not recognized when I plug my freecom xxs 160 gb 2.5 ext usb hdd. I hope you can help me find a solution to this problem. I have tried other PC already and the same error appears.
    President:
  • 1,851 Answers
If the usb ur using is 1.0 - it can read it - get a 2.0 external unit and you're good to go.
Posted on May 02, 2010
Freecom 320gb xxs external harddrive can't be recognized. i haven't used it for some time and now it wont work.
Freecom are a trusted make so I would assume that your laptop sees the unit when plugged in?
Mar 10, 2014 | Computers & Internet
It won't connect
re install your os xp sp3 then connect ur mobile drive
Aug 01, 2012 | Freecom Mobile Drive XXS 250GB, USB 2.0...
What should i do when my freecom toughdrive does not recognize of any computer
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Feb 19, 2012 | Freecom Computers & Internet
Freecom tough drive usb cable damaged. my 120 gb frecom tough drive's usb cable dameged and not working.
Sir, you can buy usb cable cord to a computer shop. i guess it is not expensive but you have to bring it and tell them in what model you using it. i hope that i help you, sir.
Nov 07, 2011 | Freecom (24358) 160 GB Network Hard Drive
When i plug in my XT hard drive windowa say no drivers
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
hope this helps you
Sep 01, 2011 | Freecom Mobile Drive XXS 250 GB USB 2.0...
My computer don't see mt toshiba 500 GB external disk. I had Win XP with SP3 and my external disk is connected to a USB hub with 8 ports. I had a pen connected to that hub and the computer see it. But...
Your USB hub cannot provide enough power for your external hdd, you can try to plug it in directly to any free USB port for the mean time to check if its detected or not, if it has a power button ( which is not normal for regular USB powered EXT HDD) make sure that it is on, if its still not working try to use a different cable, a known good cable or plug it in to a different computer to check if its your USB port, or the usb cable or the ext hdd that is causing the issue
Hope this help.
Jul 10, 2011 | Toshiba (HDDR500E03A) 500 GB USB 2.0 Hard...
Freecom 160gb harddrive not been reconized with usb
you can look at jaycar, **** or rs if the sell the right usb plug and solder it back in.
Jun 09, 2009 | Freecom (24358) 160 GB Network Hard Drive
Freecom 400GB Hard drive not recognized.its a Freecom mobile drive xxs 400gb , my pc just cant recgnize the hard drive
I'll assume your using Windows.
I'll assume it's a USB drive.
I'll assume it is an external drive.
And I'll assume it's formatted as NTFS.
Try using the USB (or FireWire) port for anouther drive to see if that is the problem, if it is then reinstall the driver for the port, through the Computer Managment Concole (assuming yur using windows).
If you formatted the drive as FAT, re-format it as NTFS.
Jan 02, 2009 | Computers & Internet
When I put my usb memory stick in to the usb in my Alpine CDE 9880R it sais USB ERROR or NO DEVICE
Make sure the USB device is formatted to FAT32.
I use both a 1GB Creative Zen nano and a 120GB Freecom mobile drive XXS with no problems other than the fact that the freecom has WAY more folders thatthe head unit can read!
Oct 10, 2008 | Audio Players & Recorders
USB Hard Drive
You cannot run a External Hard Disks (...that's what the User Manual say) It only reads Flash Drives, I have tried 8GB.
Oct 01, 2008 | JVC KW-AVX800 CD Player
Freecom  80 GB USB 2.0 Hard Drive Logo
536 people viewed this question
Top Freecom Computers & Internet Experts
Greg Ulan
Mithilesh Kumar
Are you a Freecom Computer and Internet Expert? Answer questions, earn points and help others
