Question about Garmin nuvi 350 GPS Receiver
No signal how to get back my signal
    Scholar:
  • 174 Answers
Is the gps switched off for indoor use?
go outdoors, switch it on, and wait 'till it aquires satellites.
Posted on Jun 12, 2008
How to fix a back left turn signal?
Wild guess, in the process of fixing the tail light, you disturbed the signal connections. Go back through your work carefully, see if something is loose or bad connection.
Apr 09, 2015 | 2004 Toyota 4Runner
Turn signal switch repair
The steering column wheel has 2 pins pushed into the back side of it and as you turn the steering wheel making a turn, the pins slide over the humps of the blinker signal. As you return the wheel back to center to drive straight, these pins then hit the humps in the turn signal and push the turn signal back to the original position. It sounds like one of these pins fell out or broke off. You need to pull steering wheel and check to see if these pins are still inserted on the back side of the steering wheel.
Sep 29, 2013 | Mitsubishi Montero Sport Cars & Trucks
Problem with turn signal when headlight is on
this sounds like a earthing problem , so check the wiring for the head lights, see if any wires are trapped between something, bare wire touching car body , anythingthat doesn't look correct, could also be the indicator lever itself with a problem , but check the headlight wiring first
Jun 03, 2017 | 2002 Chevrolet Express
Back signal blinks fast no front signal
Right front signal bulb not working (burnt or disconected). Check bulb and connections.
Nov 02, 2011 | 2011 Chevrolet Traverse
Left turn signal outside lamp, front and back do
Inspect the turn fuse under the hood. There are seperate fuses for L and R
Feb 06, 2010 | 2003 Chevrolet Silverado 1500
Left turn signal (front and back) are not working
those cars have a lot of problems with the signal switch, same thing one signal wont work, to test try putting signal on and slowly wiggle or pull back slightly and up and down while watch signal if it starts working then it a switch, also make sure hazard button is off, good luck, hope this helps.
Nov 18, 2009 | 1995 Pontiac Grand Prix
2002 Hyundai elantra driver side turn signal not working outside
This simply means that the front driver side turn signal bulb has failed. Replace it.
Oct 28, 2009 | 2000 Nissan Maxima
No signal
hi, this message means that the tv is not getting a signal, what signal are you giving it ? cable, satellite, antenna ??? when you first turn on the tv it should say on the screen ch or v1 etc,. you could have a bad tuner or the set is not tuned to the proper input on the back of the tv, let me know what your input signal is & where on the back you have it connected, video-tek
Jun 05, 2009 | Hitachi 50FX30B 50" Rear Projection...
1987 toyota camry s/w back left (driver's side) turn signal does not work, bulb and ground are good, front left signal works but flashes fast, rt side signal both working ok. when emg flasher is turned...
Problem solved, Since 3 of the 4 turn signals worked I did not fuse was a problem
but after checking the turn swithch, I pulleded out the fuse which looked ok, but when
I put it back in all the turn signal lights woked! Apparently just one part of the surface
of the fuse was corroded.
Aug 01, 2008 | Toyota Camry Cars & Trucks
Garmin nuvi 350 GPS Receiver Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
