Buzzing Audiolab 8000M/8000C set up
Hi. I just bought the following on ebay, which were described as ''excellent''. 2nr Audiolab 8000M 1nr Audiolab 8000C.
When I connect up the monoblocks I get buzzing and crackling from the speakers. If I add the 8000C to the circuit it becomes more of a buzz, which is ''cleaner''. All of this is very noticeable and the units are unuseable. I also tried using my 8000A as a pre amp, and the problem is still there.
Any ideas as t what is wrong, who could fix it and what it may cost? I am in London.
thanks
Derek
  • 1 more comment
  • djm749 May 02, 2010
    Hi
    Thank you for your ideas. I have tested the equipment using a different mains supply. I have also changed all the supply leads and checked that all plugs are earthed. All of that was ok. Not sure what else to look at now.
    Thanks
    I also have an Audiolab 8000A. I tried using that as a power pre amp and still got the buzzing in the speakers. I then tried it as a power amp with the 8000C I bought, and got no output whatsoever, so it looks like all 3 components are not working.
    Any ideas as to costs/
    just re read all this and realised I should have mentioned that the amps don't give too much speaker buzz when they are powered up without sources connected. add in a tuner or a CD player and it then starts to generate a lot of buzzing through the speakers.
    Scholar:
  • 75 Answers
Make sure ur mains supply and ur equipments are compatible. check all connections and most important make sure u have proper earthing.
Posted on May 02, 2010
  • John Muana
    John Muana May 02, 2010
    i am afraid either the power section or the power amp is burnt. it will not cost that much to repair. any qualified tech should be able to repair it.
In need of the torque settings for a 2007 Toyota Corolla 1.3 professional. Engine Code 1NR
cant find the repair manual for that
which torque specs are required
suspension
use "all others" as a guide
http://www.rockfordcv.com/Toyota_torque.htm
Aug 30, 2016 | 2007 Toyota Corolla
Need user Manual for Audiolab 8000 A Amplifier
http://www.hifiengine.com/manual_library/audiolab/8000a.shtml
Try this...sign up first (free)
Feb 12, 2014 | Audio Players & Recorders
Audiolab 8000 Amplifier User manual/ instructions/Pdf
you could try a website called manualslib.com They have a wide range of manuals etc. for a wide range of car audio makers/models.
Feb 12, 2014 | NAD C325BEE Amplifier
How do i return a new item I bought here but wassent straight from Dell, they won't take it. it was unopened
if the item is not as described, you can file for the significantly not as described dispute and you will be given a shipping label to ship back the item to the seller hence you will get refund for the item that you purchased.
Dec 12, 2009 | eBay Auctions
Word/Excel - trying to mail merge excel data into word document. Keeps carrying values out rather than following my Excel rounding to four.
Hi. I was pointed to a change in settings in Word that allowed the data to come over as I wanted.
Take care, Dennis
Sep 29, 2009 | Computers & Internet
Audiolab 8000CD Player Problem
This may be a problem with the sled motor. This is the motor that moves the optical assembly in and out along a rail. Try openint up the unit and cleaning off the rail with a dry cotton swab. Be careful not the leave any fibers on the rails. Also, while you are in there, clean the lens using another cotton swab and alcohol. Report back with your results.
Dan
Mar 28, 2008 | Audio Players & Recorders
Buzzing
try to get your mobile reflash...that should correct it
Dec 12, 2007 | Motorola Mobility RAZR V3
415 people viewed this question
 Grubhead
Grubhead
