Question about Acer Aspire L310 (ASL310UD631A) PC Desktop
I have an acer aspire l3600 that wont turn on at all need a service repair place in the geelong region
5 Suggested Answers
  • 2976 Answers
SOURCE: My Acer l3600 Power Lead is faulty - is it
No. It's about 90-100 volts different.
Posted on Oct 29, 2009
  • 212 Answers
SOURCE: acer aspire L3600 unusual power problem
sounds like a hard drive issue. reformat your hard drive and put windows back on it.
Posted on May 23, 2009
SOURCE: cd stuck in my acer aspire L3600 which doesnt have
The L3600 doesn't have an emergency hole so you need to disassemble the cover. MAKE SURE IT'S UNPLUGGED FROM THE AC POWER BEFORE GOING FURTHER! I would only suggest this if your warranty has run out. Remove the screw at the back under the warranty label then slide the top cover backwards and remove it. You will see 3 strap type black plastic catches towards the front of the computer, lift each one to unclip the front then lay it forward (it will still be attached by a cable, leave it connected). You should then see a metal catch under the CD/DVD Drive, lift it then slide the CD/DVD player out of it's housing, remove the Ribbon Cable at the back but make sure you know how to reconnect it. Remove the 3 small screws from the top and the two on the side holding the metal cover on top of the Drive then take the cover off, you should now be able to lift out the CD. Do the reverse of the above to reassemble your computer and there you go.
Posted on Jun 27, 2010
SOURCE: cd stuck in Acer Aspire L3600
Acer aspire l3600
You may have a bad power supply. Did you turn it off, or did it go off by itself? Do you hear any beeps when you try to turn it on? Those may help you figure it out. If nothing happens you need more help, like a technician in person.This may be simply the power supply, or the motherboard may be done for.
Jul 19, 2013 | Computers & Internet
I am wanting to change my broadband connection to a wireless connection to use with multiple connections. Does the Aspire L3600 have what is needed for a wireless connection? I can't find any details.
The Acer Aspire L3600 only comes with a wired network option in the original basic configuration. Some models had an added WLAN card filling the mini-card slot. The best way to check if the WLAN card is in your computer is to check the Device Manager. In Windows Vista, Click Start > Control Panel > System and Maintenance > Device Manager (except in the Classic view of the Control Panel). For the Classic View there is a direct link to the Device Manager on the Control Panel. For XP, it's Start > Control Panel > Performance and Maintenance > Administrative Tools > Computer Management > Device Manager (in Classic View, just skip the Performance and Maintenance step). If you upgraded to Win7, Start > Control Panel > Hardware and Sound > Devices and Printers > Device Manager. Scroll down the list to find any Wireless drivers that are installed.
(If you have one of the machines with Unix, check the specific documents. My Unix experience has always been wired.)
The Aspire L3600 specs are available here: http://support.acer.com/acerpanam/desktop/0000/Acer/AspireL3600/AspireL3600sp2.shtml .
I hope this helps.
Aug 10, 2011 | Acer Computers & Internet
Hi I've got an acer aspire l3600 and got a broken ribbon cable clip on the back off the cdrom can you please tell where i can by a new one or can i fix it up in another way .
Amazon and eBay are the cheapest place to get specific parts like that. Consult Acer's website to find the service manual, that will give you the exact part number.
Jul 15, 2011 | Computers & Internet
I want to get driver tv tuner for acer aspire l3600
It's a problem for us to assume since you didn't mention the Operating System installed on the Acer Aspire... moreover there are two types of tv tuner card that comes with this model. I hope you'll not mind letting us know all these next time so that we can help you better.
If the operating system install on your system is Windows 7 the click the below links to download
Acer Aspire L3600 Connexant Tv Tuner driver for windows 7
Acer Aspire L3600 Yuan Tv Tuner driver for windows 7
Once you click the link, download will automatically begin. You'll need winrar or winzip to extract the files. Extract the files and run the setup or as per your convenience.
Acer Aspire L3600 Yuan Tv Tuner driver for windows vista
Currently, there's no drivers available for windows xp but you can still run it by using the "Device Manager" > "Update Drivers" wizard after extracting the windows vista drivers.
Good luck.
Thanks for using FixYa.
Jul 08, 2010 | Computers & Internet
Oct 29, 2009 | Acer Computers & Internet
Acer aspire L3600 unusual power problem
May 09, 2009 | Computers & Internet
Do i need the cables for the router?
To go Wireless on your desktop Acer Aspire L3600, you should consider buying an USB Wireless Adapter. It could be any brand as long have same frequency with your Netgear (i.e 2.4 Ghz/5.8 Ghz)
P.S.: If this information was helpful, please rate this solution.
aymloekh0fg4hpz2e87n86udvs4fowqwshuaaaaasuvork5cyii=
Apr 01, 2009 | NetGear DG834G Router
Acer aspire 3610 lan driver
Go to control panel. Select Add hardware. Select that you connected the hardware. Find the device you need to update and tell Windows that your drivers are located on the desktop using the browse option.
Aug 21, 2008 | Acer Aspire 3610 Notebook
Restore factory settings to acer aspire L3600?
you need to press the Alt and F10 key together when u restart ur system on the initial power on screen
Mar 20, 2008 | Computers & Internet
Acer Aspire  L310 (ASL310UD631A) PC Desktop Logo
539 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
