Question about Garmin eTrex Vista GPS Receiver
I am having trouble getting location. Even when I get good satelite coverage (many showing on the screen) No location shows. It also seems to be slow in acquiring upon power up. How do a restore the units function?
  • Garmin Master
  • 695 Answers
Hi!
i checked out the Garmin owner's manual for your GPS:
http://www8.garmin.com/manuals/eTrexVista_OwnersManual.pdf
On page 6 it explains that from the satellite page there are four options from which you can choose;
1) Use with GPS off
2) New location
3) Restart search
4) Continue acquiring
If the date displayed on your unit is NOT today's date, select "Restart Search"
Since the GPS does NOT lose memory when the batteries are removed, the problem is unlikely to be that the GPS doesn't know where it was used last.
If the displayed time for your area is not correct, use the main menu to access the setup pages and follow the instructions for setting the time found on page 49. This SHOULD get you on your way.
Posted on May 02, 2010
White screen
This is a problem with shutter not fast enough opening to take a picture indoor shows the horizontal lines. In sun light it is too slow and over expose the picture. Not worth the trouble to fix, buy another camera?
Jun 26, 2012 | Olympus Cameras
Samsung SyncMaster 2232gw unstable
It seems from the begining you have had nothing but trouble, if under warranty return the item, because it will eventually fail, it is a matter of probability.
Apr 22, 2012 | Computers & Internet
When someone calls my lg Neon Phone it brings it straight to voicemail. But my phone doesnt even show that they called! It seems like it doesnt even have any signal even when I stand outside in sight of a...
Different phone companies use different towers, you may be standing right beside a tower, but that doesn't mean its the one your cell provider uses. It sounds like you just don't get service coverage in that area, which will make phone calls go straight to voicemail and not show you that they called.
May 19, 2010 | LG Neon GT365 Cell Phone
Can not start the computer -comes with graphic
Welcome to Fixya Support
I feel Happy to Assist You on this time
1.By analysing your Problem,it seems Like Screen or LCD fault,to confirm that just open lower small Panel where RAM is located just remove the RAM and replace with another One.if it is shows same problem.Deffinately screen or VGA section is faulty.
If it Covers warranty take it to the nearer Toshiba Service Centre they replace the screen or VGA faulty area free of cost.
I think it helps.
good luck
Jul 10, 2009 | Toshiba Satellite M115-S3094 Notebook
Cannot acquire satellites and freezes
use the web-updater at garmin
or update the firmware at garmin,
turn WAAS on
turn GPS signal off
go outside after the update
turn GPS signal back on ( takes upto 15 mins to locate satelites )
should be good
Regards
Richard.
Apr 21, 2009 | Garmin StreetPilot C330 GPS Receiver
No signal on my T-mobile dash
I am not sure of the problem and how well you know cell phones, But check to see if it is in airplane mode. Some how you have to get to the communication manage (where it will show bluetooth, wifi, data connect, direct push) and make sure that the "phone" is highlighted. Best of luck.
Jan 27, 2009 | T-Mobile Dash Smartphone
Can't get on internet
iphone uses wi-fi for first preference to connect to internet then drops to 3G if wi-fi not available then finally E (Edge) if you do not have either of those showing on your phone then it may be you are in an area where not even edge is available... try checking in different locations inside/outside your home.. down the street a ways or even a different part of your town. If you still cannot get at least the E on your phone maybe your service provider does not provide sufficient coverage for your location.. this does happen
Sep 21, 2008 | Apple iPhone 3G
Garmin Nuvi 200W
If you push for 5-8 seconds on satelit indicator and then release it, the satelit meni is showen.
Apr 29, 2008 | Garmin nuvi 200W GPS Receiver
Picture cuts off at bottom of screen
Do your basic trouble shooting first, disconnecting satelite or cable box, etc. to eliminate bad attached components or cables. How old is the bulb for this model. They are only good for three years of so. $300.00 part. If the main Wega engine is out, look out, expensive part. Have a qualified tech look at your unit. It will pay for itself as the picture looked even better than new after repairs.
Jul 24, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Garmin eTrex Vista GPS Receiver Logo
223 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
