Question about RCA HD52W59 HDTV Projection Television
No picture on my RCA HD52W59
Hi -- I saw your reply to someone about their RCA HD52W59 tv. I am also looking for a replacement bulb or lamp and was disheartened to see you say that there is no bulb or lamp to replace. So what are my options? I've only had the tv for about 15 months, but the warrantly is only for 12 months. I can't just let a thousand dollar tv go to waste like this. I checked RCA technician rates, and it would cost hundreds just to come and service, and probably additional $$ for the parts.
So again, what are my options? I would appreciate any info you can provide. Thanks.
  • rca_troubled Mar 27, 2008
    Thanks for the reply. I guess I didn't describe my situation as specific as I should have -- I do get audio, but absolutely no video -- no lines, no on-screen menu, nothing. No white fuzzy stuff if I put it on a non-existent channel. Nothing. But audio is fine, so I don't think power is the problem. I really think it's something specific to the video, either a projection bulb or the picture tube. That's why I was distressed when I read that this system does not have a projection bulb -- is that correct or did I misunderstand? In any case, now that I explained that thr problem is strictly with the video, can you possibly give me a better idea of which part/component it could be?
    Thanks again!
  • rca_troubled Mar 28, 2008
    The model # is HD52W59
    The serial # is F494CU021
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 208 Answers
Well, this is a difficult situation. I assume your unit will not power up and this can be several problems in this unit and will most likely require someone with troubleshooting experience. I would suggest finding a repair service that gives free or reasonable estimates if you bring the unit to them and haul it in for the estimate. This unit has chronic failures of the deflection/power bd. as well as the convergence power supply and convergence amp. bds. I have also had several with shorted crts, and shorted ic's on the crt drive bds. so It is impossible to guess.
Posted on Mar 27, 2008
  • 1 more comment
  • Anonymous Mar 27, 2008
    I am sorry, there is definately not lamp or bulb in this model. The unit has 3 crt's, red, green and blue. With no picture at all you most likely do not have high voltage. This would most likely require replacement of the deflection/power bd. Please provide the service # off of the unit and I can provide the part # for that bd. The service # is the model # and some letters and #'s after the model. This is written very small just below the model # area.
  • Anonymous Mar 29, 2008
    I would will still need the entire service # as I described in my response.
  • twysted420 Jan 19, 2011
    hello, i just saw this feed, and i just got this same model from a friend. he told me it needed a new bulb. now i know there's no bulb! so, will you please provide me with the part # for that bd? my service # is HD52W59yx38. thank you so much if you are able to!
SOURCE:
Lamp keeps going off an on (1 min intervals)
I will need the model number of your set. The HD52W59 doesnt have a lamp as thats a three picture tube TV.
Jun 26, 2010 | RCA HD52W59 HDTV Projection Television
IS IT JUST THE BULBS/LAMP
Please contact RCA "Head Office" in your area, ask for a referral to an Authorised Service Center. This is VERY important. Ask for a "Quote" before proceeding with any repair.
Apr 01, 2010 | RCA HD52W59 HDTV Projection Television
RCA HD52W59
Actually, we didn't remove any bulbs, we removed the lamp in the back of the tv.
Dec 14, 2008 | RCA HD52W59 HDTV Projection Television
RCA HD52W59
you can get any board needed at the following link for your model its the ITC222 chassis, they have pictures of the various boards so you can deyermine which board it is that youre needing. Heres the link.
http://servicemanuals.vstore.ca/
Aug 24, 2008 | RCA HD52W59 HDTV Projection Television
Picture turns on and off
Just found this trying to figure out what was wrong with my same model tv. Since mine was under warantee, I had the repairman troubleshoot it. He changed the lamp and the tv started working normally again.
I didn't understand how the lamp could be bad if it lit up while the tv was on. He said the tube was probably using too much voltage or too little voltage to run, so the tv would turn itself off and on in an attempt to receive the correct voltage from the lamp.
I realize this is 9 months late, but maybe it can help someone else who has this problem. I can't believe there are only 3 rca dlp's out there with this problem.
Mar 10, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
I need a replacement tv screen for a rca hd52w59 itc222a
I have the 52" set of screens as well, if you still need them, email me @ [email protected] or just reply here.
Feb 13, 2008 | RCA HD52W59 HDTV Projection Television
Replacment bulb
This unit is a crt rear projection tv and does not have a bulb or lamp. this unit has a red, blue and green crt. The only service manual for this unit is provided by RCA on cd or dvd.
Jan 21, 2008 | RCA HD52W59 HDTV Projection Television
Bulb type?
This TV is a CRT rear projection - It uses 3 picture tubes - not a DLP lamp.....
Nov 05, 2007 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 HDTV Projection Television Logo
681 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
