Question about HP PSC 2410 All-In-One InkJet Printer
Where do I buy a power supply cable - HP PSC 2410 All-In-One InkJet Printer
    Genius:
  • 1,044 Answers
Contact your dealer where you purchased the printer OR Contact HP customer service center. OR Contact support on the HP printers web site OR Check at electronics retailer shop in your town
Posted on May 02, 2010
Power supply of dell d09m not working
Buy a new one and install it. You need something that is at least as powerful as the one you are replacing. And buy a decent name brand supply, don't go cheap your entire computer depends on what power supply you choose. Visit Hardware Revolution for an excellent writeup on choosing a new power supply. Before you take the old one out unplug the machine and press in the power on button for five seconds to drain what you can. Open the case and take pictures of where all the cables from the power supply insert into the mother board and video cards (if any) and sometimes a case fan will be clipped into the power supply as well. Remove the old one after grounding yourself to the case and install the new one. Power supplys are rated in Watts, the one pictured below is 810Watts/67.5Amps. Your supply will have a sticker similar to the one pictured below. Dell use the cheapest and lowest rated supplys they can get away with. Buy something better. If you replace the supply and the computer won't boot either the old supply was good and something else was fried or when it died it took out another component like the motherboard. Check if you have a loose stick of ram, any cable or cord or a card half out of it's slot. Try to reboot again. You may see a steady or blinking amber light on the motherboard that indicates a power problem with the motherboard or power supply. Look for bulged, loose or leaking components on the motherboard. Capacitors especially. Good luck!
Oct 27, 2014 | Computers & Internet
Replace power supply motherboard
Replacing power supply mother board risks fire and shock. For the cost of a new supply, It is far better to replace it. I believe that is a standard power supply. You can buy them from Staples or Best Buy for cheap.. If you're not sure of the correct part, remove the old one (only 4 screws and a few cables) Make note of cable connection locations.. but really, it is pretty hard to put a plug into the wrong socket. Bring the old supply to your supplier of choice and match it with a new one.. Higher wattage is OK, lower is not
Good luck
Jan 15, 2014 | HEWLETT-PACKARD Hewlett Packard Pavilion...
Where do i get a Hyundai ImageFlat L70A 17 in. Flat Panel LCD Monitor power cable
you can buy it in an computer supply store ,electronics supply and in hardware they have supplies op power cables
Aug 19, 2010 | Hyundai ImageFlat L70A 17 in. Flat Panel...
Need to buy a power cord to replace the original. Do you know where one can be purchased?
Modern monitors and desktop computer use universal power cables, so you should be able to go to an office supply store like Staples or Office Depot or an electronics store like Best Buy and ask them for a monitor power cable. It will have a three-prong end to plug into the wall and a six-sided end with three recessed slots to plug into the monitor.
If you want to buy online, monoprice.com has grest prices on cables.
Good luck.
Jun 09, 2010 | AOC LM742 17" LCD Monitor
The unit can't work properly. the purple cable for 5v is ok and also the green one for ps on.but the others are spoiled out, incuding the blower.
There is a partial damage of your power supply. Rather
than troubleshooting the defect., It is advised to buy a
replacement. Troubleshooting it will be expensive than
buying. Hope this helps.
Dec 09, 2009 | Kingwin Inc. Kingwin Divine KWI-450WAS...
Gtx+ shorts out powersupply
1.Power supply doesn't have enough Amps for the 12 volt voltage rail.
2.Power supply doesn't have the required power cables/connectors required.
You NEED TWO 6-pin PCI Express power cables.
If you use just one, you will burn up the connectors down in the PCI Express x16 slot, and the power cable connection on the GTX card, and/or fry the power supply.
3.Cheap power supply that came in a deal when buying a computer case. Cheap case? Cheap power supply.
Aug 16, 2009 | Pine Technology XFX GeForce 9800 GTX+...
What is a good replacement for the MGE 400W
all you have to do is swap it with another one with the same specs connectors and wattage, thats a good PSU, i'd replace it with 550 wats
Nov 27, 2008 | MGE 400W Power Supply (QG) Power Supply
Please help for Cable and Power supply for KOGI monitor L7EH-TA ???
the power cable is as the simple attach to run the pc..
the vga cable u have to buy it from computer/monitor shop..
ask them for cable by telling them the model and spec. of your monitor.
regard,
dont forget to rate it
Jun 14, 2008 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
HP PSC 2410 All-In-One InkJet Printer Logo
43 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
