Question about Kenmore 20.6 cu. ft. Top Freezer Refrigerator
Refrigerator not running, was a few days ago, copressor very hot
Model 2539366012
the compressor wasnt getting cold enough to freeze a cup of water 2 days ago. today, there was no coldness at all, and when i pulled it out from the wall, the compressor was very hot to the touch. should i scrap it and get a new one altogether, or could it be repaired?
  • badfast23 May 03, 2010
    turns out that the defrost timer was stuck in defrost and as such, the compressor was staying shut off.
Compressor got hot and motor shut off will it start up when it cools. If not what do I do
Posted on Jun 04, 2010
  • Kenmore Master
  • 1,606 Answers
" low charge " is a non-good tech answer . No such thing . Replace the overload/relay on the compressor . It Just plugs onto the side of the compressor . Take your model number with you to get the correct part .
Posted on May 02, 2010
  • Mike Smith
    Mike Smith May 06, 2010
    Thanks for the info . I can add it to my notes ... " A compressor is very hot to the touch if stuck in defrost " .
    Habit-Forming:
  • 193 Answers
If compressor is hot it means (a) low charge (b) locked rotor and in any case it can be fixed
GE Profile refrigerator does not get cold enough to keep food. The compressor is humming but even after having it plugged in for 3 days it has not frozen anything or kept any of the food cold.
Could be the t stat not shutting the unit off..so it runs all the time untill it freezes the evaporator in the the freezer then it runs and runs and gets hot...or if it has had a compressor replace before..the freon level what not put back in thr right way..meaning its overcharged, or undercharged..this will also do this...The coils are dirty under the unit...
May 29, 2014 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Samsung rs2630sh not cooling or freezing
If it has fan to deliver cold air, and it is not working, cold air is stuck on the begining. So your fan could be dead. And I suppose, that compressor is running all the time. Even compressor could stert freezing if fan does not deliver cold air in fridge. The other option is, that there is not enough gas in the compressor. In this case compressor vould not be freezing, but line, going out of compressor has to be hot, if it is not, there is no gas.
Dec 02, 2017 | Samsung RS2630WW Side by Side Refrigerator
Our freezer is cold but not cold enough at the top to make ice. It will freeze a cup of water at the bottom but doesn;t seem to be cooling enough. The compressor does come on and the fan is blowing. Is...
Get a thermometer, and place it inside the freezer. The temperature should get at least 17 degrees. If it is like 28 degrees or highe it will freeze water but not other things like some popsicles which freeze at lower temperature.
Mar 05, 2010 | Refrigerators
Sister has Montgomery ward upright freezer, she had 3-in-1 part installed compressor runs now but she called and said freezer is not getting cold, water in cup still not frozen after 1 day. Is there a way...
Don't know three in one is, capacitor?
The compressor has oil in it. If the unit is layed on its side, compressor oil can leak out into the refrigeration tubing. This can cause a refrigeration circuit clog. Leaving the unit disconnected, upright, for a few days, sometimes fixes this oil clog.
If it sprung a refrigeration leak, it's another story, it needs a service tec looking for a leak. Then repairs, just chuck it or invest in this nice unit on repairs.
If compressor and fan blowers all run and work, the electric portion is good, compressor line gets hot, the other one cold.
Aug 25, 2017 | Freezers
Frost Free refrig/freezer doesnt get cold enough
if you have 2 setting set both at the factory setting,if you don't know the factory setting set both at the halfway point and wait-mike
May 22, 2009 | GE Refrigerators
Hot to touch
there is another fan at the bottom, rear, of the refigerator. remove the bootom panel and look at the cooling fins to make sure they are not bent into the fan blades. Caefully bend the fins away from the fan. this should improve the cooling of the refrigerator and get rid of the hot spot on the rail between the refrigerator and freezer.
Apr 26, 2009 | Kenmore 53542 / 53544 Side by Side...
Freezer not freezing frig not cold
the compressor with a picture of an Indian, its a techumseh. Is the compressor running? If not, could be stuck in defrost mode. Since you have looked at the compressor, there is two lines that go to it. If there is an oil cooler, then 4. Follow the line, smaller of the two that goes to the condensor, rad. With the fridge running, use your hand to feel how hot it is, if you find it hot enough that you can't leave you hand on that line, then its an inneficient compressor.
Feb 09, 2009 | Frigidaire FRS3R4E Side by Side...
Refrigerator in garage
Yes it is very possible that exactly what you are describing can be happening. Also try a thermometer frozen in a cup of water to get more accurate temps. Also 33 in the fridge is very normal for the cold control set on max and the heater installed. Let me know the temps in the frz with the thermometer sensing product temp not air temp which fluctuates often.
Dec 22, 2007 | Frigidaire FRT21P5A Top Freezer...
I have a Frigidaire model FRT21LRG
CHECK TO SEE IF THE CONDENSOR FAN IS WORKING IT COOLS THE COMPRESSOR IF IT IS THEN UNPLUG IT AND LAT COOL DOWN FOR A DAY THEN TRY TO SEE IF IT WORKS BETTER IT MAY NEED A RELAY OVERLOAD TOO BUY A 3 N 1 START KIT IT TELLS YOU HOW TO WIRE IT ON THE PACKAGE
Aug 26, 2007 | Frigidaire FRS23KF7AB Side by Side...
Kenmore 20.6 cu. ft. Top Freezer Refrigerator Logo
308 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
